Results 1 to 3 of 3
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    Maximum Rumble Rubber?
    Is it possible to get a 3" Nokian Gazalodi in the back of a Rumble, or would it just not go?
    Cheers,
    Dr FG
    A Fatback'd Lefty for who life IS a Beach
    Reputation: mcrumble69's Avatar
    If you are running a front derailleur, It's a definite No. It would rub the derailleur cage.
    I had to run a 118mm BB so I could adjust the FD out enough so it would not rub a 2.4
    The largest I have tried without a FD is a 2.5 and that was fine, but I'm not sure about 3.0
    Reputation: JRA009's Avatar
    The Kenda Nevegal 2.7 barely fits and with that big of a tire you can guarantee flex of the tire will rub the frame (that slows you down a bit).
