Results 1 to 13 of 13
    Reputation: 8valvegrowl's Avatar
    Otero seatstay/chainstay bushing/bolt
    Does anyone have a source for these? Not having much luck. This is a brand new unbuilt 2007 frame and one bushing was snapped when I received it.
    What are its measurements?
    I'll try to measure it/take a photo this evening when I get home. I guess the best way to describe it is that they are like a sex bolt/chicago bolt with allen key sockets on either side.
    If you have the measurements, you can usually find a replacement. Bike companies like to use off the shelf hardware since it's cheaper. You do, however, need to take exact measurements.
    Looks like 10mm body diameter with a 12mm shoulder diameter. 19mm length in-between the shoulders (23mm length overall, so 2mm shoulder width). The threading looks to be M6x1.0.
    Please update this if you find sources. I had a similar problem though involving the shock hardware. I tried getting help from Mongoose but was pretty much told that they do not deal with such problems. Scouring the net has been futile for me.
    Will do...Pacific/Mongoose/Whatever Customer service told me the same thing...they built this frame until a year or two ago, you'd think they'd have spares. Sheesh.
    Reputation: faceplant72's Avatar
    Quote Originally Posted by discombobulated_conundrum View Post
    second that. My bushings are probably on there way out and a known source would be nice.
    Thanks in advance
    Totally bummed at Mongoose's customer service.
    I guess a visit to a machine shop is my best bet. Have them turn a few bushing and use standard bolts to hold it together. Mcmaster Carr here I come again.
    I ended up drilling out the threaded male portion and holding it together with an M6 x 1.0 socket head. No luck whatsoever on sourcing new ones. You'd think they'd have a large amount of spares of things like bushings, bolts, and hardware, especially for a frame design that was in production several years and only went out of production recently. Sheesh.
    Uly
    Uly is offline
    Im not sure if you saw this in past posts, but a few people found the stock bushing-bolt on teocali supers inadequate to take the beating of aggressive riding (snapping), so they replaced the bushing bolt with a hex bolt, nut and a couple washers. The hex bolt had a unthreaded section just long enough to clear the bearings (19 mm in your case). I did this on my '06 teocali super, but had to cut down the threaded section and chase it with a die. Worked great until the bike died.
    Yeah, I sort of did that with the broken bushing bolt. I am waiting to hear back from my LBS if they can source an alternative.
    No dice on an alternative...luckily that pivot point has very little movement, so I guess I'lm gonna go use common hardware to fix it up.
  1. seatstay vs chainstay mounts
    By vqdriver in forum Brake Time
    Last Post: 09-14-2011, 11:03 PM
  2. 5 Spot Seatstay and Chainstay
    By SCUBAPRO in forum Turner
    Last Post: 03-17-2008, 06:37 PM
  3. 02 - 04 Enduro Seatstay and Chainstay
    By jason8265 in forum Specialized
    Last Post: 10-18-2007, 03:08 PM
  4. Moment chainstay / seatstay color
    By yangpei in forum Ellsworth
    Last Post: 05-01-2006, 01:04 PM
  5. enduro chainstay/seatstay alignment
    By gregm in forum Specialized
    Last Post: 05-23-2004, 03:03 PM
