Results 1 to 6 of 6
    Rebuilding a Fox Alps shock
    This is my final draft for rebuilding and modifying a Fox Alps shock. While it's on the thread I started on the suspension forum, I wanted to drop it here as well since the sweetspot used the Alps, and was my original motivation. Hopefully it'll be useful to someone.
    Let me just say, the Alps shocks are very sensitive to oil level, and like to be serviced regularly.
    Attached Files Attached Files
    Crazy about Homegrowns
    Reputation: blue72beetle's Avatar
    I have absolutely zero knowledge of how shocks work, what all the parts are, etc. But this looks like I will be able to rebuild mine when the time comes if I just follow your instructions.
    Jan 2013
    I have a used 5R for sale. It's off my 1997 Klein Mantra Race and I have to say it's been used for pretty much all of the 15 years since without any servicing of any kind *ahem*.
    Shock goes up and down, does have some damping but it's sticky and makes a liquid squishing sound. Also you can hear liquid sloshing when you shake it. Also after I clean it it doesn't take long to build up a bit of oily gunge around the bottom of the shock (leaking down from the piston).
    Other than that there is very little wear - bushings are still good, no visible scratches. I got a rockshox mc3.3 to replace it and it seems to be an acceptable subsitution.
    If anyone wants it for parts then I dunno - $25 plus postage seem fair? PM me or I'll put it on ebay. This is only my third post so I'll try and get this across a few threads as I know a few of you are always on the lookout for parts/spares.
    Feb 2013
    Anyone a source a source for the tri-lobed tool needed for this ALPS 4, or a suggention as to a subsitute?
    Thanks in advance.Rebuilding a Fox Alps shock-alps-4-shock-tool-tri-loged.jpg
    Worst comes to worst, buy the right sized socket and go to town with a Dremel and cutting wheel.
    Feb 2013
    Installing the blue-green slip ring on a ALPS 4 shock
    The blue-green skip ring on a ALPS 4 shock can be a real ***** to re-insert into the cylinder, especially if it is slightly stretched - in fact, it's more-or-less impossible.
    Well… after making myself half-crazy attemping this step, it turns out it’s a piece of cake.
    Put the assembly into the freezer for 10 minutes, and it contracts enough so that it will literally DROP into the cylinder.
