Results 1 to 3 of 3
    '06 teocali front derailleur??
    Out of the 5 spare front derailleurs I have tried, none fit my new '06 teocali elite frame. They're either too fat and jam up the rear triangle, or the mounts are too high/low. Do I need an E-type, or what exactly do I need?? All I can find for specs is that it usually comes w/slx but no where denotes much else.
    Uly
    Uly is offline
    The 06 teocali elite was pretty much the same as the teocali super frame design. My 06 super had a Deore LX FD. It was the low mount which is numbered fd-m590. I am actually still using it on my 09 super build.
    Thanks! I've only had 1 other reply on pinkbike, with no model #. This helps out a ton. Thanks again
  1. Replies: 1
    Last Post: 07-11-2013, 06:16 PM
  2. Sram x7 or x9 rear derailleur or SLX? SLX front derailleur?
    By pressingonward in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2009, 06:12 PM
  3. e-type front derailleur, downshifting issue, do they work w/ triple ring up front?
    By mmatador22 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-08-2008, 07:57 AM
  4. Front Derailleur Shim /derailleur to fit?
    By kawarider in forum 29er Bikes
    Last Post: 03-22-2008, 09:19 AM
  5. Front Derailleur with 2 Front Rings... to much space?
    By venture in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-30-2006, 11:28 AM
