Results 1 to 14 of 14
    Reputation: TrailBurner's Avatar
    Fox Coil Shock for 4Bangers
    Hey all,
    I was browsing around, and found what might be a Fox coil shock that can be used to convert the 4 bangers into a straight 6.
    Check out this link:
    http://store.icyclesusa.com/Product333
    Recession buster special after adding it to your cart = $69.99
    The picture indicates that it'll fit with the trunion mount, but I don't know for sure.
    So if anyone was interested in trying out something different for their 4 Banger, you might want to check this out while they're still available.
    Cheers,
    Mark
    ****edit****
    I just checked again and it says the product is discontinued. It seems to be intermittent.
    Sorry.
    ****edit no. 2*****
    I just checked again, and they're showing to be in stock for $69.96 after adding to your cart. Wow!
    Person
    I think Fox uses a different thread pitch on the shock body so the trunion will not mount on it.
    Could be.
    I know that Fox was the supplier of the shock for the last generation of the Straight 6's. (The yellow ones in 2000 or 2001?)
    I myself have the Fox Vanilla R on my 4Banger and I could swear it looks like that one in the picture!
    I wonder if there is some way to check it out without just buying it and physically trying it on the bike.
    If I had extra cash, I'd buy that shock in a heartbeat and send it to Push Industries. The Fox coilover transforms any 4Banger into a much better bike.
    Person
    Quote Originally Posted by TrailBurner
    Could be.
    So the Fox worked with the stock 4Banger trunion?
    I found a longer Rock Shox shock for my 4Banger last year, a big improvement over the original (no rebound adjust). But am curious about what a Fox would be like, lots of cheap used ones on ebay too if you look around a bit.
    smell my finger
    Reputation: joemamad's Avatar
    I've seen a fox with a rockshox trunion that was "drilled out" or the threads filed out and then sandwiched between 2 spring collars to keep it in place. I guess that's an option. I think it's in a thread here somewhere. The diameter of the body of the 2 shocks is very close but the thread pitch is different between rockshox and fox. I cannot tell you if the oem fox shocks on the straight 6 have the right threads for a rockshox trunion, though.
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    4Banger rear-shock up-grade: the Risse Racing Jupiter5. i had no problems at all, i took many big drops and nasty rock gardens with no issues what so ever and i highly recommend it for all 4 banger owners, Risse Racing has all the parts still in stock. just have to call for the custom order and will take a few days-week for assembly. well worth in my opinion. 541-526-7242. i just called to confirm @9:55'ish am 25 Aug and yes, they still have the goods to make the shock for the 4banger and i'm sure the '01 straight6.
    http://www.risseracing.com/coilshocks.shtml[/QUOTE]
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    Mar 2005
    I bought (errr ... wasted $50) on a Fox vanilla thinking that the trunnion would fit. Negative.
    Feb 2006
    edit...
    '11 Jedi
    CTB
    CTB is offline
    Reputation: CTB's Avatar
    The trunnion is pretty simple overall. Perhaps you can have a local machine shop make you one? You could give them the Rock Shox one for a pattern, and they could thread the trunnion for the Fox thread and get you going.
    Person
    This shock will work for anyone that already has the trunion, plus will convert your 4 banger to a straight 6. Not my auction, but I do have the same shock on my homegrown.
    http://cgi.ebay.com/Rock-Shox-Deluxe...item3363a0e6e8
    Mar 2005
    Thanks for the heads-up Baulz, I got it for $32.
    Person
    Quote Originally Posted by EHPhillips
    Cool! You may need a stiffer spring, I have a 500 on mine. Would like to try 550. I weigh 175ish.
    Reputation: tartosuc's Avatar
    delete
    Reputation: DECIM8's Avatar
    I apologize in advance for resurrecting such an old thread. I felt it was better than starting a new one.
    Does anyone know where I can find the trunion for mounting a Fox Vanilla shock to a 4 banger/straight 6? I have a Vanilla R on my 4 banger right now but I know there are a few other people looking for one and I wouldn't mind having a backup.
    Quote Originally Posted by Baulz View Post
    Looks like its in stock per the link below. 600lb. spring. Chain Reaction Cycles has one with an 800lb spring in stock, I just picked one up. The price for the shock and spring is less than my LBS wanted for just a spring.
    Fox Shox Vanilla Shock 600x1.63
