Results 1 to 9 of 9
    X-Fusion Service
    What shops in the Albuquerque/Santa Fe are service X-Fusion forks?
    Reputation: Fuglio's Avatar
    Bike works has always done a great job on any fork Ive taken there
    10-4. That's probably the only shop in ABQ I haven't went in yet. I'll have to check them out. Thanks
    I blew through the lockout a while back and now the lockout doesn't work at all... It's a '12 Velvet. I took it apart and looked at the internals, but didn't see anything bent or out of place. I'm not real familiar with MTB forks. I used to play around with the valving on my dirtbikes when I used to race, so I'm not completely suspension dumb. Just not familiar with lockouts and how they work...
    Hmmm. We may need to tag team this thing. I'm kinda curious how the lockout works in conjunction with the damper. Shoot me a PM if you're up for it.
    I'll be calling in a few from an 850 area code #.
    Lol keep us up dated, this is gonna be good.
    but i want to ride now
    Reputation: aldousfilcher's Avatar
    Jan 2011
    In most forks the oil cycles through the damper side unimpeded. The exception to this is closed systems like Fox's FIT or Rock Shox's Charger damper, where the oil cycles within a flexible bladder. In either case (open or closed) a lockout works by disallowing oil to cycle within the confines of the system. Essentially, when the lockout is closed (locked) a port is closed, which no longer allows oil to cycle. I have not personally disassembled a Velvet, but we (and by we, I mean fellow Fat Tire Cycles techs) have rebuilt a couple in the past. My guess is that something stripped or failed in some way, allowing the port to open, and probably compromising any real damping control. Long story short, in may require a new lockout assembly.
    sweet sweet trails
    Quote Originally Posted by Fuglio II View Post
    @ fug, it probably can't be fixed with an o-ring from AutoZone.
    First your gonna need to locate the forks ass, so you can blow smoke up it.
  1. X-fusion Trace RL2 full service
    By Kung Stalle in forum Shocks and Suspension
    Last Post: 09-21-2013, 11:29 AM
  2. Help with X-Fusion Lower Service
    By megamax in forum Shocks and Suspension
    Last Post: 07-24-2012, 06:51 AM
  3. X-Fusion Damper Service Instructions
    By kiwimtber in forum Shocks and Suspension
    Last Post: 05-12-2012, 10:21 AM
  4. X-Fusion customer service?
    By outdoorlogic in forum All Mountain
    Last Post: 04-06-2011, 09:01 AM
  5. X-fusion service guides?
    By y0bailey in forum Shocks and Suspension
    Last Post: 02-21-2011, 05:02 PM
