Results 1 to 56 of 56
    Fly Team Over Fly Ti
    I Was Planning On Buying A Fly Ti, But Of Course I Waited Too Long And Now They Donít Have My Size. I Was Really Counting On Buying A Ti Bike. I Donít Think I Can Wait Until They Build More So I Was Thinking Of Buying The Fly Team.
    Anyone Have Any Input/review Of This Bike For Me, Or Should I Wait For Ti And If So Does Anyone Know How Long It Will Be Before They Build More.
    Thanks Anthony
    yoU mighT havE tO waiT untiL nexT yeaR oT geT thE flY teaM sO gettinG A fantoM tI mighT eB A gooD holdeR foR ouY untiL theN.
    yoU mighT eveN realizE the fantoM tI mighT bE alL thaT yoU wanteD/needeD iN thE firsT placE, althougH the flY teaM is definitelY A sweeT ridE.
    Former Bike Wrench
    Humor I can appreciate
    Reputation: Broccoli's Avatar
    Look at Fantom Pro Ti. It is the same frame with a slight downgrade (and trail worthiness upgrade) in components. Once they wear out you can replace them with weight weenie parts. Same fork, and about two pounds heavier overall - half of the increase is in beefy tires.
    I would have bought Fantom if it was available when I have ordered Fly Ti, as I have ended up replacing/upgrading many parts anyway.
    Thank you all for the posts.
    I don't no why the font posted like like when I copy/pasted it from word processor, I was in a rush and didn't notice it, but yes very funny.
    Former Bike Wrench
    I would second the Fantom Pro Ti as well, the increased weight is in actual trail worthy parts...tires for instance that actually work on multiple surfaces, not just smooth hardpack. It also comes with an actual MTB cassette, not a road cassette.
    Quote Originally Posted by mtnbiker72
    [offtopic] We have had this discussion else where - but I do not understand where this notion that 27t is too high a gear for an MTB comes from. Yes, 12-27 is missing a single gear - about 18% lower, compared with some 12-32 cassette - but honestly, how often do you need that one gear? I may end up using it on a 37lb trail bike - but on a 22lb hardtail?
    Former Bike Wrench
    Moto is the only one
    Quote Originally Posted by Curmy
    Have you ever noticed that Motobecane is the ONLY bike company who does this...name me one other
    If you want a "pro-style" setup, most XC pros (I know, I've worked on their bikes) run a 2x9 set up with a mountain cassette.
    First of all, one the other end of the bike spectrum: http://www.sicklines.com/2008/02/25/...ette-pg-970-dh
    So the "ONLY" exclamation is somewhat misplaced.
    Then all of the bikes now come with 175mm cranks. Which is a really wrong idea for a whole lot of people, both short and tall. So industry convenience and consensus means jack sh.t IMHO.
    I rode a bunch of endurance events and found that I do not need that one extra gear on a lightweight hardtail, that is good evidence enough for me. Observing other folks around me - they do not use that last gear either.
    +Shorter derailleur, shorter chain, lighter cassette, more accurate gear choices, slightly cleaner shifting.
    -One gear available that I never used.
    Double setup with a 26t small ring and 32 cassette is the same low gear as 22/27, and there is a good use for a 44/12 gear on a bike like Fly, so I would rather stay with a triple.
    Former Bike Wrench
    You are in the minority
    Good for you that you don't use the 32 tooth...but MOST people use all of their gears on a mountain cassette. And BTW-the cassette you linked to is clearly labeled as a DH (as in downhill) cassette which is common on bikes that only go...downhill...hence the DH
    And your also totally wrong on the "all of the bikes come with 175mm cranks" statement. Most bike companies actually put 170mm cranks on their smaller sized bikes and definitely on their woman's specific bikes. Its still not perfect, but 175's are not on all bikes.
    I'm really happy for you that you love your road cassette...but again you are in a major minority and BD only puts that cassette on the bike so they can advertise how light their bike is. While I overall like BD and of course own one of their products...it is simply dumb to spec a bike with parts that are not appropriate for the majority of their buyers.
    12-27 cassette is perfectly appropriate for all the buyers who ride a lightweight racing hardtail. (would be completely optimal with a 11-28). They may not realize that since they did not try it in a long time. There is absolutely nothing wrong with missing a single low gear and a lot of benefits that I have enumerated.
