Results 1 to 5 of 5
    Jan 2005
    Fantom 29 rear susp. performance
    Greetings,
    Got one of these for my girlfriend who's 98 pounds soaking wet. Rear suspension seems way overdamped - rides like a hardtail even with damping at minimum. Static sag is set at 25%.
    Anyone else having a similar experience? Solutions?
    Mar 2012
    hello, I don't have that bike , but I do have a Dawes Roundhouse 2000, I'm also in process of researching/hoping to upgrade the rear shock, I think that im going to upgrade the rear shock to a Fox RP23 or the Manitou shock, I believe that is the only way to fix this problem, coil is rated at 850 lbs?!!!! I also have my stock shock at the minimum and the bike developed a creak , had to tighten up to get rid of the annoying creak, hope this helps
    Jul 2013
    Quote Originally Posted by bicycleriderguy View Post
    Greetings,
    They might be tuning the bike for a target maket segment closer to the average heavy American rather than the average bicyclist.
    Quoted section below taken from the following link.
    FASTSTATS - Body Measurements
    Body Measurements
    (Data are for the U.S.)
    Measured average height, weight, and waist circumference for adults ages 20 years and over.
    •Men:
    Height (inches): 69.3
    Weight (pounds): 195.5
    Waist circumference (inches): 39.7
    •Women:
    Height (inches): 63.8
    Weight (pounds): 166.2
    Waist circumference (inches): 37.5
    Jul 2013
    Greetings,
    Try lower inflation pressure in the tires. Maybe switch to a taller higher volume tire with a high thread count carcass, softer sidewalls, and run tubeless at reduced inflation pressure.
    edit (adding links):
    Inflation Pressure | Schwalbe North America
    Tire Dimensions | Schwalbe North America
    Frt Range, CO
    Reputation: pursuiter's Avatar
    I see this same issue on expensive LBS bikes, lightweights can't get the suspension soft enough to have it work. First step I would try is more sag, less air pressure. If that didn't work, I'd go a shop that knows suspension and see if they can tweak the suspension to work better for a 100lb rider.
  1. rear 4 link susp. newbie
    By aircargoo in forum General Discussion
    Last Post: 05-19-2013, 04:32 PM
  2. ECDM Tapered Steerer - rear susp.
    By specbill in forum Tandem Mountain Bikes
    Last Post: 04-08-2013, 04:47 PM
  3. Fantom DS rear shock question
    By Higgdiggy in forum Motobecane
    Last Post: 06-29-2011, 10:43 PM
  4. NRS 3 - Upgrade fork and rear susp
    By jertel in forum Giant
    Last Post: 04-27-2011, 12:28 PM
  5. 08-09 Sanction/Force Rear susp. Setup...
    By sickspeed16 in forum GT
    Last Post: 10-20-2009, 11:18 AM
