Results 1 to 9 of 9
    Feb 2013
    Straight 6 rear brake
    Other than Hayes, is there any other brake that will fit this bike? (Rear brake). Thanks John
    smell my finger
    Reputation: joemamad's Avatar
    Look into A2Z adapters, 22mm - 54mm I.S. This adapter will allow you to use modern disc brakes set up for 185mm rotors. I have used this adapter and it works fine. -- Joe
    Feb 2013
    Thanks Joe. I think I may have to make a custom mount. I am going to using Hope Mono 6 calipers front and rear. Don't no if I can even get it to clear the rear linkage. Thanks again. Later John
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    just some food for thought, I'm running a direct mount rear caliper on my Homegrown with the Stroker Trial master cylinder.
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    smell my finger
    Yeah, if you have an early Straight 6 with the pull shock you will have clearance issues. The brake mounts onto that isolator link connected to the chainstay, right? The newer rear dropout style on the "Gen 2" mounts the brake on the top of the rear dropout. That stroker conversion looks like a good idea.
    Feb 2013
    Does anyone have a picture of a rear brake mounted to an early pull shock six. The bike pictured above (red bike) uses the new style 22mm caliper, it does not work on my bike. A little help please. Thanks John
    Reputation: Rocket88R's Avatar
    Jan 2013
    Slow86gn, can you post a picture of the what you have? I have seen the early S6s but it would help to see your set up.
    Feb 2013
    In all 3 pictures the newer Straight 6 brake arm is on top. Everything about it is different. It uses the 22MM caliper everybody was talking about. The early model did not.
    Jan 2013
    Ah... You got me. I have not seen this before. Very intersting though. Looks like a custom project to me.
  1. Correct headset for 1.5" straight to 1 1/8" straight steerer?
    By Muffinhead in forum Beginner's Corner
    Last Post: 09-10-2012, 03:58 PM
  2. Q about Rear Frame Alignment?? is mine straight
    By 29or6to4 in forum Frame Building
    Last Post: 05-07-2012, 04:50 PM
  3. Straight 8 Rear Axle Question
    By CTB in forum Mongoose-Schwinn
    Last Post: 08-19-2011, 11:41 AM
  4. Disc Brake Conversion - rear stay brake line?
    By RBatsch in forum Litespeed
    Last Post: 04-03-2011, 02:50 PM
  5. Straight 8 rear hub/wheel
    By Sp4rt4cus in forum Mongoose-Schwinn
    Last Post: 03-14-2011, 03:00 AM
