Results 1 to 16 of 16
    Distributor
    Reputation: nicolai-uk's Avatar
    Feature requests
    Please add your votes to the totals below and reorder the list. 2 votes per forum member (post both to a single line if you want). Add new features if you think of anything. Change your mind - add new post with revised totals.
    44/56 Headtube standard fit on all frames – (1)
    Improved Bearing/bushing design with greaseports – (1)
    650b Helius AC -
    ION 16 (to replace Helius AM) -
    Helius AM 29 as standard model -
    Helius ‘RC’ 29 (lighter weight AC29) -
    142mm rear -
    Modular dropouts (bolt on dropouts to enable change between QR/142mm/135mm) -
    Simon Still
    Momentum Distribution
    www.nicolai-uk.com
    44/56 Headtube standard fit on all frames – (2)
    Helius AM 29 as standard model - (1)
    650b Helius AC -
    142mm rear -
    NB (Helius AM29 would replace AC as the rear suspension range and fork range would cross over if 44/56 HT or 1.5" HT used. Weight would be very similar. Naturally leading to a lighter RC/AC))
    Aka chainline...
    Reputation: dipper's Avatar
    Jun 2005
    44/56 Headtube standard fit on all frames – (3)
    Improved Bearing/bushing design with greaseports – (2)
    650b Helius AC -
    142mm rear -
    www.gravity-sports.co.uk
    flash bikes for flash gits
    Reputation: Midgetman's Avatar
    650b Helius AC -
    Helius ‘RC’ 29 (lighter weight AC29) - (1)
    142mm rear -
    44/56 Headtube standard fit on all frames – (4)
    Improved Bearing/bushing design with greaseports – (3)
    650b Helius AC -
    142mm rear -
    Modular dropouts (bolt on dropouts to enable change between QR/142mm/135mm) - (1)
    Helius AM Style Shock Mounting on Helius AC as Standard - (1)
    __________________
    "Its All Good"
    Reputation: Whafe's Avatar
    Helius AM 29 as standard model - (2)
    650b Helius AC -
    Helius ‘RC’ 29 (lighter weight AC29) - (2)
    142mm rear -
    "El Whatever"
    Reputation: Warp's Avatar
    44/56 Headtube standard fit on all frames – (5)
    Improved Bearing/bushing design with greaseports – (4)
    650b Helius AC -
    142mm rear -
    Modular dropouts (bolt on dropouts to enable change between QR/142mm/135mm) - (2)
    Check my Site
    Improved Bearing/bushing design with greaseports – (5)
    650b Helius AC -
    142mm rear -
    Integrated fork bumpers for Ion 18, Ion 20 and E2 - (1)
    Improved Bearing/bushing design with greaseports – (6)
    650b Helius AC -
    142mm rear -
    Modular dropouts (bolt on dropouts to enable change between QR/142mm/135mm) - (3)
    Remember, you are unique, just like everyone else.
    650b Helius AC -
    ION 16 (to replace Helius AM) - (2) 650b
    142mm rear -
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    650b Helius AC -
    +1 Helius ‘RC’ 29 (lighter weight AC29) - (3)
    142mm rear -
    +1 Modular dropouts (bolt on dropouts to enable change between QR/142mm/135mm) - (4)
    Add: revised geometry on 29"
    Add: 650b compatibility across the 26" range.
    Hard funkin΄ Kraut
    Reputation: NoStyle's Avatar
    May 2005
    650b Helius AC -
    +1 ION 16 (to replace Helius AM) - (3)
    Def for an ION-16, but please keep it 26. Not shure if the AM needs to be replaced ...
    142mm rear -
    "Its All Good"
    Come on Nicolai peeps, if you have not completed this, please do.....
    steep fast and loose :)
    44/56 Headtube standard fit on all frames – (6)
    Improved Bearing/bushing design with greaseports – (7)
    Improved Bearing/bushing design with greaseports – (8)
    650b Helius AC -
    Helius ‘RC’ 29 (lighter weight AC29) - (4)
    142mm rear -
    44/56 Headtube standard fit on all frames – (7)
    Improved Bearing/bushing design with greaseports – (9)
    650b Helius AC -
    142mm rear -
