Results 1 to 13 of 13
    Upset AC weight !??!?!
    I just got my Helius AC in S size but noticed that weighs 2,8 Kg (about 200 gm more then the M size as described on Nicolai's website). Any similar experiences??
    Is that with or without the shock.And have you any options that would add weight?
    Quote Originally Posted by norcosam
    There is no shock and no options.
    ... only an S size Helius AC
    Dec 2008
    the color is anodized?
    Quote Originally Posted by 20lt
    Yes, is black anodized and top rear triangle in white. Is that heavier???
    Drink...sleep
    Reputation: Boozzz's Avatar
    Aug 2005
    Paint is heaver than anodized, but I doubt just a painted rear triangle would add over 200g in weight over a non-painted one. Seems weight on the website just is a bit off.
    Reputation: rpm100's Avatar
    Are there holes in the chain stays? As perhaps the weights were done when the original AC came out which had holes in the chain stays like the AM?
    Yes, indeed. It has 2 holes in the chain stays! I don't see the point. The S size should be lighter then a M size...
    Or maybe your scales are out by 7.6%?
    Quote Originally Posted by geetee1972
    That I have no idea... I have ordered a normal S size Helius AC... they say that due to the fact that the frame is hand made, it can happen.... but it should not happen, I think!!
    I can understand it must be disappointing to find that it weighs something other than you anticipated. But I'd also take comfort from the fact that weighing scales are often inaccurate and to be out by 7.6% would not be at all unlikely.
    The best way to decide how you feel about it is to build the bike up and see where you get to with the weight then. 200g is basically one mid weight inner tube, so in the grand scheme of your bike build, it won't count for very much.
    And besides, you've got a fabulously made bike that you are going to love once it's built up. It will happily weigh 28lbs or less without too much strain on the wallet and it will track like a cuise missle. Get some pics up and let us see it once you're done.
    A friend of mine rides a small Nomad. I used to have a large. Same build more or less. His weighed a ton more than mine (carpark lifting test, no scales). Never did figure out why, but made no odds to his enjoyment of the ride.
    I must say, putting a frame on the scales wouldn't be the first thing I would think to do when I got it out the box. As Geetee says, you will doubtless be stoked when it is built up. BTW, I have an AC frame waiting to build - I won't be weighing it either!
    Thanks for your supoport guys!!!
    But indeed... I just love this frame!! Still waiting ofr building up the wheels
    Photos are coming soon!
