Results 1 to 41 of 41
    "Its All Good"
    Reputation: Whafe's Avatar
    Anyone ripping it up on an ION16 27.5?
    Hi All
    Any Nicolai peeps got an ION16 27.5 in your quiver...
    Very keen to hear your thoughts.
    Working through the task of what to get bike wise next.....
    No. But I've just ordered this you might be interested. Depends how brave you are. I've done a lot of testing recently of a Mondraker XR Fwd Geometry that I borrowed and adapted to this geo but its the 26'..Its a long story how I came to it and why not the 27.5..
    I am totally addicted to the front end steering feel and grip, it has me giggling like a loonatic everytime I go out on it, Ive been alternating between that and the 29 trying to figure stuff out whats great whats less so.
    My experiments show the 26 to be as quick as my 29 descending and in this setup it is as stable even when hitting obstacles but more easily deflected off line, however the wheelbase keeps it controllable...
    Closest thing I can describe the feel is imagine riding it is like watching an old school Impreza WRC car, as long as the front is pointing in the right direction don't worry about anything else :-)
    The grip is as good as my 29, I feel the front has even more but the steering feel, oh, <eyes go dreamy> it's like having your brain hard wired to the front contact patch...which could account for the impression of grip.
    Climbing is great (its so long) although it doesn't pedal anywhere near as well as my 29. Essentially it's a different solution to offer to what an AM 29 offers, stability at speed and oodles of grip with a very natural (to me) position. If you've ridden motorbikes it feels completely normal.
    It's a pity Mondraker have bottled it this year and made all of them shorter relative to ST and compromised the design to appeal to more people, I presume due to limited acceptance of the models and difficulty of estimating production numbers for an Asian made frame.
    Chris Porter, owner of Mojo a Suspension in the UK has had two made now once he found out a Nicolai did custom, ironically as a result of the Ion15 project...but Chris is very extreme and has taken the concept to the max with very much a DH focus and Łber slack HA.
    It probably doesn't help Whafe but something to think about, I've taken the plunge in a similar way to my ion15, much experimentation with geo before committing..in many ways the Ion29 has enabled me to get more skills at higher speeds with a safety net, I kinda want to turn off the electronics now and see if I can still keep control ;-)
    I'm 99% certain that with this bike I'll have the descending speed and stability of my 29 but with a bike that is more active in the air, faster to turn (due to only 10mm stem, even with 66deg HA steering is instant with so little handlebar movement needed) and to pick up (side to side due to lower gyroscopic effect of smaller wheel/tyre). It won't pedal as efficiently or smooth out the small ripples quite as well I'm sure but as mentioned, I'm addicted to the front end.
    Forward Geo makes no sense on a 29 as the stabiity is derived in a different way it would make an unweildy beast but since 27.5 is so close in diameter to 26" it does make sense, well to me anyway, I've been chatting to a Journo I know who has been long term testing the Mondraker Foxy 27.5 in XL he feels t feels more cohesive than the 26" due to the slightly smoother feel of the 27.5s.
    Going to go with team colours for this one...wk 24...
    Aka chainline...
    "Its All Good"
    Looks very interesting indeed, long wheel base, fast and stable, nice and slack... What does it climb like?
    Mmmmm, food for thought
    Well it climbs excellently and again belies its head angle, as the front centre is so long. That's the measurement to focus on, the Chainstays are short as, 431mm on 27.5 wheels but the front centre is 798mm/ RC 431mm Compare that to my Ion29 at FC 737mm/ RC 449mm. Wheelbase of ion is 1187mm.
    As such you just don't get wheel lift on the steep stuff. As I said response feels instant as the stem is so short, not sure what you run on your triple clamp but Moto triple clamps have little if any 'stem'.
    The 26" I've been using is longer than my 29 at 1200mm but I can't y as I've noticed any issues even on 180 switchback climbs and descents. The overall width is shorter as the wheels are smaller obviously, the 27.5 is about the same as my 29 end to end with the smaller wheels.
