Results 1 to 30 of 30
    Reputation: Rocket88R's Avatar
    Jan 2013
    Straight 6 and 4 Banger overhaul
    Within the last 30 days, I have managed to buy a 2001 Straight 6, all OEM in good shape and a 4 Banger (frame only). So now I am in the process of overhauling them both.
    History: In 2001 I bought a Rocket 88 Stage 4 from REI in Austin Tx. Bottom of the line, it was the most I could afford. What I really wanted was the Straight 6 right next to it. I road the wheels off the rocket for years. A few months ago, surfing the web (where else does inspiration come from these days....) I found a Straight 6 for sale on Craigslist in Denver CO. A few days of emails, text and phone calls and the deal was done, the bike in the mail. A day or so after I finished the S6 deal, a 4 Banger came up on CL in Austin Tx. By that time, insanity had set in and the S6 needed a buddy. So deal made, frame in the mail. Let the insanity begin!
    Now, I am wallowing in the fun of overhauling and upgrading the S6. The 4B will benifit from lessons learned on the S6 in a few months.
    The first place to start is in the suspension. Last night I worked on pulling the suspension bearings with toools at hand-sockets, some washers and a piece of all thread. Worked well so far, Real World Cycles were sourced for new bearings. When they get here, I will reverse the process and install them.
    I will work on pictures this weekend.
    Welcome to the Schwinn Sanitorium!
    Stay tuned.
    R88R
    Jan 2013
    A week later. I have replaced all the suspension bearings in the Rocket 88. Overall it was pretty easy. A few months ago I found a Fox VanillaR rear coil shock. The stock rear shock was a straight vanilla, so the R would add rebound adjustment. Unfortunatly, it was 1/4" long (6.75 vs 6.5) and it mad the lower pivot bar rub on the bottom bracket. So, I took the time to modifiy the lower pivot bar by removing some metal so that the new shock would fit. Mission success! Works like a champ now. Now, I need to move on to the S6 and 4 B bearing overhaul.
    Jan 2013
    I did take the 4 Banger appart and quickly realized that I might need some advice to put it back together.
    CTB, if you are out there, I remember reading in a thread that you have replaced all the bearings in your 4 Banger and the bushings. Can you give my some direction on where tomfind the bushings and how to reassemble the upper pivot for the CF swing arm?
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    I'm here. I can't reply right now, but I will. If I don't, PM me for sure!
    Short answer: I got my bushings (not the bearings) from a place called Igus. They were nearly perfect - I just had to sand down the inner face a bit to get the shock trunnion to fit freely. I think I have the part number at home. I got all my bearings from Real World Cycling.
    Jan 2013
    CTB, I am so junior around here I can't PM or email anyone yet. I need to bump my post rate a bit. I got the bearings from RWC. Got that from a previous post of yours. I will search IGUS for the bushings. I need to find a picture host so I can start to post pics.
    The S6 is easy to reassemble, so it will be first. Then the 4B. Can't wait. How is your 4B doing?
    Jan 2013
    So, anyone know what the ID on the headtube of an S6 or a 4B is? Looking for a new headset. I don't have the tool to puch out the old one yet.
    Jan 2013
    So, here is a glimpse of my Straight 6 and my 4 Banger finished and ready to go.
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    aww the Homegrown 4Banger... oh' how sexy you are you sexy sexy girl you :* .. luckly the neither the 4banger or S6 have the ICBM headset so you can get pretty much any 1 1/8th head set you want. I"m a fan of Chris King but there are several other options. To get the old cups out, take a punch and hammer, lightly tap the inner cone from through the head tube and it / they will pop out. No special tools needed. Now getting the new headset pressed in, that might need the the headset tool
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    CTB
    CTB is offline
    Looking good.
    Jan 2013
    Cool-blue Rhythm
    Update to my 4/6 Banger project. Nothing dramatic.
    I upgraded my stem and bar to a Raceface Deus set. Stem-90mm, bar 680mm. The stem is shorter and the bar wider. I like it. I also upgraded the fork lockout. RockShox makes a lockout with a tension nob that lets out make compression adjustment instead of the on/off (no compression or locked out). That is actually the nicest thing I have done.
    Cockpit is much nicer now.
    Since I am running a Fox Vanilla R with 2" travel, I figured I would just put my Straight 6 swingarm on there too. Truth in advertising.....
    Some stats:
    HTA-at 85mm, 71 degrees/at 130mm 68 degrees
    Note: I have a RS Recon 351 with UTurn Travel adj. 85-130mm. I run about 120mm for about 68.5 degrees.
