Results 1 to 6 of 6
    Mar 2011
    Problem. Crank moving side to side. Fly Pro
    I have about a quarter inch of play in my bb. It is enough that it is hard to shift to the big chain ring. The bottom bracket appears to be tight. I havent put a wrench on it because im not familiar with these new fangled style bbs. My bike is a 2011 Fly pro 30 speed dyna sys with fsa v-drive cranks. I emailed bd in search for a remedy. Im waiting for a response. If it is something easy I can fix that would be great. Thanks in advance for any help.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Did it always have play or is it a recent development?
    Mar 2011
    It is a recent problem. After poking around a little I found the problem. The hex bolts came loose and Tue crank was sliding off of the spindle. I squeezed it back together and tightened it. Should I put lock tite on those bolts to prevent future loosening?
    AZ
    AZ is offline
    Yes, and check them frequently.
    I had the Sam issue with my fly pro ds. I torques the bolts and haven't had the problem since.
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    Proper torque and loctite go a long way.
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
  1. Front wheel side to side play - 2011 SJ Comp 29er
    By Breezin86 in forum Specialized
    Last Post: 11-27-2010, 10:01 PM
  2. side-to-side bb/crank play
    By rushrider in forum Cannondale
    Last Post: 07-03-2008, 06:55 AM
  3. Moving to the dark side!
    By pro in forum Urban/DJ/Park
    Last Post: 03-23-2008, 06:47 PM
  4. Suddenly ALL chain links making vibrating noise with side to side play
    By noshortcuts in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-17-2006, 07:33 AM
  5. Side to side wheelie balence problem
    By KB1LQD in forum Beginner's Corner
    Last Post: 07-20-2005, 04:26 PM
