Results 1 to 5 of 5
    Fuji factory build bikesdirect?
    What factory build bikes for bikesdirect? Is it still Fuji factory? They also build bike for Performance?
    I was told in other room, Fuji builds Motobecane - Bikesdirect bikes. Is this true? Do is it same quality as Fuji?
    Reputation: CarolinaLL6's Avatar
    I've heard some of the frames are Fuji, but as who assembles them I don't know.
    Reputation: Surfacecreations's Avatar
    The Motobecane frame is made by Kinesis. --> Welcome to Kinesis Website
    There's a Kinesis sticker right on the frame of a Motobecane. I believe it's a Taiwanese company and the frames are made in China. I've also heard it's welded in Taiwan.
    According to many sources on the web, Fuji does not make their own frames but also has them welded there in the same factory as the Motobecane. At least that is what I have found so far.
    If the frame geometry works for you and the components it's built with are to your standards then you should be good to go. Check out the Kinesis site. They seem to know what they are doing.
    Reputation: TheKevman's Avatar
    Kinesis builds frames for lots of "manufacturers".
    LIVESTRONG
  1. Wheel set build? Or factory set?
    By BigwheelsRbest in forum Wheels and Tires
    Last Post: 02-11-2011, 03:57 PM
  2. ? for AM/Comp XCL factory build owners
    By bailout in forum Custom Builders & Other Manufacturers
    Last Post: 07-01-2009, 11:15 PM
  3. 08 Fuji 29er Build
    By colorado4x4 in forum 29er Bikes
    Last Post: 11-11-2008, 02:23 PM
  4. Custom Build vs. Factory Spec
    By Walter Sobchak in forum Yeti
    Last Post: 02-29-2008, 02:07 PM
