Results 1 to 36 of 36
    4Banger Owners - Shock mount idea for modern air shocks! Experiment is GO!
    As discussed in my other thread, I have an idea to make up some new shock mounts for the 4-Banger to accomodate modern air shocks with different eye-to-eye and stroke length, therefore making it easier to customise your BB height, head angle and travel of your 4-Banger, as well as run a modern shck with more tuning options available.
    First, I gotta buy one (looking at one this weekend)
    So yeah, if you had the choice of any air shock, what would it be? and why?
    And would you be looking to increase the travel to 5 or 6 inches for eg?
    CTB
    CTB is online now
    Reputation: CTB's Avatar
    I may as well weigh in here as well.
    Fox RP23. Not because I want the pedalling platform (I'd turn it off), but just because it is modern and I like the feel of Fox dampers. I have a 2004 Float RL on my bike now, I never use the lockout, and it has permanent Pro-Pedal, which I don't need for my style.
    I'm running my bike at 4.7" travel now, and that's quite good for where I live. I'd possibly go to the full 5" if I could, but I don't need 6" for trail riding where I live.
    Here's what I was thinking.
    Found this while eBaying that prove's my concept.
    Providing the stroke length was similar, we should be able to install any shock we like.
    Fox shock with remote 'brain' inertia valve anyone?? ;-)
    CTB
    CTB is online now
    Very interesting, Bellsy. That's what I had envisioned in my head, but I was never sure it would actually work.
    Well... I now own a 4Banger (pics and details to come tomorrow in a separate thread) and I just bought a 38mm stroke Rockshox Monarch 4.2 from CRC so the experiment is go!
    Quote Originally Posted by Bellsy
    Yes, very much yes!
    Very much no.
    CTB
    CTB is online now
    Quote Originally Posted by bad mechanic
    Very much no.
    So I'm not the only one.
    Quote Originally Posted by CTB
    Have you guys ridden them? I've had 2 Speshy Epic's now both with the inertia valves. Loved them! Pedal amazingly well. They feel alot like a hardtail to ride, just without the harshness over the med-large bumps. I only have good things to say about the system. especially for XC and endurance racing.
    CTB
    CTB is online now
    I had a couple rides on them at this year's 2009 bike demo in my area, though in fairness I didn't have time to really dial them in. I vastly preferred the ride of my 4-Banger. Any suspension bike will avert the harshness over med-large bumps; I care about the small stuff being erased, which is a large part of why I have a suspension on my bike. Spec makes good bikes, I'm just not sure their philosophy suits an in-the-sadlle, non-racer such as myself. I do agree it makes great sense if you're a racer. I wish I had one to test for a week or so to try and dial it in better.
    In case you think I'm overly biased to the 4B, note that I loved the Trek Fuel EX9.9 I rode that same day. Similar feel to the 4B with a lot less weight. Likely the bike I'll choose if I move to something other than the 4B.
    The Specialized Epic makes sense if you're a serious XC racer and every second counts. I am not, therefore, when I'm riding my full suspension bike, I want it to feel like I'm riding my full suspension bike. When I want the hardtail feeling, I ride my hardtail (which is what I'm usually on). Honestly, medium to big sized hits on my hardtail is not a problem, it's the small stuff which beats me up.
    I see why certain people love the inertia valve concept, but when I've tried them, it's left me completely cold. To me, it's almost the worst of both worlds; I don't get the plush ride of my FS, but I still have the complications and weight of it.
    There are enough fully active full suspension systems around which pedal really well (DW Link) without needing to resort to things like inertial valves.
    bump...did this ever work out?
    I'm also interested if this advanced any further.
    Very close to having it finished. My brother made the prototype and some of the hole centers were slightly out so I have to modify it slightly but it looks like working.
    Once I get it on and working well, he'll machine up a new one to suit and shave some weight off the design.
    Proto should be mounted and running within a week or 2. I just gotta get off my a$$ and onto the lathe.
    bellsy, are you on bonustomato with that beautiful blue/grey 4banger?
    Do you know the specs on the factory shock?
    CTB
    CTB is online now
    Sandwich, which factory shock, and what do you want to know? The Super Deluxe shock had the adjustable trunnion, and mine had a max length of about 128 mm eye-to-trunnion. The SID air shock used on my 2000 had a fixed lenth of 140mm eye-to-eye.
    What's the stroke? Varying threads have suggested 1.5 to 2.0". I'm looking for factory-spec 4banger travel.
