Page 2 of 2 FirstFirst 12
Results 101 to 169 of 169
  1. #101
    'All over it!'
    Reputation: lornibear's Avatar
    600lb Spring Anyone????
    Quote Originally Posted by ryates
    Hi Lorni, hope you are better. Can I suggest you e-mail Malcom at Cane Creek. He gave me a 450lb spring for my old FR set-up. You are only 30lb heavier so it sounds that you are running the wrong spring.......may be even less than 650lb? Whafe, what are you running and whats your weight?
    Well I have tried to get somewhere witht the 650lb spring but still think my FR is oversprung. I have set the sag to just over 35% but the shock still does not feel as plush as I'd hoped. I have the LSC dialled right out and minimal HSC which leads me to believe I may need a 600lb spring. Anybody in UK got a steel one I can borrow to test my theory? Many thanks in advance
  2. #102
    steep fast and loose :)
    lorni - PM Dipper for a spring
    I'm 86kg kitted on a 400# spring momentarily.......
  3. #103
    'All over it!'
    Thanks TLR, will do.
  4. #104
    lorni - fwiw i've quit estimating sag - i now look to pre-charge the shock circuits with a bit of preload and then dial in a bit of LSR / HSR whilst focussing on LSC and HSC....in fact i run very little HSC (about 1/4 turn) and try to get it plush around mid point LSC / LSR looking for the shocks most efficient zone, so to speak.......
    does this make sense
  5. #105
    'All over it!'
    Well if you can offer any advice, it would be much appreciated. After I figured out that I had the shock in the wrong forward mounting points, I am back to square one. I have enough preload to hold the spring on without moving and next to no LSC.
    Can you try to get me at a base setting as the factory settings are poo. Sag is roughly calculated at 22mm which equates to about 38%. Perhaps it's me, but it still doesn't feel dialed. I have slowed the rebound down a little, perhaps it is this which is making the shock feel inactive? Sure on the hits it feels good but at the moment it feels like it has a platform even at 38% sag.
    I am confused.....
  6. #106
    'All over it!'
    I might try and contact dipper next week as I know he is over 200lb and has a CCDB, see what he is running on his shock?
  7. #107
    dipper can't get below 68 seconds at Knockhill !!!!!
    if you PM me i'll give you my number and we can discuss - too difficult to dial in over the net
    however, if it takes the square edged hits (HSC) and has a stable pedal platform (Horst + CCDB mid stroke control) then it sounds pretty good to me .... however, best to call me to discuss
  8. #108
    Hi Lorni
    From my experience I would start with about half to one turn HSR/ HSC in from fully open and about 12 clicks of LSR/LSC out from fully closed.
  9. #109
    'All over it!'
    Ryates - I am open to any suggestions at the moment - so many thanks for your advice. I am going to sort this sucker after the easter break with regular trips to Chicksands.
    TLR - Many thanks for your kind offer. I will PM you momentarily and get in touch after Easter, again many thanks.
  10. #110
    Reputation: dipper's Avatar
    Jun 2005
    lorni
    if you think theres currently too much platform, try backing off all the circuits and working in from there. I run the HS circuits wide open pretty much everywhere. The LS circuits I change depending on where i am and what i'm doing. Sag @ 40%
    TLR - no idea what motorbikes have to do with anything but I know 68sec is quicker than you've ever done. And seeing as you've bottled it like the big girls blouse you are you'll never be able to prove otherwise! If you're up for the challange, I'm going back in may.
  11. #111
    don't forget the characteristics of the leverage rate of the frame - or the Horst link design, making a stable pedal platform BEFORE the CCDB has been introduced into the equation.
    FWIW, It's doubtful whether the HELIUS needs a shock as well controlled as the CCDB due to it's inherently stable suspension design !
    Therefore, as mentioned above, start opening all the circuits wide open, then close in......
  12. #112
    'All over it!'
    Dipper & TLR - Thanks for the advice. I went to the local park this morning armed with my 10mm spanner and I think I am getting somewhere. The rebound circuits are set up to my liking thus eliminating the 'kick' often associated when the shock reasserts itself.
    With that dialed, I am now making headway with the HSC. I have hit a few jumps up to about 3 foot in height to flat and I can really feel the shock working on the landing. It sometimes feels as though I am blowing through the travel due to it feeling so plush with no bottom out.
    On your advice, I have backed the HSC off to minimum and am now working on setting it a little at a time and doing the same jump. I am back to the park this morning to have another bash and perhaps hit some bigger stuff for confirmation, will let you know how it goes. Many thanks to both of you.