    You do own a 29r? So your lowest gear/inch with a 32 cassette is only 6% lower then my 27t cassette on a 26" wheel, and that's on a bike that is significantly heavier. Do you really think 5% less available matters that much?
    I see where you benefit from a 11-32/34 if you run 2x9 setup as many XC racers do, but if you need a slightly wider overall range of a triple, 12-27 works just fine.
    Yes, I know it is a DH cassette in the link, I said it about the other end of the bike spectrum.
    Anybody taller then 6" will be better off with a 180mm+ crank, and anybody under 5'4" needs 165mm. They do not get it.
    Dave Wiens and Lance Armstrong both were running XTR cassettes during the Leadville 100.
    To each his own. I ride with some very competitive riders (for fun) and we all use MTB cassettes. Motobecane is the only XC Mountain bike I've seen that comes with the 12-27.
    Maybe Curmy should be on a SS.
    Quote Originally Posted by snowind
    Was it a 2x9 setup by any chance? But I would guess they both could ride anything.
    No, thanks. I own a SS, but I would not use it on an adventure race. I need my knees to last a while.
    When you ride with your competitive friends - take a note on how often they actually use the last gear. I did it once on a 36 hours race (that involved 10000ft overall climbing on a bike), and I have used 24/32 once - and 22/27 would have worked just as well, as it quickly ended in a hike-a-bike. Yes, I am that anal to track what gears I use, and I am not strong at all - I sit and spin. And Fly Ti will be for sprints. And I would not ever bother switching my Yeti or Kona to a road cassette.
    Oct 2007
    Curmy, if you can ride without a 32 or 34 tooth than either you are a very strong rider, or you don't have any really steep hills. If you are a very strong rider that is great for you, and I applaud all the hard work you have done. I can tell you that I get a lot of use out of my 32, whether it is in the middle ring, or the granny ring. But there are some questions that you need to answer.
    1. Why does no one, not one company, make a mountain bike cassette that uses a 27 tooth low gear (other than downhill cassettes which aren't made for climbing anyway)? If, according to you no one needs a 32 on a race hardtail, then there should be a lot of people needing a mountian cassette with a 27 tooth low. And if there were all these people, manufacturers would be more than willing to make them.
    2. Why is the use of road cassettes so uncommon, since again according to you that is what you need on a race hardtail.
    3. Why not have a 32 tooth. Are you really worried about the 80g or so of extra weight? You can get an XTR cassette which weighs no more than an Ultegra.
    What it comes down to is this. Just because you don't need and or want something don't make the assumption that everyone else is like you, or should be like you. There is at least one benefit of a 32 that even you would utilize. You do not have to shift to the granny gear as often, which for me is extremely convienient.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Quote Originally Posted by ljsmith
    For the same reason they do not put appropriate cranks on bike. And unlike a proper sized crankarm having a 32t around does not hurt.
    I am not claiming that everybody should be using a 27t cassette. I am claiming that most strong words against such use are either unfounded or exaggerated.
    This is a one extra gear ratio - 18% difference. (6% with a 29r on a 11-32). Your statement that one must be a particularly strong rider to not need that one extra low gear does not seem to hold to an experimental verification. When 22/32 is good enough for a 35lb trail bike, 22/27 should be good enough for a 21lb race bike.
    For the same reason that use of proper size cranks is uncommon. Common solution works well enough.
    Because I do not need it. I can get a Dura-Ace 12-27 9sp that is 50gr lighter then XTR and $100 cheaper on EBay. And Ultegra came with my Fly Ti.
    What it comes down to is that I was not making arguments against usage of a wider range cassette, I use'em myself and would not bother changing - I was responding to arguments against usage of a slightly more narrow cassette. I am not sure that people who argue against it do have any other solid justification besides "everybody uses 32/34".
