Results 1 to 13 of 13
    Headset for CC - advice please
    So, following on from my earlier thread, I've jumped in for a CC - very excited!
    I'm robbing 90% of the parts from my Specialized FSR - trying to keep cost to a minimum here - and thankfully most everything will fit (I hope!!)
    Looking for some help on headset though. It is standard 1 1/8th head tube. I recall there is a need for a deep headset though, or am I making that up?? Wanting to keep costs reasonable so was looking at something like a 30 Cane Creek S3. Will that do the job or do I need something more specific?
    PS - CC arrived yesterday - many thanks to 5c0tty of this parish!
    "Its All Good"
    Reputation: Whafe's Avatar
    It arrived yesterday, well where are the pictures then?
    Just the frame so far! This weekend's project is starting to get it built up - photos will follow for sure!!
    Reputation: dipper's Avatar
    Jun 2005
    No need for a deep insert headset on the cc. Ac upwards require them as they're longer travel, bigger hitting frames
    www.gravity-sports.co.uk
    flash bikes for flash gits
    Reputation: 5c0tty's Avatar
    What did I do ?
    Looking forwards to seeing the build up...
    Nicolai Bikes in the South of England head to..
    http://www.head-for-the-hills.co.uk
    i have just ordered an AC and was going to use my old chris king headset from my Turner 5 Spot which is standard.
    Why do i need a new deep insert if at all?
    Quote Originally Posted by 5c0tty
    What did I do?
    Bought it from you on ebay! (or from Head for the Hills anyway - maybe not you personally!)
    Jun 2005
    Nicolai advise that you fit a deep insert headset(22mm) to their long travel frames. Not everyone does but you won't be warrantied if you ovalize the head tube.
    what is classed as Nicolais long travel frames?
    Everything greater than the CC?
    Jun 2005
    Tech specs are on the nicolai website. AC and above are all 22mm insert(assuming 11/8th). I cant actually see the cc specs for some reason but from memory it only requires 12mm
    The 2 options vie used are chrisking steel set(heavy) and an Acros. The across is very light and very high quality. It would be my choice
    Reputation: steve_b77's Avatar
    I run a Hope in my CC, can't see why a Cane Creek S3 won't do if you're keeping the cost down
    Hope for me too.Well sealed last ages , don't creak & best of all you can get them in red!
