Results 1 to 6 of 6
    not actually bad :)
    Reputation: bad_andy's Avatar
    '08 Mongoose Canaan Comp creaking pivots
    I bought a new '08 Mongoose Canaan Comp about a year ago.
    Have been enjoying it, and it does what I need it to!
    The pivots are starting to creak. Is there any maintenance I need to do?
    Or just replace them, or??
    Any help?
    Old Codger
    Reputation: mullen119's Avatar
    http://www.mongoose.com/usa/usaeng/mtn/tech
    Check that out. It gives decent information about maintenance. Check you bolts are tight. you might need to replace the bearings in the pivot behind the BB.
    not actually bad :)
    Quote Originally Posted by mullen119
    Thanks for the link.
    That's perfect.
    I took the main pivots out and greased them up as specified. That helped a ton. Still need to get to the other ones as there's still a little creaking, but 95% better already!
    Old Codger
    Good job on fixing the problem. This is way off topic but was wondering if you guys know how much the frame weighs?
    not actually bad :)
    Quote Originally Posted by ^warning^
    Sorry, I don't.
    Tried to find it for a few minutes online with no luck.
    Old Codger
    I weighed mine when I had it apart before but I dont remember the exact weight. I think it was just over 6 lbs. I think that was including a manitou X3 rear shock.
