Results 1 to 2 of 2
    Burgtec Offset Shock Hardware
    Anyone tried it or know if it will fit any Nicolai"s?
    Burgtec Titanium Offset Shock Hardware | Burgtec
    I haven't used these but I did undertake an experiment to see if altering my AM's geometry via a different shock shuttle would work.
    In essence, the shock shuttle I tried moved the shock forward 7mm, dropping the BB and reducing the HA by about 1.5 degrees.
    I compensated by fitting a shorter fork and running the bike in the third hole down for travel.
    What I found was geometry that worked really well but the spring rate of the shock got really progressive. It was like riding a slopestyle bike or something where the spring rate ramps up massively. I found I was loosing control and getting my feet blown off the pedals quite a bit.
    But that was a 7mm forward shift. These bushings do the same thing but only by I think about 3mm? That's going to reduce the HA by less than a degree I think, but don't quote me. BB will drop slightly as well.
    Of course all this depends on what bike you're thinking of putting them on.
  1. offset shock bushings
    By grantw9066 in forum Downhill - Freeride
    Last Post: 07-20-2011, 07:43 AM
  2. offset shock bushings
    By grantw9066 in forum Shocks and Suspension
    Last Post: 06-23-2011, 09:30 PM
  3. Prophet Rear Shock Mounting Hardware for Fox Shock
    By bdamschen in forum Cannondale
    Last Post: 03-26-2010, 10:19 AM
  4. Burgtec
    By -Insomnia- in forum Urban/DJ/Park
    Last Post: 06-14-2007, 04:01 PM
  5. 5th element mounting hardware? rear shock hardware?
    By schoolisbad1 in forum Shocks and Suspension
    Last Post: 10-16-2006, 03:38 PM