    Yep, the Blue/Silver 4B is mine. I bought a 38mm stroke Rockshox Monarch 4.2 which was very close to the stroke length of the old Spuer Deluxe coil shock.
    The eye-to-eye is different though, and there's no trunion mount. Hense the new shock mount.
    I have a 24hour race next weekend so I should have the prototype all finished by then. Its looks ugly as sin, but once we perfect it, I'll have a new one made that'll look alot nicer.
    CTB
    CTB is online now
    Factory 4-Banger shocks are 1.5" stroke. Anything you see that refers to a 2.0" stroke is a Straight 6 shock (the second-gen Straight 6).
    Bump. Any progress?
    Absolutely zero progress made on this. I haven't been riding the 4B much at all. Wont take much work to finish off the mount though so I might have a crack at it this week.
    Because of the shape, it means mounting up the 4-jaw chuck on one of the lathes at work which is a pain in the a$$.
    On a tangent, what can a 4 jaw chuck do that a 3 jaw chuck can't?
    CTB
    CTB is online now
    We had to use a 4-jaw on my mount as well since it is quasi-rectangular in shape. Two jaws on the long sides, two jaws on the short sides. A triple couldn't properly grip it.
    Can each one of the jaws be adjusted independently?
    Yep, a 4-Jaw can hold anything with 4/8/12 sides etc. A 3-jaw is only good for triangular/hex or round shapes.
    My mount is 8 sided for different BB height adjustments ;-)
    And yes, on a 4 Jaw chuck, each jaw can be adjusted independantly so you can have eccentric shapes etc
    I'd be in for this. I'm currently running a 2.0" stroke Stratos, but I'm afraid someday it will break and I'll need more options!
    dude...i don't normally question peoples' rides, but get that monster off there! wtf are you doing with a monster on a 4.5" travel XC/trail bike? The headtube will snap long before the shock gives you any problems!
    Quote Originally Posted by sandwich
    The rear shock has 2" of stroke so the bike has just under 7" front travel and 6" rear travel. It's nicely balanced. It steers better than you'd expect too.
    I'm not worried, I've been riding 4-bangers for over 10 years on triple clamp forks and I've never had a problem. I don't jump foolishly and I don't abuse my equipment.
    Have you ever seen a Yeti made 4banger with a snapped head tube? I haven't, but feel free to post if you have.
    And why? Because it's a hoot to ride. Nothing is stiffer or more plush on the front end.
    Sorry duder, but yeti never made a 4banger, only the _factory_ hardtails and the straight-468 bikes.
    There are triple crown forks and then there is the monster...a sid XL or similar is a far cry from that hucking fork. I respect your choices, and if it makes you happy then do it, but I'd bet you'd be just as happy with a 66 or similar, if you feel you really need 6+" of travel on that bike.
    Well I fiiiinally got this mounted up today. Waited like 12 months for my brother to finish it off for me.
    Pics:
    CTB
    CTB is online now
    Cool, I've been wondering about this. How's it ride?
    Haven't had it on the dirt yet. Will report back as soon as I do though :-)
    that looks terrifically simple and well executed...nice!
    If there's interest, I will look at getting some more made up, although they will be even more simple :-)
    Wouldn't be worth doing unless I had an order for at least 5 or 10. The more I make the cheaper they get :-)
    First ride on the new shock and mount the other day at Mt Stromlo in Australia which hosted the World Cup in 08 and the World Champs in 09.
    All I really did to the shock was set the air pressure up to give the correct sag, then went and rode for a good 3-4hours on it.
    I rode everything from firetrails, the 4X track, and even sections of the 09 World Champs XC and DH tracks
    There's still a little pedal bob in it when I'm climbing out of the saddle but I think this can be improved by changing the effective eye-to-eye of the shock mount (which will lift the bottom bracket), and by tuning the shock slightly.
    Its completely transformed the bike though. With the Sid's up front, its become alot more balanced than it was with the old shock. There's less pedal bob and the damping works great and I'm not getting lifted off the seat while rolling over bumps while seated.
    I'm looking at making a few more up if there's interest.
    It'll probably be around $100 per mount for the current style, but I'm looking at designing a much simpler one which I could possibly make for around half the price.
    If I can get a group order of at least 10 mounts, I'll go ahead with it.
    CTB
    CTB is online now
    Any idea what your head angle is with this setup?
    Reputation: Rocket88R's Avatar
    Jan 2013
    Late to the party, but I take one if the build is still on.
    Rocket88 R
