    Reputation: mtb_baz's Avatar
    Mar 2006
    Bottom bracket recommendations for G-Boxx bikes
    I need a new bottom bracket for my G-Boxx nucleon thingy. I assume I'm stuck with ISIS at 100mm. Any recommendations? I've found a FSA Platinum Pro DH. Any good?
    Or is there a way of getting something more durable, like an external bottom bracket, there?
    Drink...sleep
    Reputation: Boozzz's Avatar
    Aug 2005
    If you're stuck with ISIS, maybe have a look at the SKF FR600 bottombracket (http://www.skf.com/portal/skf/home/i...17215&lang=en). They use rollerbearings on the driveside and they're far more durable than your average ISIS BB.
    Mar 2006
    Alas, they don't do 100mm ones, only 68 and 73mm
    Reputation: thepimpmessiah's Avatar
    I've got two RaceFace Signatures which I use in rotation. I get anywhere between 6 and 12 months from the replaceable bearings. Replacing the bearings is a rubbish job which is why having two is a good idea, not sure if they are available anymore, I've had mine for four years.
    I've never tried any of the others.
