Results 1 to 16 of 16
    AM frame and AFR rear triangle
    I'm about to get a new Nicolai AM frame (26"), possibly with an AFR rear triangle. What are the impressions of Nicolai AM/AFR owners? Any recommendations?
    Then you'll basically get the good old Helius FR, that was exactly using the same Tubeset as the Helius AFR with the Fat chainstays plus a stronger downtube. This results in maybe 300 Gramms more weight.
    If you do a lot of high drops and park action this might be the way to go. But I had the FR last year and switched to tha AM since the FR was way overbuilt for me.
    It will be a tank of an AM for sure!
    Reputation: dipper's Avatar
    Jun 2005
    I think you'd be as well just getting an afr. I've got all 3 here. Am, fr and afr. You'd be surprised how similar they all are. One of the things I really like about the afr is the offset seat tube. The riding position is in the right place but put the seat down and it moves forward and well out of the way.
    The afr is on 180mm forks and the other 2 are on 170mm. Ha's are all identical(measured scientifically by lining them in front of each other and eyeballing the fork legs). Fr and am have the same bb height(I could have sworn the fr's was higher). The afr's is @ 5mm lower. Seat tube on the fr is slacker than the am so needs the saddle a bit further forward for climbing.
    Am weighs 35lb, fr 34 and afr 36
    All of the above are available for sale as well
    www.gravity-sports.co.uk
    flash bikes for flash gits
    Reputation: Karve's Avatar
    Mar 2006
    Quote Originally Posted by hmpoliveira View Post
    Why out of interest?
    www.essexhertsmtb.co.uk - Mountain Biking near London in the UK
    "Its All Good"
    Reputation: Whafe's Avatar
    AM Front Tri, AFR Rear.......
    Here you go, in adult sized wheels
    Whafe, what are, for you, the main benefits of having the AFR rear? What about climbing?
    Quote Originally Posted by dipper View Post
    AM will be more suitable for my riding... I was just wondering about the benefits of having a AFR rear!?
    Jun 2005
    Listen!
    Quote Originally Posted by Whafe View Post
    Whafe. That's not technically an afr rear. Looks like AM chain stays. Front tri is afr style
    "Its All Good"
    It is great for climbing.
    The AFR rear allows my adult sized wheels to get more travel.
    Dipper,it is an AFR rear built with AM tubing.
    Me love it though, great bike. You will all mature to a 29er at some stage
    Sent from my HTC Sensation Z710a using Tapatalk
    What benefits are you looking for. I don't see what your trying to achieve
    I was just wondering what an AFR rear could bring to the AM frame since there quite some people using it.
    Jun 2005
    Whafe. Not meaning to be pedantic but what's 'afr' about the rear? Looks standard am to me(albeit in 29er form). The front however is very obviously afr in style.
    "Its All Good"
    No, good call, pedantic is all good. I was meaning the area of above the cranks, or the front der tower area... This enable the rear stays to be longer, but a slacker seat tube. I feel this is something that really gives the AM29er an advantage in all things 29ers... Shorter chainstays and more travel = whole lotta great riding....
    Well tbh not much, the longer chainstays means you can have more travel/clearance before your tire hits the seattube. Whafes is the only am that I know uses it, though that does not mean that they do not exist. He only uses it to gain more clearance to run a funny size wheel
    Well tbh not much, the longer chainstays means you can have more travel/clearance before your tire hits the seattube. Whafes is the only am that I know uses it, though that does not mean that they do not exist. He only uses it to gain more clearance to run a funny size wheel.
    What is more common is running an afr down tube on an am which means you can run longer forks
    Jun 2005
    ah i see whafe! just crossed wires then.
    hmpoliveira
    as per ian, i dont know of anyone(on here anyway!) running the setup whafe has and again he only needs it to run big travel with 29" wheels.
    do you mean the offset ST of the AFR or do you mean an AFR rear as in the beefier chainstays from?
  1. Fly 07 Rear Triangle-Frame
    By matt45 in forum Foes
    Last Post: 05-06-2010, 06:44 AM
  2. M3 rear triangle onto Ss1 frame
    By E_1 in forum Intense
    Last Post: 04-07-2010, 11:41 PM
  3. Rear Triangle for a Sugar 1 frame
    By kvojr in forum Gary Fisher
    Last Post: 04-06-2010, 03:16 PM
