Results 1 to 14 of 14
    Uly
    Uly is offline
    2009 Teocali Super Build
    This is a build that started due to a frame crack on my 2006 Mongoose Teocali Super.
    That story is here: 06 teocali frame crack
    Some parts are new, others will be swapped from the old frame. Here are the pics.
    The old bike. She was a good bike.
    The New Frame. 2009 model super
    The new parts
    Everything else will come off the old frame. I have already started the build. There are a few annoying things I have run into. One hurdle was that hardly any hardware came with the new frame. Performance Bike helped me out with this and they got me the rear shock bushings and bottom bracket cable guide.
    Another hurdle was that there were not enough ferrules that came with the Jagwire cable set so I had to order some. The catch is that the matching ferrules only come in bottles of 50 if you order on-line. The cable set comes with 3 endcap ferrules. 3 is what is listed on the package, but I need 4 to complete my project. 2 for each derailleur.
    I had a mishap with my 20mm maxle on the old bike. Somehow that got frozen on and I had to take a rubber mallet to it to get it off. But even with slight tapping from the rubber mallet, the maxle body gave up the ghost and I had to order another one. At least it came off without damaging the fork lower. I won't go into how it got that way, let's just say that I would never twist that maxle on there that tight. That's why its a QR, to keep from having to tighten it that much when screwing it on.
    I will update this post with the finished build.
    Reputation: mullen119's Avatar
    Love the rims
    Uly
    Uly is offline
    Quote Originally Posted by mullen119
    Love the rims
    Thanks, man. I like the strength and weight characteristics of those wheels. And aesthetically, they are just awesome.
    Please don't clamp frame tubes! Use the seatpost.
    Uly
    Uly is offline
    Quote Originally Posted by bad mechanic
    Will do, thanks for the advice
    Uly
    Uly is offline
    Finally!
    DONE! It's the missing/unplanned for small parts that'll kill ya.
    Spec:
    Color: Black/White
    Frame: Mongoose FreeDrive W/ 145mm travel
    Headset: Cane Creek 110 ZS
    Headset Spacers: FSA
    Fork: RockShox Pike 454 Dual Air, 140 mm travel, air spring, 20 mm thru axle
    Rear Shock: Fox Float RP23, air spring, three position ProPedal, XV air can, 200x57 mm
    Crankset: Shimano SLX M660 22/32T Hollowtech II, ethirteen bash guard
    Bottom Bracket: Shimano external bearing
    Pedals: Shimano Deore XT
    Front Derailleur: Shimano Deore LX
    Rear Derailleur: Sram X.9 medium cage
    Shifters: Sram X.9 trigger 27 speed
    Cassette: Sram PG990 11-34T (red)
    Chain: Shimano XTR
    Rims: Industry9 Enduro
    Rear Skewer: Hope QR (red)
    Front Hub: Industry9 Enduro 20 mm thru axle
    Rear Hub: Industry9 Enduro QR
    Spokes: Industry9 straight pull
    Brake Levers: Avid Juicy 7
    Brake Rotors: Avid CleanSweep-X IS, 185 mm F, 160 mm R
    Handlebar: Easton EA70 Monkey Bar, 31.8x20x680 mm
    Stem: Truvativ Team 6 deg. 31.8x90 mm
    Grips: Ergon GP1
    Saddle: SDG Bel Air RL titanium rail
    Seat Post: KS Cobra adjustable height w/ remote 31.6x350 mm
    Bottle Cage Bolts: Toronto Cycles
    Derailleur Cable/Housing: Jagwire Ripcord 4.5 mm
    Tires: Schwalbe Nobby Nic, 2.4 F, 2.25 R
    Total Weight: 31 lbs. 7 ounces
    Attached Thumbnails Attached Thumbnails 2009 Teocali Super Build-img_0850.jpg
    Uly
    Uly is offline
    A few more pics
    Attached Thumbnails Attached Thumbnails 2009 Teocali Super Build-img_0834.jpg
    Looks awesome! Better then mine lol
    Uly
    Uly is offline
    Thanks! This is the cleanest it will ever be in it's life time.
    Can't wait to get it dirty! Took it for a test and tune and it felt pretty smooth, but things still need to loosen up.
    Quote Originally Posted by Uly
    Have you weighed it? I feel like mine is a tank weighing in a 33.4 lbs. Doesnt ride like its that heavy though.
    Uly
    Uly is offline
    Yup,
    Clocked in at 31.7 on my home digital scale. Not an accurate scale, but in comparison, my 06 weighed in at 33 pounds on the same scale.
    Test and tune today. I don't know if it's the wheels or the tires but it felt like it was on rails and very smooth rolling. Still a little drag there but they say the I9s will loosen up with time. Climbed with very little effort as well. The frame felt much more solid and you could really feel the stiffness in the rear triangle compared to the 06.
    T&T day, unfortunately, soon turned into OTB day since I haven't been on a bike in 2 months and was tired and not concentrating on a little roller. Didn't lift the front end up in time and the front tire dug in at the bottom. Only damage was to the handle bars. Got a little scratched up.
    I would have saved on the i9 and put the money elsewhere.
    I guess I can live with 2.5 lbs heavier. Mine started out as a comp that weighed 35lbs, So i'm slowly shaving weight off with all the upgrades I have done.
    I love the look of the I9 BTW.
    Uly
    Uly is offline
    Eh, If mine were 2.5lbs more heavier, it wouldn't bother me (I know, easy for me to say, I'm 2.5lbs lighter). Thanks for the props.