    Former Bike Wrench
    I use 11-34 on my 29er
    First answer, I use a an 11-34 on my 29er. This makes my lowest gear 15% lower than a 26er with a 22/27 setup. In addition, my 29er gets significantly better traction which allows me to stand and climb on trails my 26er would lose traction on if I stood. That said, there is a push to bring back the compact 5 bolt 58/94 crankset pattern so a 20 tooth gear can be used on 29ers. Back in the mid-90's when the 8 speed cassettes were 11-28, I used 20 tooth grannies which overall was 6% higher than a 26er with a 22/32 low gear. When 8 speed 11-30 cassettes came out, the 20/30 is nearly identical to the current 22/32.
    Second, both Dave Weins and Lance Armstrong used XTR Triple cranksets in Leadville with full XTR cassettes. You can click these picture links as proof.
    http://www.ultrarob.com/blog/uploade...604-741677.JPG
    http://www.velonews.com/files/images/wiensbike.jpg
    So two of the best riders in the world use full MTB cassettes and triple cranksets. And again what company uses a road cassette on their top of the line race hardtails? NONE, ZERO, ZIP
    The $6600 Specialized S-Works Hardtail comes with an 11-34 and if that isn't a pure bred race machine, then what is? Yet Specialized doesn't try and make it artificially light with a Dura-Ace cassette and worthless tires.
    You can defend it all you want, a XC mountain bike should not come with a road cassette. It should only be a weight weenie choice after the bike is purchased since so few (including top pros) would never use a road cassette on their bikes.
    They also come with a choice of two crank lengths and only five frame sizes and the reason for this is purely and entirely economical. It does cost too much to make another carbon mold and to stock and distribute too many parts, and those sizes work well enough. Will you argue that nobody should ever fit the bike to them? Gearing is just as important as the frame size, and no, you have not offered a shred of actual evidence that a 20lb hardtail should have the same gearing as a 35lb 6" travel trail bike. I have offered you an observation of actual gear usage (not just carrying it around, but actually using it). Good enough for me - and no, I was was not putting down *your* choice.
    How many other companies offer a nice Ti frame with top parts for $2K to your door? Should BD also follow the best industry practices and offer 100% mark-up at your friendly LBS?
    BD also specs 12-27 only on a few models - it seems they do actually understand the difference in usage.
    Only Cannondale (probably) offers BB30 frames - does it mean that it is a bad solution? $6500 Specialized does not offer it, and Lance Armstrong did not ride it - must be a bad mistake to ever offer a lighter and stiffer choice .
    Nobody would argue that a Jeep Wrangler and a Porche should come with the same gearing - why should my Kona Coiler and my Yeti Kokopelli and my new Fly Ti have the same gearing? It is entirely illogical to suggest that common parts is anything more then a reasonable compromise. (my current bikes are now 22/36 to 11/34, 24/32/44 to 11/32, and 22/32/44 to 12-27, and I have used pretty much anything that had been available in the last 20 years).
    You can defend industrial conventions all you want, but so far you have not offered a single argument beyond "everybody doing it" for why you need an extra gear ratio out of ~14 available in this *particular* application. What Lance uses is irrelevant just as much as what Joe Sixpack uses on his Walmart special. 12-27 gearing works perfectly well on a light hardtail and I applaud BD for offering this choice.
    ..allows me to stand and climb on trails my 26er would lose traction on if I stood
    If Fly Ti loses traction it is not because of the choice of gearing, but because of the choice of its tires. 18% lower gearing will not make a dent of a difference, and one can pedal smooth enough standing. Traction is not a direct function of gearing.
    Sorry, but you are just repeating "everybody is doing it so it must be right". That does not make a strong argument.
    Many good adventure racers often run the whole race on cyclo-cross bikes with 36/46 cranksets, even as they suffer through roughs. Will you tell them that they are dumb for making this choice and they should use a "real" mountain bike? Hogwash and a pound of boloney. Fly Ti in fact fits in between a cyclo-cross bike and a trail bike. It is only natural and right to have gearing set-up in between those choices as well.
    Oct 2007
    Your argument comparing crank length to cassette gears is ridiculous. In the case of cassettes it would be extremely easy to make a mountain 11-27 cassette since the tooling already exists. So if there was a market for them, they would exist. In fact Shimano would probably just relabel an Ultegra cassette as an XT. No major crank manufacturer has tooling to make multiple crank lengths, except 170 and 175mm and maybe a few others. The tooling for the cranks will cost too much, because there isn't much demand for the smaller or larger sizes, because the majority of riders are not huge or tiny. But again, tooling for cassettes alrady exists!
