Results 1 to 13 of 13
    Mar 2013
    2008 Teocali build help
    I haven't had a bike since 1999 and I've been lurking here since March. I ended up picking up an 08 Teocali frame and fork at a bargain price I couldn't pass up. Now I'm in need of some help picking out what I need to complete it.
    I'm not looking for anything super expensive but trying to get the best bang for my buck. I don't see myself doing any major drops at this stage.
    1. Wheels:
    I had my eye on Mavic X317 disc or WTB Speed disc wheels. Thoughts?
    2. Brakes:
    I want hydraulic brakes but other than the bolt count to the wheel I don't know much more. Some of the wheels I've looked at have rotors already.
    Do I need to worry about rotor compatibility?
    3. Rear Cassette:
    Will any SRAM cassette work?
    4. Shock:
    I'd like to upgrade the rear shock to a Fox RP23 and believe the 7.5 x 2 is the correct size?
    Thanks for any help you can give.
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    1. Wheels:
    --- Mavic makes goood stuff. that's the route i would take
    2. Brakes:
    --most bolt patterns are universal 6bolt. Do the wheels come with rotors or do they just have them pictured for advertising purposes? I picked a set up from here for my hard tail! MOUNTAIN BIKE ROTORS | Moment Industries
    3. Rear Cassette:
    -- i would imagine yes, but that is also dependent on the rear hub. if the hub is set up for an 8 speed cassette you won't be able to put a 9 speed on. just make sure they match before purchasing
    4. Shock:
    -- you have to measure the shocks over all size(A] eye to eye length) and the stroke ( B] the length of smaller diameter cylinder of the air shock.) http://www.sicklines.com/tech-info/s...t_coil_top.jpg
    '11 Jedi
    '01 Rocket 88 Stage3
    2008 Toyota FJ Cruiser
    Reputation: Cobra8d's Avatar
    Aug 2010
    4. Shock:
    Yes
    Reputation: mullen119's Avatar
    not a 7.5 x2 rear shock. I had an 08 and its a 7.875 x 2.25 or 200x57. If you look at the seat stay on your bike, its is actually written on it
    Mar 2013
    Finally got to start the build. It took forever to get the frame from Seattle from my sister. For a large the frame is bigger than what I had expected.
    I still need to put on the new chain, rear derailleur and swap out the rear shock.
    Also, going tubeless was super easy with the WTB Frequency rims.
    Mar 2013
    All built
    I think I'm done with her.
    Got a 32 mile ride in today since we finally had some temps under 100.
    Did the forum dump a bunch of pics because a lot of the older ones I uploaded are now gone??
    Feb 2006
    Look'n good! sounds like it's a bit warm where you are at! lol... lots of water and SPF50! "Stay white all day"!
    '11 Jedi
    Nov 2013
    What were the parts you ended up going with? I just purchased a stock 2008 Teocali that the original owner maybe used 4 times, I know down the line I'd like to build her up for sure the rear shock, and possibly the front, I'd like to have a lockout. The tubeless sounds great.
    Mar 2013
    Here's the list of parts I went with:
    WTB Frequency i23 rims w/ SRAM X9 hubs w/ Stans rim tape and sealant
    WTB Bronson 2.3 tires (seem to be wearing fast)
    SRAM X7 rear derailleur
    Fox Float RP2 rear shock and 7.875 x 2.25 is the correct size for an 08
    UNO 80mm stem
    Truvativ Hussefelt 30 mm rise bars
    Avid Elixir 7 brakes
    Ergon grips (man I love these)
    Wellgo MG1 pedals
    SRAM PC 991 chain (Powerlink is slick)
    SRAM PG 980 9-speed cassette
    I think that's everything I updated. I've been meaning to take it into work to weight it but haven't gotten around to it yet. Maybe next week.
    Hope that helps.
    Nov 2013
    Were you able to re use the hardware and bushings on the Fox Float RP2? My SR Suntour finally gave out and want to get a new rear shock and wanted to know if the original hardware would work
    Mar 2013
    Nope, original hardware didn't work. Found my hardware on ebay they were 18.80mm width x 8mm from this seller.
    Mountain Bike Shock Eyelet Bushings 18 80mm Width x 8mm ID Fits Fox 803 03 039 | eBay
    Mar 2013
    I want to upgrade my fork and not a lot of non tapered options. I know I can use a tapered fork if the headtube has an internal diameter of 44mm with a pick and mix bottom headset cup. Anyone know if it's 44mm?
    Mar 2013
    It can be done! New tapered fork installed.2008 Teocali build help-20161121_143926.jpg
  1. 2008 S-Works Stumpy build
    By theZapper in forum Specialized
    Last Post: 07-28-2011, 07:43 AM
  2. 2008 Trance 2 build up
    By Light Man Mike in forum Giant
    Last Post: 07-04-2011, 12:09 AM
  3. 2008 Mongoose Teocali Comp
    By tsefreeflow in forum Mongoose-Schwinn
    Last Post: 07-03-2011, 07:31 PM
  4. 2008 Reign build
    By mrabe1979 in forum Giant
    Last Post: 04-28-2011, 06:03 PM
  5. The 2008 Avalanche (re)build
    By Bikin' Bric in forum GT
    Last Post: 04-27-2011, 01:49 AM
