Results 1 to 5 of 5
    Front derailleur for Mongoose Grand Marquis
    I am beginning to assemble the GM, but now have found the front derailleur I bought is not working! I havev an SRAM X-Gen top pull bottom swing seat tube mounted. Due to the S-bed on the seat tube, the derailleur does not line up right to the big ring.
    Do I need to go with a derailleur that mounts on the bottom bracket? Or is there something else that works? Thanks!
    geek
    Reputation: coffeegeek2112's Avatar
    I put an xt top pull, top swing I think 31.6 on the seat tube. Works perfect.
    Thanks for the info!
    Quote Originally Posted by coffeegeek2112
    I found that my SRAM X-Gen is a high clamp, and by the looks of your pic I need a low clamp. Thanks again!
    geek
    Nov 2007
    So you have to use a top swing with this frame ?
    Yes. Top swing, top pull.