    Why do so many people make an issue of the Ultegra cassette on the Motos? Well because the majority of people do NOT want it. Why spec your bike with something the majority of people do not want, and will have to pay money to replace, just so the few weight weenie guys can be happy? The simple answer is that they want to make the bike light for marketing purposes. I think most intelligent people can see that. So yeah, people do not like having to spend extra money to buy a new cassette for a new bike. If bikesdirect would give you a choise of cassettes you would see very little people complaining about the road cassette, as long as they can get what they want they don't care.
    There is no winning this argument about gears in a forum. What I really would like to see, is you out on the trail riding every hill with the 27. There is one place I ride with an extremely steep hill that has a layer of sand on top. On the trail map it is labeled as "cardio climb". You CANNOT stand and mash to get up this hill because of the sand, your rear wheel will just spin out. The only way to get up this hill is to shift to your lowest gear, stay seated and using a slow steady pedal stroke ease your way up the hill. I would love to see you get up this hill in the 27.
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    No it is not, you just did not get it. The point is that a unified solution that works well enough will be offered, as companies would not bother to optimize their offerings and cranks is a good example of that. It does not hurt to offer a wider cassette as a standard- I have never stated it does. It is just not optimal.
    Why stop at 34? Why not a 36 with a 20 in front? Somebody did their homework and came out that it works OK - for everything including heavy AM bikes with 2.5" tires. It also works OK for a lightweight racer - but that does not mean it is optimal.
    As I have mentioned, I have monitored my gear usage on multiple adventure races in Sierra Nevada mountains, I am very particular about my equipment, my food and so on and keep logs and pay attention - and I do not switch into the last one, and most good racers around me rarely use it, and a whole bunch of people do it on cyclo-cross bikes - with a frigging 36 in front. That's a fact. I am most definitely not a very good athlete - I am barely good enough to finish a 24+ hours race in the second half of the pack.
    Fly Ti with narrow tires is really a heavier duty cyclo-cross bike and must be geared as such. It is the right solution to offer it like that.
    For trail riding I just assembled a new 6" FS Kona. It is entirely unfounded and utterly illogical to suggest that a 6" AM bike needs the same gearing as a sprint race hardtail.
    Sorry, but your arguments just do not stand up to logical and experimental verification. Be honest to youself - pop in a 12-17 cassette and ride around on a 20lb hardttail - for trails that a 20.5lb hardtail is suitable for..
    Have a nice day.
    Oct 2007
    Have a nice day.
    What is your "experimental verification". Do you even understand the scientific method? What you have described is not experimental verification, it is in fact called anecdotal evidence. How in the world does your anecdotal evidence about your adventrure races have anything to do with me, or anyone else for that matter?
    Some real experiments you could do:
    1. Statistically you could take a random poll of mountain bike riders to ask if they use their 32.
    2. You could take a large group of random mountain bike riders to a very hilly course with bikes equipped with both a 27 and a 32. The cassette would need to be obscured so they cannot see what size cassette is on the bike. At the end ask their opinions on the gearing and monitor their times.
    3. You can take a random poll of who would be interested in a 12-27 vs. 11-32 cassette when shopping for a lightweight hardtail.
    Notice none of the experiments includes you. No scientific experiment can include the researcher as this could influence the results. They need to be mountain bike riders which may include racers. But using racers only does not give a correct sampling of all the possible buyers of a mountain bike and thus a racer only test would be insignificant.
    Once you complete the above studies get back to me, and then we can talk about real experimental verification. Other wise all you can say is that YOU only need a 27 tooth.
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Yes I do, I have a Ph.D. in experimental physics.
    What you suggest is not an experimental verification. People get bikes with something installed due to industry conventions, and they may use it, but that does not mean it is optimal or necessary. Experimental verification is when people do not employ their preconcieved notions (as ones that you so vividly display), so shopping patterns or polls are much worse of an indicator then an observation that I have offered. So I can only conclude that it is you who do not understand the scientific method.
