Results 1 to 6 of 6
    Nov 2008
    Help Finding Frame Bearing Kit
    I have a 2009 Mongoose Boot'r that is my GF's and I found the lower linkage a little loose, so decided to take the screws out and lock tight to ensure it's not going to come apart.
    Well, I found the bearings are shot. I am going to email Mongoose, but is there anyway to buy a kit for the bike? Does anyone have the bearing sizes, so I can order them and build a kit. I would like to change them annually; as we race in the mud a lot. Any help would be awesome.
    Thanks,
    Calvin
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    You should be able to read on the side of the bearing the model number/ID of the bearing. You can order replacement bearings here:
    http://www.enduroforkseals.com/id169.html
    Nov 2008
    Thanks for the response. Yea, I tore apart the front hub on same bike and nothing on them. Hopefully the frame bearings have numbers.
    Big thing is; I was trying to get them all together before I started to tear down the bike, but I might have to go this route if no one has the listing.
    Look at the seals on the bearings, they'll most likely have a 4 digit number on them, usually starting with the number 6. Once you have that, you can order bearings from http://www.mcmaster.com.
    Nov 2008
    Thanks for advice to all. I actually talked with my local shop and they said they would do the work and use Enduro's for a really good deal. I am just going to do my part and support my shop who orders all my parts.
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    I've put Enduros in my bikes, and so far I'm happy with them. So you get to support Enduro and your LBS in one move. Cool.