    Aka chainline...
    "Its All Good"
    The stem on my Dorado's on the Monster Truck is short as... Am used to almost no stem...
    Mmmm, what would I change on the ION16 27.5.... Would for sure run a super short stem... Am used to that....
    Just wondering if it might be to much bike.......... Mmmmmm
    Too much bike? Well I can't answer that but if that's a thought then might I suggest 29 is still the right wheel size. I think I said this last time, what do you want it for?
    My ONLY reason for using the smaller wheel is to be able to use the forward geometry and 10mm stem, I think I need the longer travel to compensate for the wheel size. I have done quite a lot of messing around with the fwd geometry concept on a 29 platform but the numbers just don't make sense with a FS. It's ok with a hardtail but you don't have the compromises of the rear wheel path and chainstays to deal with. In fact it just doesn't make sense, the stability and rollover is already there because of the wheels...
    The Ion15 at 145mm travel and 150/160mm front is a fantastic trail bike that I've used for DH tracks and everything in between, it's a genuine do it all bike as I've said before.
    This one is much more of an AM focused Shredder and I would say the 16 is too in reality. Happiest when flat out will cover ground ok and climb well. A bike tester friend of mine described the differences beautifully he said "on a date a with a 27.5", not as chatty as 26" and doesn't have the legs of the 29 but still nice."
    Perhaps the AC 27.5 would be a better fit if you have a desire for the smaller wheel size but I wouldn't be sucked in by the koolaid. 27.5 is very close to 26" not only in actual diameter but in ride feel according to my objective riding buddies, just a teeny bit smoother over small/mid size obstacles. I think you have to ask yourself why you went 29 in the first place and what qualities about that you like, what you don't, only then can you decide what compromise to make.
    Ultimately the 27.5 is only 25mm bigger diameter than 26" in total (559 vs 584) so 12mm radius. The 29" is near on 40mm bigger than a 27.5 (584 vs 622) so nearly twice as big a difference in terms of rollover ability in comparison.
    For me I believe in the bike for the job the Ion15 is more versatile than any other bike in the range in my opinion. The Ion would do what your monster Truck and your AC do without a doubt, it covers ground efficiently, handles brilliantly, descends like its on rails, it is just a fantastic all round bike, which is what I wanted. A normal rider on the 15 will be faster than the same rider on an equivalent tweener wheel in almost any terrain I would wager, who would have more fun would depend on what they like in a bike.
    What is the stem on your a Dorado? If it's 30mm or similar, running 10mm makes a big difference in response and how much bar movement translates into wheel movement.
    Aka chainline...
    Reputation: Karve's Avatar
    Mar 2006
    Het the_piolet
    are you building a version of this
    Randoms - Core Bike 2014 - Pinkbike
    see last article on that page
    www.essexhertsmtb.co.uk - Mountain Biking near London in the UK
    Hi Karve, yes. That bike came about as a result of the publicity of the Ion29 I built I understand..a friend of mine mentioned it and Nicolai's willingness to do custom FS.
    Chris Porter of Mojo has some very focused ideas on what works for him and he agreed with the Forward Geometry Concept developed by Ceser Rojo and Fabien Barel. But he couldn't get his interpretation in a production frame.
    He found out about Nicolai and they built that for him. It is much longer in the TT than even a long Forward Geometry bike but his idea was also to make the chainstays long too..
    He has subsequently had a second one built that has even longer TT and Chainstays. Chris wants to go as fast as possible on super steep terrain.
    I want to keep the short chainstays but increase the front centre to use the 10mm stem as I find the steering so accurate and responsive and the feeling from the front tyre so good. This bike I propose is lengthened by 50mm in the TT compared to my Ion29.
    So my bike is a cross between the Mondraker Dune and Foxy bikes, changed to suit my size but also preference for a long TT anyway, also it is lower, slightly slacker with a steeper ST than the Dune and of course it's a Nicolai.
