Results 1 to 3 of 3
    AC29er: 142mm rear axle?
    Just wondering, if I remember correctly I read a review on the AC29er around summer 2012. The author claimed that the 135mm rear axle of his test bike would be replaced by 142mm in the final bike setup. However, I donīt see this option for the current 2013 model. Anybody knows if there is a plan to give a 142mm rear dropout for the 2014 model?
    Quote Originally Posted by Wilhelm6 View Post
    You lucky man! By way of thanks for your brave waiting you have now the chance to order the all-new for 2013 PM rear and 142x12mm through-axle standard upgrades for your Helius AC PINION, formerly seen already at Eurobike 2012 (Ion 16). The overall surcharge is € 100.00. Those upgrades were unveiled at 2013 Lake Garda Bike Festival (Trentino, IT).
    Quote Originally Posted by crank1979 View Post
    I enquired about this when I first ordered and was told "The Helius AC Pinion comes with 135x12mm by default, but we can tailor the rear end to 142mm. I would not recommend that, because this would cause 300€ upcharge and you donīt have any advantage out of it."
    It would have made wheel choices a little different. At least I know I can change it in the future if I decide to go that way.
    My AC 650b frame is running 142x12mm with the new style post mount.
    Check out my Thread,theres a photo
  1. SB95c 142mm axle options?
    By Just J in forum Yeti
    Last Post: 06-11-2013, 08:46 AM
  2. Problem with syntace x12 142mm rear axle
    By cridom in forum General Discussion
    Last Post: 03-25-2013, 06:35 PM
  3. 142mm rear axle convert to 135 QR?
    By WVJon75 in forum 29er Components
    Last Post: 12-03-2012, 02:27 PM
  4. Hardtail that takes 142mm rear axle.
    By weedkilla1 in forum 29er Bikes
    Last Post: 03-01-2012, 08:53 AM
  5. Syntace axle with 12 x 142mm chip kit
    By soderblom in forum Yeti
    Last Post: 01-02-2012, 08:43 AM