    It is a firm fact that you can not dispute that many adventure racers use cyclo-cross bikes. That means that 36/27 gearing is good enough for this purpose. It is entirely obvious that in the gap between a heavy AM bike with 22/34 and a cyclo-cross there is plenty of room for a different, optimal solution.
    Observing a person pull away on a steep climb 5 hours into the bike leg of a race in a middle front ring is a scientific observation. Asking the same person about what he thinks he may need is not.
    You have not made a smallest dent in this argument. Have a nice day.
    Former Bike Wrench
    Has it occured to you...
    That your the ONLY person defending a road cassette on the Motobecanes...
    That's OK, you can ride to the beat of a different drummer...but your explanations are severely lacking in substance
    I have offered plenty of facts, observations and logical reasons. You have offered NOTHING but point out to an established industry convention.
    You did not refute neither the fact that the cyclo-cross bikes gearing is adequate for many of the same applications that a Fly TI is targeted for, nor the fact that given the choice many people do not actually use the lowest gear, nor the fact that 12-27 offers tangible performance benefits in a particular application.
    The fact that the substance in my explanations flies straight over your head is not a concern to me. Have a nice day.
    Space for rent...
    Reputation: SSteve F's Avatar
    Not trying to be a dink, but I do agree with Curmy on this subject. Nothing wrong with a lightweight hardtail having a 12-27 cassette. As he said, a light bike going uphill isn't going to need the same gearing as an all-mountain bike.
    I am sure overall weight may have been the primary reason the bike was spec'd this way, but there is strong argument that a 27 rear cog is suitable for the application.
    Most singlespeeds can climb just about anything in 32/16 to 32/20, so to suggest 22/27 is too high, is well, just silly
    It's only pain......
    Quote Originally Posted by SSteve F
    Consider two systems
    29r, 35lb, 32t rear cog
    26r, 20lb, 27t rear cog
    Assume a 150lb rider, ignore rolling resistance difference (it is not as important at a low speed steady climb). Total relative force one need to apply to maintain a constant speed uphill for the 29r compared to a 26r
    (185lb*29"/32t)/(170lb*26"/27t) -> 1.025
    So it is actually 2.5% harder to move a 29r in the last gear, and a 26r will move ~8% faster for the same constant power output. (power determines the rate of climb for a given mass, while force depends on gearing and slope for a constant(or zero) acceleration)
    So all the vitriolic arguments against using a 12-27 cassette on a light hardtail should equally apply to a 35lb 29r with a 32t cassette. Which illustrates that they are indeed silly.
    Thank you, but I prefer a more precise cadence selection over many hours, and an extra 60g off my bike (cassette and a shorter chain).
    I am sorry to be the one to ask a seemingly stupid question but it wont be the last time since this thread started off as Fly Ti vs Fly Team i thought this might be a good place to ask does the Ti itself give you a different ride
    Just because Curmy is the only one dialoguing in this thread on a 12-27 road cassette on the Fly Team Ti does not mean he is the only one who sees its merits, and certainly does not detract from the validity of this or any such other bicycle being spec'd with it.
    In fact, I think it's great; not that a more common 11-32/34 "mountain cassette" isn't, but there's nothing inherently wrong with a 12-27, especially for a lightweight bike like the Fly Team Ti and the presumably light (and strong/skilled) pilots who ride them.
    Quote Originally Posted by Bends But Doesn't Break
    Thank you Bends. Mtnbiker's emphatic ALL CAPS assertions are quite misplaced indeed.
    Quote Originally Posted by xc2006
    It seems to be much more compliant and dampens vibration very well - I am not rattled nearly as much as with Fly Team I have tried some time ago that my racing buddy had, and compared to a Trek 8500 hardtail I had a chance to ride around recently.
    I also expect the Ti to be much more reliable and robust over the long term. If not breaking qualifies as a "different ride", then that's another point to consider.
    Fly Ti setup that I would prefer to triple - 12-27..
    There is at least one benefit of a 32 that even you would utilize. You do not have to shift to the granny gear as often, which for me is extremely convenient.
    It will probably be worth it for me if the middle ring was around 30/29t - then it seems I can stay in it for most of the time. If you look at Trek 9.9, it comes stock with low Q FSA 42/29 crank for the lowest gear of 29/32 - that is 11% higher the the lowest stock gear on Fly Ti. For the low low price of $6599. I would have actually preferred the Fly to be set up like that - maybe I will do that...
