• 07-13-2010
    bad_andy
    '08 Mongoose Canaan Comp creaking pivots
    I bought a new '08 Mongoose Canaan Comp about a year ago.
    Have been enjoying it, and it does what I need it to!
    The pivots are starting to creak. Is there any maintenance I need to do?
    Or just replace them, or??
    Any help?
  • 07-14-2010
    mullen119
    http://www.mongoose.com/usa/usaeng/mtn/tech
    Check that out. It gives decent information about maintenance. Check you bolts are tight. you might need to replace the bearings in the pivot behind the BB.
  • 07-20-2010
    bad_andy
    Thanks for the link.
    That's perfect.
    I took the main pivots out and greased them up as specified. That helped a ton. Still need to get to the other ones as there's still a little creaking, but 95% better already!
    :thumbsup:
  • 07-23-2010
    ^warning^
    Good job on fixing the problem. This is way off topic but was wondering if you guys know how much the frame weighs?
  • 07-26-2010
    bad_andy
    Sorry, I don't.
    Tried to find it for a few minutes online with no luck.
  • 07-26-2010
    mullen119
    I weighed mine when I had it apart before but I dont remember the exact weight. I think it was just over 6 lbs. I think that was including a manitou X3 rear shock.
