    DHX shock on a '07 teocali - Is it possible to install?
    Before actually measuring, it looks like there's no enough space for the external reservoir. Has anyone seen a setup like this?
    Mar 2006
    I got one om my Teocali 05 M/18". Its a customized (stroke). Progeressive 5th Element coil. Its equal to a DHX in size I think.
    Reputation: 02_NRS's Avatar
    rear shock?
    what weight coil spring are you using+how much do you weigh?also plan on going with a coil but don't need a dozen spare springs.maybe you can save me $$$.thanks.ps I weigh 180.
    Mar 2006
    I've been using a 275 spring. It made for a plush ride but were way to weak for hard riding. I'm 170-180. I believe a 350 might be more acurate. Any well sorted LBS is to have a spring replacement program.
    Due to the linkage, I believe the Teocali shall have a slightly weaker spring than according to the tables.