    Dang - should have looked at FSA double instead of the XTR... It has odd BCD though...
    IMO, Ti is the ideal frame material for mountain bikes.
    It has the rigidity and light weight of aluminum, providing efficient energy transfer and close feel of the trail that aluminum does, but dampens trail shock akin to the feel of steel (without steel's weight and flexiness) that gets telegraphed by aluminum. To me, jolts on aluminum are felt all the way through the small of my back, but on Ti, such jolts feel like more of just a 'thud' against my chamois.
    Ti is inherently durable and corrosion-resistant, and doesn't present the fragility issues that carbon fiber does.
    Plus, bare Ti tubes just look plain beautiful.
    Well, it's not my intention to pick sides or polarize a debate, but rather just to remind that just because certain points of view aren't as prolifically expressed as others does not inherently weaken those points - there are a lot of lurkers out there, each of whom have their own experiences and opinions.
    That was not my intention either. I have just noted in a response labeled [offtopic] that I have disagreed with a strongly worded assertion that a cassette has to be changed on a Fly Ti.
    Oct 2007
    Curmy, I wish you had told me you were a Ph.D. up front. I wouldn't have bothered debating this with you. I have never met a Ph.D. who could admit they were wrong. They always say stuff like "Well in theory I was right"
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    I guess that is because they never stooped down to debate you? Sorry, my mistake that I did.
    You have resoundly lost an argument, and all you can come up with is a personal attack. I have tried to illustrate it for you - but it went right over your head it seems.
    I am not right in theory. I am right in practice of riding this bike.
    Have a nice day.
    Reputation: VTECnical's Avatar
    gmarte12
    i totally agree with Curmy here. a 27t max is suitable for a ~20 lb race bike.
    just because nobody puts a 27t on a bike does not mean that a 27t is at a disadvantage. Look, no other company sell high end mtbs at ~$2000 other than motobecane. Does that mean that they are wrong and stupid? Quite unlikely. The fact that they outsold their stocks is a testament to that.
    Also, the reason why a 2x9 setup is more common than a 3x9 (with 27t max) setup is because losing the smaller chain ring means more weight is shaved off because chain rings are usually heavier than cassette rings. Finally, an ultegra cassette is cheaper than an xtr cassette. They would not use an xt (mtb equivalent of an ultegra) because it would look out of place with the xtr group. Comparing a 2x9 setup versus a 3x9 (with 27t max) setup obviously favors a 3x9 (with 27t max) in terms of requiring less force to move the bike forward. So there.
    And just in case you guys will be an a$$ and ask me for my credentials, I have graduated with a major in biophysics (physics combined with biology) with a minor in chemistry. And one of our case study and experimental lab was analyzing dynamics for biking.
    And finally, people who should buy this bike must be around 180 lb MAX. Any heavier means you're too fat to race and realistically come close to winning. Lose some weight through road biking before coming back bragging about xc racing.
    and in case you never finished college and still don't understand the above reasons why a 27t is more than enough for a fly ti...
    then my question for you is:
    are you a noob that you cannot stand and pedal at the same time?
    Quote Originally Posted by gmarchie12
    It appears that a lot of people don't realize that the Fly Ti is out of their fitness/skill league.
    Just because an exotic frame material and lots of bling components including carbon is available at a price within reach does not mean that the bike is suitable for anybody who can purchase it.
    I was agreeing with you until this blurb.
    I am a rock climber and a former wrestler, and I am not planning on getting under 180 any time soon, even as I am fairly short. At 180 I had no body fat and did not feel well. That is a reason I was not buying aluminum Fly, but grabbed the Ti frame, I do break things.
    I do not care about winning - I care about finishing 24 hours. My weight did not preclude me from doing that.
    gmarte12
    good point.
    Ok..Ok... Already... I too have a Moto fly ti and I have used the road cassette that came with it all summer on full blown double diamond trails. Does it work? Yes. Do I wish I had a real Mtn bike cassette? sometimes on long rides. Will I be buying a Mnt cassette over the winter? Yes. (The one that came with the bike was just a plain jane cassette anyway) Is it the rite equipment for that bike? Probibley not. Mike from BD did admits that it was set up for a fast flat no hills track.