  13. #113
    Reputation: Karve's Avatar
    Mar 2006
    After riding for a year on this shock I only ever adjust 2 things now
    HSC - when doing BIG stuff I whack it up... on the trail rides i lower it to make it more supple over fast roots and the like. By whack it up i mean 2 clicks lol
    LSR - my preference of how much pop I need off of jumps seems to change... more rebound = more pop but more over the bars. More rebound also gives a bit more spring out of corners.
  14. #114
    Jun 2005
    for fast flowing trails with not too many roots/rocks i dial in quite a bit o LSR and C. Like you say, it gives more spring out of corners and more pop off jumps and you can pedal hard without wallowing.
    For DH I back off quite a bit all round as it keeps the shock plusher. I'm not entirely convinced that drops are a HS event though. I find by dialling in more LSC the shock stays composed off drops without sacrificing suppleness too much
  15. #115
    I'm about 15 clicks out from closed on LS (28 clicks total range) and half a turn back from fully open on HS.....feels good on most stuff.
  16. #116
    Hi! just two pictures of my ion st mounted with the ccdb:
    <a target='_blank' href='http://img9.imageshack.us/my.php?image=p4210004.jpg'><img src='http://img9.imageshack.us/img9/3038/p4210004.th.jpg' border='0'/><br>
    <a target='_blank' href='http://img7.imageshack.us/my.php?image=p4210003.jpg'><img src='http://img7.imageshack.us/img7/6536/p4210003.th.jpg' border='0'/><br>
    set-up:
    _400lbs spring
    _standart set-up for both hsc and hsr
    _3 clicks from full open for lsr
    _5 clicks from full close for lsc
    _it works very, very, very well...
  17. #117
    Hi tmseth,
    nice.....yours is the first Ion i've seen with a CCDB.....must be a great combination.
    Can you post full spec in the Ion database?
  18. #118
    ok! I'm on the way to complete it!
  19. #119
    Mar 2006
    Quote Originally Posted by tmseth
    Nice looking machine.. What pedals are those they look mint!
  20. #120
    brave machine pedals, similar to the bmw pedals
  21. #121
    guys - really dialled in the LSC setting now - LSR is just about right too - phenomenal climbing grip and control.
    however, i'm open almost all the way on HSC, standard HSR and suffering slight spiking on big square edgers.
    probably running 40% sag however - is this too much ? feels awesome everywhere other than mega square edged hits ?????
    HELP
  22. #122
    Mar 2006
    40% sag with no HSC (or preload?) - sounds like u need a heavier spring.
  23. #123
    i have a 400 fitted - i also have a 450 & 500. the 400 is just super plush and super controlled with awesome grip.
    the 450# would need even less HSC, no ?
    i also have a few turns of preload in there too..................
  24. #124
    guys - i'm delighted with my LS circuits.
    what sort of settings on the HS side have you selected ?
    on really fast big square edged hits i notice a wee bit of spiking...........?
  25. #125
    half to one turn back from open
  26. #126
    new CCDB tech screen from Cane Creek for any 'potential' customers out there : http://canecreek.com/tech-shocks
  27. #127
    Nov 2008
    has anyone got a quick set up guide for the CCDB, iv lost mine!!
  28. #128
    wound right up the LSC and backed right off the HSC.
    awesome trail sensitivity and a lovely taut feel with lush feedback.
    try it out fella's
  29. #129
    Mar 2006
    Interesting... might give that a bash.. what happens when you hit something big?
  30. #130
    karve - it works a treat with better control - but then the CCDB always feelt bottomless on the Helius AM/FR..........
  31. #131
    karve - let me know your thoughts - fwiw, i find the taut control preferable to mush and wallow, but then that's just my preference......
  32. #132
    I have one on order.
    I weigh 230 lbs could do with a starting setup for all adjustments.Just something to start me off in the right direction.
    lorni you are about the same as me,do me a favor and list your settings for me
  33. #133
    Jun 2005
    sam
    I'm @ 10lb lighter than you but i'd start with both HS circuits wide open and take it from there. dial the low speed circuits in just enough to prevent bobbing and to give the bike some support through berms etc. set your sag between 35 and 40%. I ran a 500lb spring at 40% sag on the FR
  34. #134
    Quote Originally Posted by dipper
    sam
    Thanks dipper.
    500lbs.Blimey thats low.
    Malcolm at CC sugested a 650lbs.That could be a bit high.I have a 600lbs ti spring from my avy might try that.
