    Mongoose bottom bracket removal
    I apparently need a bottom bracket tool to remove it but I don't see where I would insert the thing.
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    i recommend going to your local bike shop. if you notice on one side there are two flat spots, and the other side is oddly shaped. those are the spots the tools will grab onto. i believe this kit will have what you need to remove the BB. : Brand New! Home Mechanic Bike Bicycle Tool Kit!: Amazon.com: Sports & Outdoors
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    In your last photo, the allen head bolt for the pivot point can be seen. Do you know if there are bearings behind that or a bushing?
    My Ride: I've upgraded so many parts I don't know what it is anymore!
    Use a big adjustable wrench to remove it.
