Results 1 to 5 of 5
    Helius AC 26" 2013 Head Angle with Revelations 150mm
    Nicolai give a head angle quotation of 66.5 degrees and a fork refferring measurement of 539mm. I have a Helius AC 26" on order and will be running Rock Shox Revelations at 150mm that are more like 529mm axle to crown. So I would be interested to hear from 2013 26" Helius owners that run revelations to find out what the actual head angle is with that setup.
    Steepens HA and SA by 0.5 deg and lowers your BB by 3mm based on a medium AC
    Aka chainline...
    I see. Mine will be a large. Maybe the best answer is an external lower headset cup to slacken off and bring the bottom bracket back up with the 150's.
    Distributor
    Reputation: nicolai-uk's Avatar
    I'm running a 150mm fork on my 2013 AC but haven't tested it yet. It really shouldn't be a problem - tech sheet says 140-160mm forks.
    Simon Still
    Momentum Distribution
    www.nicolai-uk.com
    Quote Originally Posted by nicolai-uk View Post
    Yes no problem with revs but I think the axle to crown quoted is 10mm longer than revs and hence will change all the angles. The reason I wanted the AC is that it is one of the few 140-150 frames that don't have 67-68 degree ha and is slacker. I personally find that half a degree makes a huge difference and makes a bike miles more capable which means it is a true all rounder.
    What sort of weight did your new Nicolai come out at?
  1. Replies: 10
    Last Post: 01-23-2013, 03:39 PM
  2. Slack Head Angle + Steep Seat Angle
    By motard5 in forum All Mountain
    Last Post: 07-25-2012, 06:12 AM
  3. Replies: 3
    Last Post: 07-01-2012, 11:44 PM
  4. Custom angle sets for 1 1/8" head tubes
    By arne_and in forum All Mountain
    Last Post: 08-23-2011, 01:29 AM
  5. Replies: 71
    Last Post: 03-30-2011, 10:57 PM
