here is my 2007. I picked up the frame from ebay, and built up from there.
StarkStarkonian said:I did a lot of research and determined this single pivot design is a good candidate. It brought the front of the bike a little forward and higher. I picked the U-Turn option so I could dial in the right fork length. I also picked up an Easton seat post with a large set back and adjustable seat angle pivot. I just tweaked everything around til my position was just right. I run the fork at full length and occasionally crank it down for long climbs.
Do you keep your forked extended out all the way with your setup?
I highly reccomend it for any of the Moto single pivot upgrade projects. I gained 2 1/4" of travel going from the Axis coil to the air shock. I highly reccomend you go with a shock that has motion control/pro-pedal with an adjustable floodgate. I can't stress that enough. The only regret I have is I wish I had located a MC 3R instead of the MC 3.3. The 3R gives you a handlbar Poploc Adjust feature. I have to reach down to switch between full open, threshold and lock out. I don't know what the travel is on your stock fork but if you can afford it I'd look into a Tora 318, or better, to increase your fork travel. It also allows you to fine tune the length and balance.mstguide said:Stark
Now that you had the 7.5 for a while do you still enjoy it? I'm going to be upgrading the rear on my 400ds? the 6.5 are a little harder to find.
Right on man, keep riding. Looks like you upgraded the rear shock/tires/wheels but too far away to identify.iMotion said:Mounted on the car.
Thank, I will be talking to my LBS soon to see what we come up with. :thumbsup:Starkonian said:I highly reccomend it for any of the Moto single pivot upgrade projects. I gained 2 1/4" of travel going from the Axis coil to the air shock. I highly reccomend you go with a shock that has motion control/pro-pedal with an adjustable floodgate. I can't stress that enough. The only regret I have is I wish I had located a MC 3R instead of the MC 3.3. The 3R gives you a handlbar Poploc Adjust feature. I have to reach down to switch between full open, threshold and lock out. I don't know what the travel is on your stock fork but if you can afford it I'd look into a Tora 318, or better, to increase your fork travel. It also allows you to fine tune the length and balance.
I don't think it's a deal breaker tho if you only have the cash to replace the rear shock and not the fork at this point and time. In general you'll just need to tweak your overall riding position untill the balance is just right. I picked up an Easton 50 seat post with a large set back and adjustable saddle angle from Sierra Trading post for $20. This is another key component to the transition. It balances everything out and allows me to dial in the correct seat angle which changed slightly with the larger shock.
Let me know how it goes and if something doesn't feel balanced.
Rock shox bar, I kept it at 6.5 inches. I didn't want to make many changes. It really rides soft and this bike its pretty tough. I notice the spacers are worn out, I need to get new ones. any ideas for the spacers?Starkonian said:mstguide...What did you get?
Starkonian said:Yeah, my lbs told me I was crazy for upsizing. Then they tried to sell me a new bike.
How does it run with the floodgate open? I haven't figure out the best setting yet. I think I have it fairly close, I know I have 175 psi in it and that seems to be working good for the bounce, like I said I haven't play enough to find the best setting if open or closed.
I had more pressure but it was too stiff. so I let some off.
The BBG bashguard works pretty good too. I rolls over everything I go over. Even some of the bigger logs.
The bashguard makes a big difference, some of the areas that we go over are pretty high and the outher ring dug into logs, the big problem was when I went to the rock garden at Alafia. The out ring hit a rock and I didn't realized it until it affected the next ring shift. I notice the chain hat pick up a little grindig on my middle ring.Starkonian said:My MC 3.3 is super plush with the gate open. I must have a bigger air can than your Bar because I only run 70lbs air pressure and I get about . . .
Hey mstguide,mstguide said:The bashguard makes a big difference, some of the areas that we go over are pretty high and the outher ring dug into logs, the big problem was when I went to the rock garden at Alafia. The out ring hit a rock and I didn't realized it until it affected the next ring shift. I notice the chain hat pick up a little grindig on my middle ring.
With the bashguard I can go over big logs and rocks with no problem it just rolls over everything. The BBG claims to have a life time warranty so far I haven't had to use it. In the future I'm going to get red tires for it.
mtb magz. just had an article were they concluded the longer bar gives better front end control.lostemple said:She is a sweet ride. I am enjoying mine immensely. I just ordered a low rise bar. The flat bar is definitely a racing bar at only 22" wide. I am going to try 27" and if necessary cut off an inch to 26". I have not had any issues with turning or pain with the narrow bar, but per the forums and pro zines they recommend a wider bar.
