Results 1 to 6 of 6
    Hammerschmidt on Helius AC
    Long time lurker coming out of the cupboard.
    I have this set up on my BB for the ISCG tabs
    I was hoping to fit a Hammerschmidt crank set to it however when I fit the backing plate it doesn't clear the adapter.
    I would need to remove this..
    Any other options apart from not fitting it?
    Many Thanks
    EDIT
    found this on Nicolai site
    Almost all NICOLAI frames are available with adapters to mount Shift guides, Chain guards, or Hammerschmidt® internal gear cranks. For models where chain-guards are mandatory or where the use of Hammerschmidt® cranks makes sense we offer mounting adapters as a surcharge-free option. We offer 3 different kinds of adapters. The ISCG 03 and 05 type is fixed with a bolt between a weld-on part at the frame and the chain-guard. The slotted holes enable further positioning as the adjustability of chain-guards is often limited. The ISCG adapters are not compatible with Hammerschmidt. We offer a special weld-on adapter to mount the Hammerschmidt directly onto the frame. This weld-on Hammerschmidt adapter on the other hand is ISCG 03 compatible and can be used for chain-guards.
    so it would appear not!!
    Attached Thumbnails Attached Thumbnails Hammerschmidt on Helius AC-2013-07-05-16.53.49.jpg
    My Old AC had Hammerscmidt iscg, was completely different to the one shown.
    Is a fixed mount that has been faced as the hammerschmidt needs perfect alignment.
    http://fstatic1.mtb-news.de/img/phot...DSC01513.JPG?0
    I have what I have, I'm looking for a possible work around to fit a HS.
    When I bought the frame I did ask if it had ISCG 05 tabs, which it does but I didn't envisage that it wouldn't be suitable for the HS, lesson learnt there.
    So anyone any idea's or suggestions other than buying a new frame?
    Reputation: dipper's Avatar
    Jun 2005
    HS compatible tabs are a much stronger welded on affair. in theory those mounts above are not strong enough for the HS. im not entirely sure why but i guess its to do with the torque applied when in overdrive. although considering the HS itself is only held on by 3 small allen screws cant see why it would matter!
    www.gravity-sports.co.uk
    flash bikes for flash gits
    Update and thanks to Swavis from another forum , I'm now sorted.
    He made me this mount
    Fitted to the frame
    Many thanks Swavis
    and no thanks go to Nicolai for your non help, still awaiting an email reply...
    Excellent job. I known the guys at Nicolai are very busy at the moment getting sorted for Eurobike. No excuse, but probably the case.
    Aka chainline...
  1. Replies: 147
    Last Post: 07-01-2012, 09:53 AM
  2. Converting a 2009 Helius AM into a Helius AC
    By geetee1972 in forum Nicolai
    Last Post: 03-27-2012, 01:14 AM
  3. HammerSchmidt!!!
    By mlb6d9 in forum Colorado - Front Range
    Last Post: 07-01-2011, 11:13 AM
  4. ?HammerSchmidt?
    By RideEverything in forum Knolly
    Last Post: 04-18-2011, 02:55 PM
  5. Hammerschmidt on Helius AC
    By tantrumizer in forum Nicolai
    Last Post: 01-19-2011, 11:27 AM
