Results 1 to 31 of 31
Thread: Fly Ti Weight
    Reputation: Kenrow's Avatar
    Dec 2008
    Fly Ti Weight
    Has anyone weighed their Fly Ti. I don't have an accurate hanging scale but did jump on a fairly accurate floor scale. Mine came in at 20.3lb which seems light since I'm running heaver tires (biggest improvement to the bike), crank bro pedals, and a cushier seat (assume its heavier). Everything else stock for now...
    My son's 16" Fly Ti weighs 21lbs 11oz. My digital scale reads exactly the same as the one in my LBS.
    -short cage XTR rapid rise derailleur (the bike comes with a long cage normal rise)
    -SL eggbeater pedals
    -1.9 small block 8 front tire
    -2.1 small block 8 rear tire
    Both tires have the stock tubes. We will be going tubeless and 1.9's F&R. That will shave a few more ounces.
    Cycling - What else is there?
    Dec 2008
    Thanks for the info, I though my recorded weight was a little low. I did see that a separate thread was done back in Oct 07. Weight for a 18" bike was in the low 21 # range and a 20" was in the mid 22#. Both included XTR Pedals in the recorded weight.
    I am surprised that your son's bike is the high 21 # range considering it looks like you only added a little over a pound with the tire change and SL pedals. Motobecane's claimed weigh is 19.8 pounds (no pedals or reflectors).
    Not a big deal, the bike is still light and nimble and climbs like a jet.
    Reputation: Broccoli's Avatar
    I did not weight it out of the box, but I have computed that a shipped bike was 20.17lb in 18", without pedals and without reflectors.
    After multiple changes it now weights about that but with XTR pedals included. My current changes had been XTR 172.5 crankset (heavier actually), Thomson Masterpiece seatpost, KCNC collar, Dura-Ace 12-27 cassette, rear 140mm G3 rotor, iLink shifter housing, Crank Brothers Opium headset, aluminum waterbottle bolts, etc. Can not settle on the saddle to use... Can not decide on tires to use. I initially thought I will junk the Vuelta wheels, but they seem to run pretty good and it is a decent enough weight to make possible upgrade very cost ineffective. I will probably convert them to Stan's and run something like Nobby Nics, or Raven, or the Kenda's it came with. It currently runs road slicks...
    Dec 2008
    Thanks for the info! 20.1 pounds is in the ballpark of what is listed on their website taking into account you have the 18” model. Just wondering did you weight the parts when you replaced them or just use the manufacturer’s listed weights. I am in agreement with the wheels, quite surprised over how they roll, would be tough to spend the $ up front to replace them.
    I also have the 18” frame, early model with the 80mm SID forks and no lockout. I also have the yellow graphics which I have gotten use to after about a year with the bike. I’m currently running Kendra Karmas with Stan’s, not much heavier than the klimaxs that came on the bike. They do roll a little slower, particularly on the road, but make up for it with their surefootedness in the dirt. Rest is stock except for the Terry race saddle and the eggbeater pedals.
    Quote Originally Posted by Kenrow
    Yes, I have weighted everything. I just bought calibration weights for my postal scale I used and it was right on - 50, 200 and 300g show as such. I also got a new scale with 0.1g accuracy now, maybe will check some weight again - it is fun.
    I have removed most of the graphics except for the top tube and the head badge. Came right off with that pink jelly paint remover. I have also removed Ritchie WCS graphics from stem and handlebars with acetone. Nothing against those companies, but they do not pay me to advertise them and it looks much nicer this way.
    the WALKING DEAD
    Curmy, I'd like to see a pic of your bike sans graphics.
    Your momma's so nasty, she keeps ice between her legs just to keep the crabs fresh.
    Dec 2008
    I second that. Getting ready to build up a fly ti frame, so I'd like to see it sans graphics. I've noticed this is pretty common on ti frames. I guess because they last so long, or because once you see ti it doesn't really matter who made it...
    Quote Originally Posted by Blake G
    I will take a photo in the evening.
    Quote Originally Posted by aph72
    So after about 5 minutes of using this:
    Frame, now in its office commuter build before it will be used for its original purpose, looks like:
    At least remove the cryptic labels from the seatstays and seat tube. I have no idea what they meant and it looked ugly. There was also an incredible amount of stickers on the rims.
    Did you buy frame only? Where?
    Dec 2008
    I bought the frame only on ebay. Some guy bought the whole bike from BD, but decided the frame was too big. He kept the components and sold the frame to me.
    What is the bare frame weight? I have never stripped it down completely.
    Enjoy your Fly. Quite a nicely done titanium.
    Dec 2008
    How does the bike handle as a commuter? I've thought about putting some road tires on but the weather has been so nice here in the bay area makes the trails too tempting....
    Its an excellent commuter, much more comfortable then a road bike when carrying a messenger bag and just as fast. 44/12 gear is too low on flat ground, I need to put an 11t cog on the cassette.
    Wheather is quite nice indeed, I was riding my Coiler in Waterdog and Skeggs during last dry spell, but it is still a bit damp right now. Should be great on weekend.