  35. #135
    Jun 2005
    yeah. you'll see what i mean when you start running it. i found it a bit harsh/spikey at 30% sag. 40% it's damn near spot on and there's no negative effect on pedalling either with the CCDB as you just need to dial in a bit more LS damping.
    I'm finding much the same with the AFR. I'm preffering it at 40% in the 185mm setting although it's early days and this may change once I try a lighter spring at 175. with the AFR I'm having to run some HSR whereas on the FR I ran that wide open
  36. #136
    Ok,
    Thanks mate.
    If i have to i might need to get a 550lbs spring to try.
  37. #137
    Should get my Double barrel tommorow.
    Shame the weather is bad.Think we have had 19 days now and every day it has rained.
  38. #138
    dry here, but cold. -2 deg C.
    what weight are you Norco and for what frame ?
    i'm on a 550# on my AM At the 150mm hole seting with 3 turns of preload @ 28% sag now.
  39. #139
    2008 FR and weigh a stealth like 235 lbs fully kitted.
    I have a 650 steel coming with it i have a 650 ti(nuke proof.heard it will fit) and a 600lb ti spring from an avalanche(1.5" internal) not sure if this will fit.
  40. #140
    Have been out today for an hour.
    Think i am still oversprung using a 600lbs spring(If it is) anyone with a 600lb and a 550lb i could borrow.
    I am only running 30% sag,not convinced that the 600lb ti is 600 i think its a 650lb.
  41. #141
    Waiting for a 600 lb spring from Cane creek
  42. #142
    droppoed off the LSC and preload and down to 500# spring for the fast dry summer conditions..................BEAUTIFUL !!!!!!!!!!!!!
  43. #143
    What weight are you TLR? What's your final/current settings?
  44. #144
    @ a1. i weigh 82kg's at 183cm.
    will measure setings later todaay as it's pouring doon after a dust-fest !
  45. #145
    anyone had their CCDB serviced in the UK yet ?
    mine is becoming wooden and has weeped a few drops of oil from the compression nuts........
    tia
  46. #146
    Dont suppose anyone has a 550lbs x 2.25 spring,steel or ti to fit a double barrel.
    Maybe, I'll check in the Garage tomorrow.
  48. #148
    mine needs a service - any recommendations ?
    im thinking STENDEC...............
  50. #150
    Quote Originally Posted by The_Lecht_Rocks
    Stendec replaced an adjuster on my CCDB that was on my Fr, after it somehow managed to make contact with a a flying rock.This was on the 5th ride,i wouldnt have bothered but it started to leak.
    Bloke was very helpful and only was charged for what he changed and labor.Same day turnaround.
    Think he was called Dave the man i spoke to.
  51. #151
    norcosam, sorry but the spare spring I have is 350 lbs.
  52. #152
    Ryates,Thanks for looking
  53. #153
    just found out from Malcolm that CCDB servicing in the UK is through OxShox.
    oxshox@btinternet.com Contact Tim Aust
  54. #154
    Seems they are part of K9. I hope they do a better job at servicing than their website would indicate, which is full of typo's.
  55. #155
    EVENTUALLY GOT MY CCDB CUSTOM TUNED !!!!!!!!!
    HERE’S THE INFO FROM STENDEC :
    • FLOWING PISTON AIR CHAMBER SET AT 25mm
    • INCREASED 4 SHIMS ON COMPRESSION STACK
    • HIGHER BLOW-OFF THRESHOLD DUE TO INCREASED OIL FLOW.
    • N2 PRESSURE SET AT 220PSI
    • THIS PROVIDES A MORE DYNAMIC FEELING SHOCK [MORE ACTIVE] WITH MORE POP AND MID STROKE STABILISATION.
    • LSC + 6 CLICKS OUT
    • HSC ¾ TURNS OUT
    • LSR + 8 CLICKS IN
    • HSR 1 TURN OUT
    • FITTED NEW BOTTOM OUT DAMPER [4mm NOT STD 8mm] GIVES MORE STROKE TRAVEL.
    • NEW O RING SEALS FITTED.
    • NEW 500# TI SPRING INSTALLED.
    FOR ANY MORE INFORMATION, CONTACT DAVE AT STENDEC-WORKS. http://www.stendec-works.com/
    Bear in mind that this is now custom tuned to my requirements and complaints about the standard shock and it's [in]action for my riding style [or lack thereof] !!!
  56. #156
    as further proof of STENDEC's ability :
    http://www.vitalmtb.com/videos/membe...46/MTBCUT-tv,6
  57. #157
    sapienti sat est
    Reputation: BikeBert's Avatar
    Ability? These are the basic skills.
