Results 1 to 3 of 3
    pyroclastic flow
    Reputation: troyer2112's Avatar
    tires for Mayhem Enduro Race
    Which tires are best for the terrian at the Mayhem Enduro Race. I plan on getting some Nobby Nics Snakeskin 2.25. What do you think?
    "THE FACT IS THIS FRICTION WILL ONLY BE WORN BY PERSISTENCE"
    2009 PIVOT MACH 4
    The Nobby Nics are designed to be a pretty good all-rounder (I'm sure you already knew that). As long as its not muddy there are several tire variations that will work just fine. You can ask the trailbuilder himself what he would recommend at Home - HWB Cycling Sales and Service
    I think that would be a good choice. Might not be a bad idea to have some mud tires in the car just in case! I might just have to try a set of the Hans Damph's, if I can scratch up enough coin! I will have my Swampthings mounted and ready to roll.
