Results 1 to 2 of 2
    Fantom 29 Crank Length?
    I just placed an order for a 19" Fantom 29. One of the first things I want to do when I receive it is to convert it to a 1X9. Instead of pulling off the inner and outer rings, then installing a bash ring, I was wanting to replace the crankset with a true single speed crank. Does anyone know the crank length of a Fantom 29?
    Oct 2007
    175mm is the standard crank length found on most all mountain bikes. Some manufacturers spec shorter cranks on smaller frames. But I would be very surprised if a 19" bike did not have a 175mm crank. But I don't own one, so you may want to wait for someone who does to answer.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
