Page 19 of 22 FirstFirst ... 91516171819202122 LastLast
Results 901 to 950 of 1083
Thread: BOS suspension
  1. #901
    I think I've got full travel back on my Devilles (not actually riden yet). I followed Mad Elk's advice and pulled up on the crown to extend to full length and then let all the air out and pumped up again, cycling every 3 bars up to 9 bar and then adjusted to ride pressure. Not in a hurry to try since I'm really liking the Idylles at the moment. Probably going to use the Devilles with a lighter 650b build I have in mind. Next, I'm going to get my Stoy retuned for my new frame to replace the DB air. I'm sceptical if the new BOS air forks are going to be as good as the old coil's, since switching from Devilles to Idylle I can really feel the difference.
  2. #902
    Executive User - UK
    Nov 2008
    @Tdmax: i wonder if the detergents in your bike wash have caused issues - you dnt use muc off or such thing do you? My seals are mint and I ride in all sorts of crap (Uk weather and all that).
  3. #903
    Executive User - UK
    Nov 2008
    Quote Originally Posted by loamranger View Post
    I have a couple of friends who have all jumped onto DH air Idylles from the coil versions and swear by them over the coil versions. Im likely going to try a set and a void next year, feel free to come have a go when they are here. Would be good to catchup again.
  4. #904
    Quote Originally Posted by vikingboy View Post
    If that's the case then I'm getting some as well. They won't be as reliable though? And they don't have 1 1/8 steerer which is an advantage when fitting to a 1.5 head tube because you can keep the front lower by using a ZS bottom cup. When is the SC air available?
  5. #905
    Mar 2011
    Hi Viking, i usually clean my bikes only by water, i use a drop of soap only on the frame.
    Usually i need only to remove dry dust, Rarely i ride on mud because here we have a lot of rocks and gravel.
    I use a motorbike soap but i always used it on all my bikes and motorbikes and this is the first time i have a problem.
    About lubricating stanchion i think it would be useful on wet condition, in my case i think that oil can attract dust. Am i right?
  6. #906
    How do you lube the stanchion? I try to keep it clean and avoid to wash with water/detergent but i've never lube it. After 8 months of abuse mine is getting a bit dry and lost the initial extra plush feeling, anyway is awesome. In the next month there's an enduro race, after that i plan to make a service.
  7. #907
    Executive User - UK
    Nov 2008
    Bos say not to use anything at all but I quite like a little spray of this stuff....and then wipe down so its not dripping and doesnt attract grime and crud. My seals are like new on both sets of forks I have (devilles and Idylles)
    Fork Juice
  8. #908
    Mar 2011
    Do you wash your forks only with water right?
    I usually do the same.
    Sometime i use teflonglide oil (protone suspensions special product).
  9. #909
    Quote Originally Posted by juan_manuel View Post
    Fork Juice spray or Stendec fork grease.
  10. #910
    Mar 2011
    I use Brunox Deo fork lube after rides
    also I recommend you to check the oil level in air leg -> I had the same issues (not feeling very plush) and after oil check (there was none!) the fork became amazing again
  11. #911
    Mar 2011
    Quote Originally Posted by thresh View Post
    How did you do it?
    I don't know how to open the fork
    on one leg there is a socked head scew, ok, but on the other?
    You need to remove knobs?
  12. #912
    For sure mine has little oil but i dont want to service or open if i dont have the dustwiper seals or other stuff thats needs to be replaced.
    I'll try to get that fork juice, looks delicious 😁
  13. #913
    Pilot, Viking,
    Like you guys I love the S**Toy on my 26" '011 AM.
    Having just got a VIP'r from Dipper, though, I have to say that's a hell of a lot easier to pedal. It's very smooth too, very grippy, good on roots. Of course I'm sureI can't expect it to hold up as well on big "Alpine" rocks as the Stoy, but right now in the woods it's giving me a far easier time pedalling up.
    I have quite a few BOS bits now so I really hope UK servicing works out with the Irish bunch.
    Man the mud is sticky here in Brighton, full of leaves too, really blocks the transmission big time. The woods are certainly looking beautiful though.
    Viking, I must come up to Swinley again when (if) it dries out a bit, riding your tracks was a great day out. Thanks again of the session.
    Neil
  14. #914
    Reputation: akdmonsters's Avatar
    I've got a Deville 170 and a Vip'r on my Helius AM, and they work very well!
    But i may use them a bit too hard
    For the moment, nothing goes wrong... It works exactly as i want!
  15. #915
    Jun 2010
    I'd be carefull with Brunox. I dont think BOS recommend this solution to their forks as it dissolves the grease from underneath the seals.
    Regarding the Mad Elk boys they are well known here in Dublin. Sound lads and very passionate riders. Good luck to them.
    Got my Deville of them last week and had a chat with them. They did the servicing training in France and I saw they had the BOS tools too.
    I thought my Lyriks were awesome but no - this is awesome. Ordered a Vipr too to as at the moment my bike rides like a racing horse shot in the arse - amazingly performing front bouncers + rear monarch RT3 trying to follow
  16. #916
    Fork Juice and Brunox
    Quote Originally Posted by lukaDH View Post
    Hia,
    Good to have your opinion of the Mad Elk guys, such a releif that we now have an English speaking Service centre.