    BBH-353mm/13 7/8"
    WB-1110mm/43 5/8"
    ETT-607mm23 7/8"
    SoH-744mm/29 1/4"
    ST-483mm/19"
    Weight-13.74kg/30.15lbs
    Rear shock set at 140mm/5 1/2" I2I. That was not intentional, that is where it ended up with the best wheel base to head tube angle fit for me. Funny though, that is pretty much what Schwinn specked it at originally.
    Just one more for the road....
    How wide of a bar is that?
    Jan 2013
    That is a 780mm bar. I wrote 680mm in the original post but I know that is wrong.
    Nope-it is a 680mm bar. I was right the first time.
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Feb 2014
    Oddly enough I have an almost identical pair of bikes to yours, Rocket88R, in terms of color. I think we both caught the Lawwill bug bad.
    2001 Schwinn Straight 6 16"
    Chris King headset
    Rock Shox Recon 351
    Mavic Crossroc UST Disc
    Kenda Nevegal tubeless 2.3" tires
    Shimano M775 XT disc brakes
    Shimano M952 shifters and derailleurs
    Shimano XT cassette
    Raceface Turbine ISIS cranks with RF and Blackspire chainrings
    SKF ISIS BB
    Crank Bros 1st generation Eggbeaters
    Thomson Elite 26.8mm seatpost
    Raceface 100mm 5 degree rise stem
    Easton Monkeylite SL handlebar
    SDG Ventura Comp Ti saddle
    Yeti grips
    1999 Schwinn Homegrown 4Banger 19"
    Chris King headset
    Marzocchi Shiver SC
    Mavic Crossmax ST Disc (20mm front hub)
    Kenda Nevegal tubeless 2.1" tires
    Shimano M775 XT disc brakes (203mm front and 180mm rear)
    Shimano M952 drivetrain with M953 cassette
    Kore Elite 90mm 0 degree stem
    Easton Monkeylite DH handlebar
    SDG Aliso saddle
    ODI/SDG Lock-on grips
    The bike needs to go to a LBS for finishing up as I don't have some specialized tools. Otherwise the spec is pretty much there.
    This pair of bikes are on opposite sides of the world; when they get reunited there will be some component swapping going on as I reckon the 4banger is more suited for XC/AM while the Straight 6 is more suitable for mucking around. The Straight 6 is actually a little too small for me, and I suspect that the Homegrown is a little too long. I usually ride 17-18 inch medium frames (large if it were a Cannondale). I'm always on the lookout for the perfect frame - then it would be a simple matter of just swapping the components over.
    Jan 2013
    Cleong,
    I have a 17' 4 Banger in the exact same color as your 19'. I would be interested in trading if it would fit you better.
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Feb 2014
    Where are you located, Rocket88R? I'm in Connecticut. I'll give my bike a try and see how it fits me before considering a trade though. If it is really too large I would entertain the possibility of swapping/
    Jan 2013
    I am down the road in Springfield VA. Sounds good. I have no imediate plans for frame.
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Jan 2013
    Update
    More work on the S6:
    Frame: Schwinn Straight 6 -18
    Fork: Rockshox Sektor RL/150mm
    Rear Shock: Fox Vanilla R 500lbsx1.96
    Wheelset: Easton Havoc with Stans Tubeless setup
    Front Tire: Continental Mountain King 26x2.4
    Rear Tire: Maxis High Roller 26x2.35
    Handlebars: Gravity Gap 28
    Grips: No name Lock
    Stem: Specialized 12 degree adjustable 70mm 31.8
    Seatpost: Gravity Dropper 2", 26.8 post
    Shifters: Shimano XT 1x9 speed
    Rear derailleur: Shimano XT Deore 9 speed Long cage
    Cassette: Shimano HGX 9 speed 11-34T
    Chain: Shimano HGX 10 Speed
    Brake levers: Hayes MAG Hydraulic
    Brakes: Hayes G1
    Rotors: Hayes 203mm front 160 rear
    Crankset: Shimano XT 175mm 32 Narrow/Wide Raceface
    Saddle: Specialized Phenom
    Pedals: Blacklabel
    Weight: 30.6 lbs
    Straight 6 and 4 Banger overhaul-s6-sept-14-cockpit.jpgStraight 6 and 4 Banger overhaul-s6-sept-14-rearview.jpg
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Jan 2013
    Not to forget the 4 Banger
    I changed to a 2x9 with a bash guard. But the biggest mod is the Frankenfox Vanilla RC shock.
