Results 1 to 7 of 7
    AFR w/Fox 180's - pics from the blog
    A couple of nice shots of an Ano orange AFR on the blog with the new Fox 36's @ 180mm
    http://1.bp.blogspot.com/_ejwj642Qbx...0/IMG_2162.jpg
    http://1.bp.blogspot.com/_ejwj642Qbx...0/IMG_2159.jpg
    Nice except that it's an AM not an AFR. It's on the AM database on here and IIRC it has a strengthened downtube so that it can be used with 180mm forks and still be warrantied. The custom tube didn't seem to add much weight either, I thnk maybe 100g or so?
    Oops - I see now. Which begs the question, if one want's to run a 180mm fork why not get an AFR in the first place...? Don't imagine there would be much weight saving between that custom AM and an AFR with that build, or at least not so much that it'd make much difference in real life use?
    Still nice looking bike though.
    steep fast and loose :)
    i was initially stunned by the ano orange / green / red, but must say that the red now looks best.
    the orange looks like metallic p1$$......
    Reputation: rpm100's Avatar
    TLR its unlike you to change your mind.
    Can't imagine why you would run the bike with no bash ring on.
    a tight kick sound
    Reputation: boone's Avatar
    If I remember correctly this thing has like 7 inches of rear travel also! I like...A LOT!!