    That said I still love the feel of this bike.
    P.S. I just switched to tubeless tires and that made all the differance on the small roots and rocks under 2" no more sharp jabs. Smooooooth as butter!
    P.S.S. Mike how about going tubeless on that FS Fantom Team Ti.
    Quote Originally Posted by teeroy
    It works just fine on steeps hills here in California. No problems at all. Math does not lie. Just like we did not have problems running 7-speed 12-28 on heavier bikes. It is the right equipment for this bike.
    The part that is set-up for the fast flat track are the tires. I will probably end up with two wheelsets - one with either stock Klimax, later replaced with Furious Fred, other with something like 2.1 Racing Ralph rear, Nobby Nik front...
    gmarte12
    anyway, back to the original question
    fly team vs fly ti
    The fly team seems to be lighter than the fly ti by more than half a lb. Nonetheless, the Fly ti has a longer functional life in terms of metal fatigue--albeit with a higher price. For those people who get embarrassed to be caught riding on a "motobecane", the fly ti seems to be the easier bike to remove the sticker/paint. However, i am pretty sure that there would be some consequence in terms of warranty or whatever meager guarantee bikesdirect offer.
    I'm very proud of my Moto. I would never think of taking the decal off.
    I actually take decals and stickers off everything. Just do not like it. I have kept top tube and badge. Cleaned stem and handlebar from gaudy WCS Ritchey lettering and so on.
    I definitely would not mind one bit directing people towards Motobecane, and I do that.
    Jan 2009
    I know its old news about 27t gearing but my older mtbs from the 90s only went up to 27-28t. 32-34t gearing I think is being used because us americans are getting bigger and heavier(lol). The trails in the 80s and 90s are no different from now, just the weight of the bikes and people.
    Jan 2009
    I am hoping to get the fly ti but they just ran out of my size last night. I should have purchased it two nights ago. Now I have to wait several months. arrgh!!!
    Quote Originally Posted by milo8172
    Worth the wait.
    Double check the top tube length. It is on the short side.
    I currently have it set up with slicks for a short commute to my office (67 F today and sunny), so just it does not get bored in my garage.
    Jan 2009
    I am only 5'4" so I was looking at the 14" frame. I was a day late and literally a dollar short. I have the money now but no Bike!!!!!!!!!!!!!! Luckily, I haven't sold all of my bikes to get this one but now, the Anticipation. Because of that, I looked at a trek 9.8 carbon but I will have to wait because the components are only LX on the Trek. hope one shows up soon. Thanks Curmy. I have been Lurking for a while now and settled on buying the fly team ti. Curmy, where are you from? that is about the same weather as here in San Diego. Actually warmer now.
    Milo
    Milo
    14" maybe even small. 16" is 21.5 top tub AFAIK. My 18" feels barely enough for my 5'8".
    I am in SF Bay area.
    If you get the Fanthom Pro Ti (from what I understand, same frame, same fork), for the $400 saved you can go to chainreactioncycles and get Dura Ace cassette 12-27 9 speed ($90) (or XTR one for a bit more), XTR shifters ($130), XTR 971 midcage rear ($105) (not sure if shadow 972 works as nice with 12-27, it is further away from cogs),.
    Sell FSA cranks while new on Ebay and getting SLX for $105 with granny from XT ($15). Then Thomson Masterpiece seatpost on Ebay ($120 shipped 31.6 350) with lightweight seat collar (Woodman deathgrip for example, or KCNC).. Ti mounting kit for the Juicy brakes.
    All that will shave a fair amount of weight and will be a kit comparable with the stock Fly Team Ti, something step below, something above. They have free shipping above $250.
    I have ended up upgrading Team Ti in the similar fashion (Dura Ace, Thomson, iLink housing, 140mm G3 rotor in the rear, different tires, aluminum bottle cage bolts, replaced K-light with XTR 172.5 cranks (saved $40 bucks), and many other bits) so it might have been cheaper to start with the Fantom Ti)
    Basically if you want it just the way you like it, getting Fantom now, selling takeover parts while brand new and shopping online you can get a better kit for about the same money. For example you could sell Juicy 7 on craigslist for fairly close what you would pay for Elexir CR ($154) on chainreactioncycles.. And building up your own bike is fun.