    Aka chainline...
    The bike above is the second frame built.
    Aka chainline...
    Whafe what is the stem on the Monster Truck, even most MTB triple clamp stems aren't that short?
    Aka chainline...
    Have 220 miles on the Ion 16 650b..
    Had an AC 650b before.
    IMO Ion climbs better,descends better and is a lot stiffer than my old AC..
    I am running a 50mm stem but think maybe a 40 would be nicer.
    160mm Pikes and Monarch Plus rear shock work amazing together.
    29lbs for a complete bike with 150mm reverb running a heavy set of Hope hoops and Hans Dampf 2.35 Trail star up front and a Conti Trail King out back..
    Feb 2012
    Dang Norcosam, now you make me want one! How high is your BB? Post some pics!
    Norcosam, and very nice it looks too.
    Aka chainline...
    I am running mine on the slack and low position.It has quite a long wheelbase aswell,This seems to make it very stable at high speeds.
    The bb is at -15mm,The Pikes run high in the travel so no pedal strike issues.
    Will be getting a set of wider rims soon,and hope to lighten the wheelset up by a few hundred grams
    My Ion 16 650b should be delivered sometime this week (15). But no sign of it yet. My wife is getting annoyed with the big pile of bike bits on the kitchen table!
    Feb 2012
    Nice bike, thank you for posting it!
    Oct 2013
    These are the teaser shots Ive been sent of my new frame! Its currently still with Dipper atm but I'm hoping to pick it up soon!
    I can't wait!!
    Anyone ripping it up on an ION16 27.5?-image.jpgAnyone ripping it up on an ION16 27.5?-image.jpg
    Wish I had some shots of mine. Still no sign of it.
    Yours looks really nice!
    "Its All Good"
    Great shots
    My wife is going to murder me if the frame doesn't make an appearance soon. She's so fed up of the kitchen table being full of bike parts and me randomly spinning wheels at dinner!
    Was in production week 15 so hopefully I can have a little more patience as it must be due soon!
    BALLS! Just heard my frame will be delayed another month as Nicolai are having trouble with their new anodiser and the frame needs to be redone. Hope the quality is still good when it finally does arrive as being anodised and stripped and then redone cant be too good for it!
    So sad!
    That sucks a big fat hairy one. I've got anodised back end on order so hope it gets sorted.
    Can't imagine it will affect quality it's a microns thick absorption. Remove more material with wire wool on a raw frame just cleaning it up.
    If also hope they wouldn't let you have it if it wasn't up to standard. They have decided it's better to ask you to wait then send you something they thinks unacceptable. Frustrating tho it must be.
    Aka chainline...
    Reputation: alex84's Avatar
    May 2014
    Hi guys, interesting threadÖcan I burgle a bit of your time and ask about mondraker, which it sounds like some of you have experience with. Iím really keen on getting a foxy but test riding isnít really an option and Iím stuck on the sizing; Iím 6í2Ē and, having measured my current bike, it looks as though Iíd suit an XL but Iím a bit concerned it will be massive? any advice? cheers
    Ok Alex if you look at the other thread where I have ordered a Forward geometry Nicolai you will see my bike will have an ETT of 661mm. The XL 27.5 Foxy XR if it's a 2014 you are talking about is 667mm. I am under 5'11". 1.78m tall.
    The straight answer is no, it won't feel massive at all not to ride. It will look long, and is but that's different.
    I'll post some links here to Chris Porters writings but he is 6'1" and his ETT is now 700mm, of course with a 10mm stem.
    There is also some sizing discussion on there.
    Aka chainline...
    May 2014
    cheers pilot, i want to use a 30mm stem as opposed to the 10, also what did your journo mate think of the xl and how big is he? could he still throw it around or did he ever comment on it being cumbersome?! thanks for your help
    Ok. If you use 30mm you have to decide. Chris would say its definitely not massive. So would I.