    Enjoy your Deville, it's pretty tough, designed for Enduro, developed by monsieur Vouilloz I think, have you seen the vid. of him on Devilles. He rides pretty hard (smooth tho).
    Vouilloz testing the BOS Deville
    Mind you, if you like the Deville you might love the Idylle SC, fair bit more hardcore and even better than Deville in some ways, stiffer for sure, definitely has the same "family" feel.
    Mind you, so does VIP'r and S**Toy.
    Is Brunox similar to Fork Juice? BOS definitely dont want solvents near there but
    I think a silicon lube spray is ok, BOS manual says:
    "3.2 Cleaning your forks
    It is compulsory to clean your forks every time you use them, without waiting !
    Nothing’s worse for your fork’s seals than dry mud.
    It is very simple to clean your forks : wipe off the stanchion with a clean rag and then slightly lube the stanchion (with silicon based product). Use of degreaser is totally forbidden.
    On the same note do not power wash the forks! It will only push the mud inside the forks and get it stuck between the stanchion and the seals."
    Have fun
    Neil
  17. #917
    Jun 2010
    Quote Originally Posted by mudfish801 View Post
    Neil
    Deville are lighter than the Idylle and I needed 170mm max. For the rear I wanted to get the Void but no luck since they don't come in 200x57 sizes. I'd say Vipr will be a good match for the devilles and more balanced on uphills.
  18. #918
    Hi
    Does anyone have any experience of the vip'r clicking as it goes through its travel in the soft setting? It's fairly loud and pretty off putting when riding. The shock is new and had been back to France already but it's come back and still sounding a touch ropey. It's on a tracer 2.
  19. #919
    Quote Originally Posted by StressedComa View Post
    Hi
    It's "normal":
    <object height="480" width="853">
    <embed src="http://www.youtube.com/v/kePFecgCaBU?version=3&hl=fr_FR" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" height="480" width="853"></object>
    It depends of the setting. You can't change it.
  20. #920
    I never heard that
    Have you really carefully gone through the equalisation?
    Are you SURE it's the shock?
    Can you put the old one back on and not have the noise?
    If so, you then need to look at the shock mounting points [bushings] carefully.
    Could it be the bar, the seat, the seatpost??
    - I sometimes work in a bike shop and strange noises from bikes are the basis of much discussion. They can come from the weirdest places.
    Example - carbon bike, creaking rear dropouts - no - front mech band was the cause!
    Creaking suspension bushings? no - seat rails!
    Creaking crankset, no bar/stem interface.
    and on and on.
    It sometimes feels like the old VW ad :
    WWW DOT youtube.com/watch?v=JF-KJ5-KNQk
    n
    n
  21. #921
    Well... When we speak of strange sounds:
    <embed src="http://www.youtube.com/v/8Ozu_aREBFY?version=3&hl=fr_FR" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" height="480" width="853">
    My Deville doesn't work as it should </object>
  22. #922
    Reputation: qbert2000's Avatar
    Quote Originally Posted by akdmonsters View Post
    since 1 week ago???
  23. #923
    Quote Originally Posted by qbert2000 View Post
    since 1 week ago???
    No, since i fixed it on my bike: today. It's new!
  24. #924
    Mr. Knowitall
    Reputation: hssp's Avatar
    Sounds like low oil level. I had the same problems. Seems they do not fill too well in the factory. It IS a pain to fill properly, and it takes time.
  25. #925
    You definitely need to balance the chambers, I posted instructions above. It doesn't sound right though. Please let us know how it turns out
    Neil
  26. #926
    For Info: It's my third Deville...
    I alredy balanced the chambers twice and it is still doing the same noise...
    So, i called directly Bos this morning and they sent me a new one for saturday.
    I hope that It will arrive on time...
    And for info, this sound could also come from a spring fixed in a wrong place
  27. #927
  28. #928
    Ah, right,
    You like them then I guess.
    Thats good service from BOS
    hope it does arrive fast
    Did you have to speak French to them?
    I didnt realise it had any springs inside.
    N
  29. #929
    Ah, right,
    N
    Well, i'm French and i live near Paris.
    So, my new deville arrived today, just 24h exactly after the sending
    And It works perfectly.
    I have to thank my shop and Bos for this reactivity.
  30. #930
    Reputation: fumanchu's Avatar
    new distributor for the uk - surf sales .com - no mention on servicing though that i can see ? - good news for uk owners hopefully
  31. #931
    Surf Sales / BOS servicing
    Quote Originally Posted by fumanchu View Post
    It is indeed -
    I see this now:
    On movember 26th Surf Sales signed a new distribution contract with what we regard as the finest mountain bike suspension engineered today, to complement it we'll be opening a service centre with full back up and we'll be offering the suspension as an upgrade to Transition bikes, notably The Bandit & Covert Carbon deville.