    Titanium frame is the way to go IMHO. You can not get such a deal on a Trek.
    Jan 2009
    My standover (or inseam) is only 26.5". you recommend a 16"? even so, none of those sizes are in stock for the Team Ti. All my bikes are Marins which turned out to be named after the trails in Marin County. How lucky to be in the SF Bay Area. Based on the Reviews though, it seems that the Fantom Pro Ti. is a great bike. Thanks for the info. The Trek I was looking at was a close out but only has LX components and is heavier than the Moto bike.
    I think you really should be fitting the top tube length. you can look up the geometry on your current Marin. You may want to consider 165mm cranks, at least 170m if it does not come with them.
    I only recommend getting Motobecanes for people who enjoy doing some basic tune-ups and upgrades themselves. But even out of the box, without all the upgrades I have mentioned it will be a nice trail hardtail. You can lighten it up to the Team level as you go, if ever.
    Simplest weight upgrades would be XT cassette, Halo bolt-on skewers instead of quick releases, maybe lighter tires (Racing Ralph 2.1 fr example). I really prefer instant and multiple release on XTR shifters. So that ($130) would be something I would order on the Fantom.
    This is your opinion and not a fact. A person can buy a "lightweight racing hardtail" for any reason such as, say, bike touring with an extra 30 lbs of gear. A 32 cog would likely be better than a 27 in this case.
    Quote Originally Posted by nobody'
    It is quite a bit more then just my opinion since many people myself included are sucessfully using such a setup, or even higher gearing, so it is most definitely adequate.
    Bike touring? It got no mounts for rack or fenders, paperthin tires, hard saddle, flimsy rims and a lighweight chain. You will have many more things to worry about if you take it touring before that one extra gear. That is beside the fact that almost all touring bikes have 700c wheels and road cranks - which is higher lowest gearing then 22/27 if you bother to compute gear inches. If anything you would rather have better choice of cadence for touring.
    HTFU!
    Reputation: S.O.B.'s Avatar
    Just to add my two cents.
    I purchased a Fantom Team early last year and it came with the 12-27 cassette. I enjoyed tooting around on many trails, all beginner to intermediate with no major climbs. I did get some comments on a couple occasions from other bikers saying I am going to be working harder with that cassette on climbs or that I should probably upgrade to a 32 cassette. I debated it and almost made the switch, but ultimately decided not to.
    The facts are that I was not a very strong rider to begin with. Even though I am a former roadie, trail riding brought new challenges that I needed to adapt to, such as the quicker more anaerobic climbing as opposed to the mostly aerobic road riding. Once I made the decision not to switch, I sought out trails with more hills to gain a workout that helped build my strength as a climber. I have owned this bike less than a year, and I am a much stronger rider than I was. Sure, I would still be a stronger rider even if I switched to a 32 but now I am a stronger rider who did not fork out any money for a piece of equipment that would not have made my bike a better bike or me a better rider, it just would have added a convenience (and a few more grams--no big deal) during riding, making some climbs easier. Anyway, I already opted for the only convenience I really wanted--full suspension.
    It is my opinion that the type of rider you are determines what cassette may best suit you.
    If you are a beginner, a recreational rider, pulling kids, and/or occasionally hitting some big trails, you may opt for a 32. There are times it will make your life easier and there may be times you will wish you had a 34 or larger???
    If you are a serious rider who is looking to do more than just get a workout, but to challenge yourself, or you want to gain the respect of your riding buddies and be able to brag that a 27 is plenty and that you wouldn't use the gears on a 32 anyway, then you have the right cassette (yes, that is now me). Or even weight weanies might opt for the 27.
    So in a nutshell. Sure, a 27 is probably fine for most; still, If you have a 32, no point in changing it to a 27 unless you really want to save those few grams (yes, or fork out big dough for a lighter 32).
    As always--IMHO
    I no longer deserve a signature.
    Jan 2009
    Quote Originally Posted by hershal
    Thanks Anthony
    did you ever get your fly ti? I was one day late in receiving my moneys and next thing you know, my size too was gone. going to have to wait.