    The frame is listed at 2.9 lbs on the Mountain Bike action website when they reviewed the bike on 4/7/2008
    I just noticed these pictures of them taking a fly ti off of some dirt jumps and if you look closely at the fork its the old style sid too http://www.mbaction.com/ME2/dirmod.a...1542C3BFD125F1
    Quote Originally Posted by xc2006
    That's nuts. But frame does feel quite robust - even if flexible.
    Dec 2008
    I would proably want a better purpose fork if I was going to ride my Fly Ti like that on a consistnat bases...
    Dec 2008
    Quote Originally Posted by Curmy
    I
    My current changes had been XTR 172.5 crankset (heavier actually), Thomson Masterpiece seatpost, KCNC collar, Dura-Ace 12-27 cassette, rear 140mm G3 rotor, iLink shifter housing, Crank Brothers Opium headset, aluminum waterbottle bolts, etc. ..
    understand the crankset was changed due to preference in the 172.5 size, but what about the other parts. Were you trying to save weight or were there performance issues with the parts changed out? I'm particularly interested in the seatpost and headset. It looks like you went with a straight seatpost without any offset, any problems with the geometry of the bike (the top tube is fairly compact for a 18" bike).
    Seatpost is both lighter and better looking, and its geometry is fine with me. I have reused the Ritchie post on another bike. Headset has a slightly smaller stack height, lowering the front about 5mm, and it is 30g lighter, and it looks better. Rotor is to save weight and to alleviate Avid's howling, (reportedly improved with G3) and to balance braking, as I prefer smaller rotors in the rear. Cranks had been changed both to pick the length that I prefer, and from my general mild dislike for carbon components near sharp rocks. Rest is to save weight and for bling, and I trickled down the parts I have removed to my other bikes.
    Dec 2008
    Seatpost is both lighter and better looking, and its geometry is fine with me. I have reused the Ritchie post on another bike. Headset has a slightly smaller stack height, lowering the front about 5mm, and it is 30g lighter, and it looks better. .
    1) Did you have the weight of the seatpost, Thompson only claims it is 40 g lighter than the elite but does not give its actual weight.
    2) Did you switch over the headset mainly to lower the front or for performance reasons (beside the weight benefit). I have the 80mm fork and would like to raise the front if anything.
    They do give actual weight on their web site. It is 193g for 31.6x350. If I remember correctly it was 195g. It is not quite 40g compared to Elite cut to 350mm, more like 30g. Ritchie was around 240 if I remember correctly. I will check later if you are interested. Thomson was $105 on Ebay. I plan on cutting off about an inch from it.
    Mostly for weight and appearance benefits (it looks integrated with the SL version), lower stack height was an added bonus, and because I had one lying around (Opium is their "downhill" model. I would not put it on a DH bike).
    Dec 2008
    iLink cables
    After multiple changes it now weights about that but with XTR pedals included. My current changes had been XTR 172.5 crankset (heavier actually), Thomson Masterpiece seatpost, KCNC collar, Dura-Ace 12-27 cassette, rear 140mm G3 rotor, iLink shifter housing,...
    Hi Curmy, are you running the iLink housing with their cable, and if so how do you like it? Also, if you are using the iLink cable did you have to modify any of the cable stanchions?
    Finally- some rain in the Bay Area
    No, I kept the existing XTR cables (pulled out and threaded them back). Frankly, iLink does not seem like much of an improvement - I bought them just to try out. They look nice, and I did like the full length plastic liner - I noticed it prevents kinking of cable under the top tube when I hang the bike on a rack. It is sure easier to install and reuse them then screwing around with cable cutters (or rotozip with thin cutoff wheels that I often use).
    I did not modify anything, works just fine. Single set was enough for the bike with enough left for a remote travel control lever on another bike.
    Yeah, I am planning on skipping a day of work, alienating my wife a bit , and making a run to Tahoe after the storm..
    Reputation: airframepapi's Avatar
    Thanks CURMY !
    Im SO GLAD I stumbled across your threads regarding removing stickers from a Ti frame. I had just posted a thread of my own asking the question of "how to?" I was wondering I couldnt REALLY tell but is there any blotchy marks or discoloration after removal because from what I saw it looked great. Thanks again for the post
    Dec 2008
    I had a little bit of "ghosting" of the letters when I removed mine. A quick dose of metal polish took care of the rest
    Yeah, I had that too - if you take a really close look. After a few races and a healthy doze of trails - where I mostly see some burly trailbikes around - mud and dust took care of the appearance.
    I should say that Fly is holding up great. Does not flinch on some quite rocky descends and climbs like it supposed to. I have hard picking up whether I want to ride it - or my Kona Coiler (with an adjustable seatpost, 2.4" tires, 160mm through axle fork) - different kind of fun.
    I did put a 23t ellliptical granny on it this weekend. It climbs so well I do not need anything lower then 23/27 even for steepest and longest climb that I can clear.
    Thanks for the head's up. I'm going to try this too. The first thing that came to my mind was Biopace of my earlier days (no comment), but granny-only makes great sense.
    G.
    Quote Originally Posted by Gringo
    That is not Biopace - exactly the opposite effect.
    As I have mentioned - I would not want it on middle ring. No need to mess with pedal stroke.