    Our service centre staff training commences on December 17th and stock is expected by the middle of the month, certainly in enough time to commence 2013 with products and service capability.
  32. #932
    chilliinleeds
    Jun 2010
    That's great to know, thanks for the reply. Relieved that BOS finally have a reliable partner in the uk.
  33. #933
    Dave at Stendec advertises on his site that he servives Bos suspension.
  34. #934
    That should have read" services" Bos in the UK.
  35. #935
    Quote Originally Posted by chillijo1 View Post
    To be fair to R53 I think they themselves were a reliable company. Roger certainly knows his stuff with suspension.
    I hope that the size of Surf Sales will help them hold stock of parts aswell as components.
  36. #936
    R53 are very good,I think its more to do with BOS not supporting them with parts.
  37. #937
    Jan 2013
    Hi bikers,
    Stefan and Michal here, we thought that as custom bike specialists/Bos suspension authorized service center we want to make a little bit more special about our service as bike shop. We are fully equipped with Bos manufactured tools and spare parts. We offer you our helping hand. If there are any queries about Bos mtb suspension or any other products feel free to contact us.
  38. #938
    Quote Originally Posted by madelkcycles.com View Post
    Hi bikers,
    Good to know that theres still some service/backup..
    Will they be releasing any 650b/27.5" Forks???
  39. #939
    Jun 2010
    Service and info of Bos Deville and Vip'r
    Hello Guys,
    Where is you bike shop? I would like to know if is possible to modify the travel of my Deville 160mm TRC to 170mm? I would like to do this mod and also service my fork and shock. Since four months ago I have tried to contact BOS directly without any result, and my fork and shock need service.
    Thank you for your attention and time, waiting for your reply.
    Regards,
    Hi bikers,
  40. #940
    Jan 2013
    Quote Originally Posted by norcosam View Post
    What we know there is new All-mountain platform being released in spring time. We haven't heard about bos 650b forks yet. But actual bos forks have enough clearance for 650b wheel, claimed.
  41. #941
    Jan 2013
    Quote Originally Posted by Carlos Andres Velez View Post
    Hello Guys,
    Regards,
    Hi there,
    We are located in Dublin, Ireland.
    According to conversion question I double check with guys in France. What I can see you need to re-built internals witch gonna cost more then just "a spacer" . But I will come back to you with definite answer asap.
    About the servicing your suspension just pack it with service form filled out. The form can be found at
    Contact us - Mad Elk Cycles and follow instructions there. it takes up to 7 working days to get back your fork/shock when in Europe.
  42. #942
    Oct 2010
    Second ride in my 140 Devills and they have packed down and wont rise, i have added air and tried to equalise but even with 8bar they wont go higher than 80mm ish,
    When all the air is let out they suck right down, crown to seals, has anyone any advice or tips please before i send them off and it costs me money.
    Sorry if this has been covered but i could not see it.
  43. #943
    Quote Originally Posted by godzilla1 View Post
    Hi godzilla, try pulling up on the crown while holding down on the axle so that they extend to full travel and then equalise in small steps up to 9 bar. Then finally reduce to working pressure. Let us know how you get on.
  44. #944
    Oct 2010
    I tried this but the forks are very powerful, when the button on the shock pump is pressed they suck down and i cant hold them apart.
  45. #945
    ok, try equalising in reverse by reducing the pressure bit by bit. Seems like pressure build up in the negative chamber? You might want to ring Mad Elks and discuss the problem with them.
    Mad Elk Cycles - Bos susspension authorized distributors,warranty & service center
  46. #946
    Jan 2013
    Add the high air pressure back to fork. While proceeding the equalization with continuous releasing of the air little by little it should bring the pressure low in negative chamber. As it's explained above pressure built in negative chamber needs to be equalized back with positive one. It's worth to have a friend handy who can help you pull fork apart. See how that works and let us know
  47. #947
    Jan 2013
    Hello Guys,
    Regards,
    here is update regarding to conversion from 160TRC to 170:
    1. new air chamber unit(piston,shaft,support)
    2. new cap to replace TRC one
    3. change height of lower slide bushes( replacing all bushes + seals to complete a job)
    4. modify cartridge or buy new one.
    The whole job would cost you quite a lot. I recommend you to buy a new one.
    Stefan
  48. #948
    Love my BOS Suuspension and have 2 forks + 2 shocks unfortunately Surf Sales apparently still don't have the service kit and are not hearing back from BOS.
    BOS themselves didn't reply to my email [in French] requesting service 9 days ago.
    So, I'm sending my Deville and S**Toy to the very friendly and helpful James at J-Tech
    j-techsuspension.co.uk - Home - J-TECH Mountain Bike MTB Suspension Service, Tuning, Sales and Data Logging
    Vikingboy said "Just Believe" [quoting Jedi] he's right. I am doing.
  49. #949
    Hi mudfish, that's not good news that Surf are not up and running, probably not their fault. Let us know how you get on with J Tech. I need a retune on my Stoy and was thinking of asking Mad Elks to do the work.
  50. #950
    Hi Loam-er
    yep, I'll post back, he was busy, so in a couple of weeks.
    neil
