Results 1 to 9 of 9
    Schwinn Sweetspot geometry?
    Does anyone have a geometry chart for the original Schwinn Homegrown Sweetspot? The one with the ball bearing pivot, and not the hollow bushing pivot.
    Did the geometry change between the 1995 suspension frame and the 96+ frames?
    I've looked around, but haven't been able to find it anywhere.
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    BMech, I'll try to remember to check my archives tonight. I have all catalogs from '95 to '01, so hopefully there's a geo chart in the earlier cats. I believe it stayed the same, but I will try to check for you.
    Unfortunately, none of those are for the 1995 Homegrown Sweetspot.
    CTB, thanks, but I lost the auction last night , so no need, I guess. Thank you again, though.
    Sorry to resurrect this thread, but it turns out the geometry for the frame would, after all, be useful.
    Check out BonusTomato.com
    Crazy about Homegrowns
    Reputation: blue72beetle's Avatar
    The specs for 96 show the frame that is similar to the 95 frames. Especially the rear triangle.
    http://www.bonustomato.com/web/files...fications2.jpg
    CTB
    CTB is offline
    BMech, will this help? This is from my '96 catalog, even though the '96 HG Suspension bikes had the later rear triangles on them. The '95 catalog doesn't have any geo charts.
    Attached Thumbnails Attached Thumbnails Schwinn Sweetspot geometry?-hg-geo.jpg
    Quote Originally Posted by CTB
    Yeah, I didn't remember them having a geometry chart in them, but I figured one might exist somewhere. Grr.
    On a completely unrelated note, I just picked up a second '99 Homegrown Pro frame to hold as a spare. To my intense joy, it came with a vintage Easton EA70 in 26.8 which will work lovely on my Sweetspot.