    As for the CCDB: beware of Sendec:
    Quote Originally Posted by gpaevo
    Had mine for just over a year now and it's superb. Get one bought lol, just don't let Stendec touch it Angry. Either send it back to the US or get Dale at CRC to service it when the time comes.
    Quote Originally Posted by dlysexic
    whats wrong with sendec?
    Quote Originally Posted by Tom L
    Sent my cane creek to them a few months ago for a service, they ended up ruining the nitrogen recharge meaning it had to be sent to the US for a proper service, £100 down the drain absolute weapons...
    This! heard this to many times. Would ever let them touch my shock
    Quote Originally Posted by pwadjo
    Ditto, mate sent a pair of super limited edition Manitou Millenium triple clamps to stendec to be serviced and they were sent back as rigids. Seriously, they didn't ever compress again
    Quote Originally Posted by Turnerkid
    They did my Romic shock a few years back, 3 times it blew within 2 rides, not impressed
    Send your shock to Malcolm in the Us, it is def worth it!
    ____________________
    | Picasa | YouTube | Pinkbike |
  58. #158
    Tim Aust at oxshox.com are the official CCDB service agents in the UK. He does tuning as well. Has anybody got feedback on them?
  59. #159
    Jun 2005
    Quote Originally Posted by loamranger
    Is that new?
    When I contacted extra about warranty work they pointed me to stendec.
    www.gravity-sports.co.uk
    flash bikes for flash gits
  60. #160
    Is that new?
    Hi dipper
    Malcolm told me.
  61. #161
    Blimey.... mine feels superb so far anyway no complaints....
  62. #162
    Thanks for the heaDs up on oxshox too. I'll be speaking to TIM today...
  63. #163
    Reputation: thepimpmessiah's Avatar
    As posted elsewhere, TFTuned are now dealers and the official UK service centre for CCDB Shocks.
    I'm so tempted.
  64. #164
    CCDB on an AC - what spring?
    I have a 2010 AC with levers for 200 - 50 shock , the top hole is blanked off.
    I weigh 157lbs in my socks.
    I would like to fit a CCDB to the AC , when the bushes from Stendec arrive.
    If anyone has fitted one of these to an AC could they advise me on the spring (steel) I will need , as I think the current one at 450lb will be too strong.
    Cheers for any help.
    Jeff
  65. #165
    speak to dave at stendec - he has the ratios and link charachteristics for the AC and will advise accordingly......let me know how you get on
  66. #166
    Quote Originally Posted by jfb1 View Post
    Jeff
    mojo spring calculator here: :::: MOJO SUSPENSION ::::
    Good luck with the build
  67. #167
    Thanks both
    loamranger - thanks for the link , if I used it correctly I will need a 550lb spring , which surprised me , so will try what I have then experiment with different poundages as required.
    TLR - will give Dave a call tomorrow , also thanks for bringing him to my attention , I had him service the 2006 DHX5 air shock which is currently on the AC & as he put it "give it a bit more pop" . the ride is much improved , the shock now rides higher in it's travel , does not blow through the mid range & the propedal settings work.
    Thanks again both
    Jeff
  68. #168
    well the AC has gone , which leaves me with a CCDB & fox DHX5A,
    If anyone is interested in either email me at jeffbushi@yahoo.co.uk
    Cheers
    Jeff
  69. #169
    Looks like an awesome new communication platform for CCDB users: The Lounge. CANE CREEK marketing "directrice" Holly COLSEN speaks.
    <iframe src="http://videos.mtb-news.de/embed/player/23328" width="512" height="288" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe><p><a href="http://videos.mtb-news.de/videos/view/23328" target="_blank">Eurobike 2012 - Cane Creek</a> von <a href="http://videos.mtb-news.de/user/view/1" target="_blank">Thomas</a> - mehr <a href="http://videos.mtb-news.de/" target="_blank">Mountainbike-Videos</a></p>
    Furthermore worth viewing: CANE CREEK director of development Joshua COAPLEN speaks.
    <iframe src="http://videos.mtb-news.de/embed/player/23343" width="512" height="288" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe><p><a href="http://videos.mtb-news.de/videos/view/23343" target="_blank">CaneCreek DoubleBarrel - Funktionsweise</a> von <a href="http://videos.mtb-news.de/user/view/5865" target="_blank">Grinsekater</a> - mehr <a href="http://videos.mtb-news.de/" target="_blank">Mountainbike-Videos</a></p>