    You are some 90mm taller than me so I would expect you to want something like a 690-700mm ETT. On a conventional bike you'd have a 630mm-640mm ETT and 50mm -60mm stem?
    Again have a look at the discussion on the forward geo thread with loamranger.
    You have an advantage too, if it's a touch too long you have seat adjustment, but also scope to use the 20mm stem etc...
    My journo friend didn't think it was cumbersome in any way, nor does Chris and he's fast.
    Journo went on to have a custom intense. Check out the reviews of the Foxy on bikeradar by Doddy, it's an XL 27.5.
    I feel it's anything but cumbersome, the super short stem with wide bar makes response so direct and I never noticed the 1200mm wheelbase on my test rig.
    Chris bike
    Chris Porter's custom Nicolai Ion 16 ? super bike - BikeRadar
    His theories (I don't agree with all of them..)
    Size matters: why we?re all riding bikes that are too small - MBR
    Bike detail
    Interview: Chris Porter, on his custom Nicolai Ion 16 - BikeRadar
    Aka chainline...
    Frames finally arrived today! Really happy with it.
    Oct 2013
    nice! did you get it from Moonglu by any chance?
    Yup! Had a nice day up there today.
    Oct 2013
    Yeah, i saw it on their FB page, your gonna love it, they're awesome bikes, just done two full days riding on mine and i can't fault it in any way!
    Love that colour and wanted the Mavic wheels but was set on the blue frame!
    First ride today and I'm pretty blown away, suspension was all on base tune settings but it felt great. Surprised how well it climbs too!
    Just need to find some frame protection that works with the anodised finish, if anyone has any ideas it would be appreciated!
    I had a good hard think about both the ano blue and the yellow..so hard the colour...
    Heli tape works fine with the ano, but obviously creates a slightly different finish however nothing will have no effect.
    I used heli on my blac ano frames without any issues.
    Aka chainline...
    I have an Ano Titanium Grey Ion 16 27.5" incoming. I too am looking at tape options. I was in touch with the chap who runs "invisframe" in the UK. He was not overly confident that the invisiframe product would bond to the Ano finish too well.
    I have arranged to try some invisframe on the Ion when it arrives before I build it.
    Will let you know how I get on.
    v0n
    v0n is offline
    May 2013
    I've finally been able to put my ion16 27.5 together. Thing rips. Needs a lil time getting use to but already smashing my old records.
    Anyone ripping it up on an ION16 27.5?-imageuploadedbytapatalk1442243554.612570.jpgAnyone ripping it up on an ION16 27.5?-imageuploadedbytapatalk1442243589.046813.jpgAnyone ripping it up on an ION16 27.5?-imageuploadedbytapatalk1442243637.535673.jpgAnyone ripping it up on an ION16 27.5?-imageuploadedbytapatalk1442243686.360330.jpgAnyone ripping it up on an ION16 27.5?-imageuploadedbytapatalk1442243711.171937.jpgAnyone ripping it up on an ION16 27.5?-imageuploadedbytapatalk1442243735.084306.jpg
    v0n
    v0n is offline
    May 2013
    https://youtu.be/-LhTNAdznAs Ion 16 27.5 on snow summit party wave. 🏽️
    sweeet.
    Aka chainline...
    v0n
    v0n is offline
    May 2013
    I would really like to throw a leg over the geo
  1. RIPping a log
    By Jisch in forum Niner Bikes
    Last Post: 12-14-2013, 09:01 AM
  2. Best fork for a 650b ion16
    By ButchSchlong in forum Nicolai
    Last Post: 10-10-2013, 12:18 PM
  3. Ripping Chilis
    By G-AIR in forum Knolly
    Last Post: 05-22-2013, 11:28 AM
  4. AM vs ION16
    By hmpoliveira in forum Nicolai
    Last Post: 05-20-2013, 10:00 PM
  5. Replies: 10
    Last Post: 04-04-2013, 03:52 PM
