Ok so I picked up beautiful SA Classic last summer and tried to build it up. Coming from the 29er work I thought I was used to being high up on the bike, boy was I wrong.
I'd like to reduce the BB height and slacken the head angle on my SA and know I can buy a shorter shock (6.5"x1.5") to replace the RP3 that's on there now. But I've been reading about shorter shock mounts and relaxed cleats and am wondering if that is a better way to go.
I'd like to use the SA as a typical XC bike so 6" travel is a bit much. I'm also slightly too long in the torso for the frame as it sits now and am worried it would be even worse with the shorter shock. Would the shorter shock mounts and my current shock lower the BB signifcantly or not? Where would I get them? Any combination use of shorter shock mounts and relaxed cleat? Any effective top tube measurements with different configurations available?
Mine's a stock set-up 2003 VPS with Float RL shock, 4.5" travel and with the shock in the front set of holes on the VPS mount, the BB height is a manageable 13.5ish, with tt length around 22".
Hmm. It's a 2006 I think, it does have the VPS mount. Right now I have it set all the way forward with a 7.0x2.0 RP3 and have a close to 15" BB height. Would like to get it down to 13" and keep an ett around 23". There are a few 6.5x1.5 Vanilla R's with a 900lb spring on ebay for $65 which isn't bad, or there are some old Fox Alps 5's available. May get something to experiment with. Thanks for the info.
That's pretty much the same setup I have (15.5" BB). It's a bit tall for high speed flickabilty, but it pedals over all kinds of off camber stuff.
Still I want a 6.5" shock. A 14.5" BB height would be great for where I ride.
Here my experimental build using a 6.5 shock on an 06 san andreas
The head angle is 66, and the BB is sitting at about 13.75 .... I also had to move the subframe to more crampt setting because otherwise the seatube angle was too slack and positioned you too far over the rear wheel.
the idea for me is a mini freerideish / light DH rig which i can pedal ... the frame plus shock on an 06 SA weighs in at 3kg ... really good
also... you cant use the sin cleat on this setup - swingarm and the toptube dont get along if you try
xc; 100mm fork, 165mm eye to eye shock in top position gives a 13" b/b
Trail; 140mm fork, 165mm eye to eye in second position down, 14" b/b 67.5 degree head angle and rides fantastic, a real bombing bike!
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
