Results 1 to 3 of 3
    'All over it!'
    Reputation: lornibear's Avatar
    Help with Juicy 7's.......
    I have also posted this thread on the Brakes forum but wanted to ask the Nicolai forum this question......
    I am planning to purchase some straitline lever blades to replace the ones on my juicy 7's. Can anybody advise or tell me how to remove the old blades and replace with the new as I can find no answers on the SRAM website.
    Many thanks
    Drink...sleep
    Reputation: Boozzz's Avatar
    Aug 2005
    That's pretty easy. Loosen the set-screw on the lever (hyper-extend the lever to do this), push out the lever bushing, pull out the lever and remove the rod that connects the lever to the cilinder. For your new lever, just repeat these steps in reverse order.
    You can also download the rebuild instructions pdf from SRAM's website. Should be there somewhere, I used it about a year ago to rebuild my levers.
    Edit: Found 'em here, http://www.sram.com/_media/techdocs/...TechManual.pdf
    'All over it!'
    Many thanks there Boozzz, sweet as.