    I took a Vanilla RC and replaced the 2.75 travel shaft with the 2" shaft from my Vanilla R. I had to put a Schrader valve on the remote IFP chamber so I could fill it. Lots of research on line produce a Fox Manual and an equation to calculate the depth to set the IFP piston in the chamber. So far it seems to be working. I will be experimenting as I become my own suspension service.
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Nice work with the Frankenshock!
    Jan 2013
    Quote Originally Posted by bad mechanic View Post
    Your contribution helped.
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Jan 2013
    New year update-4 Banger
    Changed out the Rock Shox Recon fork (85-130mm) for a Fox Float 32RL (130mm). Lost 1.5 pounds, and the fork performance may even be better. Replaced the 90mm RaceFace stem with a 40mm Spoon stem. That might be too drastic but I am looking forward to riding it for a while. I built the wheels with DT Swiss Onyx hubs and WTB i23 Frequency Tubeless rims. Changed the tires to Continental Race Kings Protection, run as tubeless, and replaced the seat with a Specialized Phenom.
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Jan 2013
    New year update-Straight 6
    Installed a Frankenshock (with a 500 lb spring) on the S6. I have the parts to build one more shock for a spare or I can run on it on another frame I have. I also replaced the 70mm Specialized stem with a 50mm RaceFace D2. The D2 is way overkill as I am not planning any DH adventures anytime soon, but it was only $20 on CL and I wanted to try a 50mm stem-so here we are.
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Jan 2013
    4 Banger Bass Boat Blue Mixer-27.5" Front/26" Rear
    Got inspired by the Foes 29/27.5 Mixer. The fork is a Rockshox 29" Reba RLC Ti. The 29" fork gives the 27.5" wheel lots of clearance and puts the HA at about 68 degrees. I am running a 1x9 so I converted the front shifter to run the Gravity Dropper post. The front axle is about 1" higher than the rear axle. The bottom bracket is at 14.5". That is high by modern standards but it still rides really well. It is super fun to ride and surprisingly different from my other 4B set up. So far, I really like it.
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Jan 2013
    4 Banger Bass Boat Gold: A more modern All Mountain interpretation
    Moved the Rockshox Sektor over from the Straight 6. The Sektor is dual position: 130 and 150mm travel, which will vary the HA between 67 and 69 degrees. The upper pic is with the fork at 130mm, the middle pic is with the fork at 150mm. I running a 1x10 (30x11-36), so I converted the front shifter to run the Gravity Dropper post. Put 2.4" Continental Tires front and back. This set up is really versatile and is my go to ride.
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Building up a 27.5" Homegrown hardtail is still on my list of things to do.
    CTB
    CTB is offline
    SOMEDAY I'm going to actually build my 275 Sweetspot concept. It was supposed to be done by now...
    Jan 2013
    Straight 6 and 4 Banger overhaul-4b-bbg-nos-side-2.jpgStraight 6 and 4 Banger overhaul-4b-bbg-nos-rear-1.jpg
    Found a NOS front triangle-never had a BB or headset installed. Built last weekend, first ride yesterday. This is a 21" frame. I have found over the last 3 years for building, rebuilding, riding, measuring, riding some more that the top tube (really the reach measurement) turns out to be the really important (not surprising that it is a focus on modern frames). This frame has ~430mm of reach, about 30mm more than my other two 19" frames. It has a longer wheel base with about a 66.5 HA. All that makes descending easier and climbing more stable. But the trade off is no dropper post. While the large frame has plenty of standover height, the seat post tube is too tall to take a GD dropper post. There might be a work around but it would involve cutting the frame; not something I plan to do. The 1999 4B design will let you ride one frame size up with enough standover to be comfortable. Then you can use a short stem to get the same or better cockpit room. Overall, I am very happy with the way this turned out.
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Jan 2013
    Update to the 4B BBG 21" NOS Build
    Added a Gravity Dropper seat post. Put a 27.5 wheel in a Reba RLT Ti fork with 27.5 lowers. It rocks!!
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Jan 2013
    Fork is now a Rockshox Revelation RLT 150mm Dual Air CSU mated to a Sektor lower with a 27.5 front wheel. The air spring as a new cap that accepts RS tokens.
    _______________
    Schwinn:
    1999 46 Banger-21"
    27.5 Front/26 Rear
    Banshee :
    2015 Phantom-L
    27.5+ Conversion
    Your shed is like a 4 Banger Skunk Works.
