Results 1 to 3 of 3
    May 2013
    A very particular case!
    On the rear damper of my ML/7.5 (new version, edited by Ethan), O-rings mounted on the IFP, continues to lose air and oil!! After three attempts, I replaced the original O-rings with a special O-rings in VITON. Even with this o-ring, air and oil leaks. Ethan says that the damper tube is lined, inside. This causes the defect!!! It is very difficult to see inside the tube lines, because they're invisible! At this point, what should I do? Try again to change the O-rings? Or change the damper tube? To you, it's never happened this thing? How you solved the problem?
    Thanks, Simone, Italy
    Schipperkes are cool.
    Reputation: banks's Avatar
    Change the damper tube. The smallest of scratches or any deformation will cause blowby you hare having.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    May 2013
    Ok!!! I will try to buy the new damper tube. Thank you
  1. Just in case anyone is looking for one of these..
    By Marshall Willanholly in forum Turner
    Last Post: 11-27-2013, 10:50 AM
  2. Contour +2 (Case vs. No Case)
    By dnoyeb in forum Videos and POV Cameras
    Last Post: 05-13-2013, 06:12 PM
  3. In case you didn't know
    By kubaner in forum Massachusetts
    Last Post: 05-09-2012, 06:57 PM
  4. Map Case
    By cowboygrrl in forum Endurance XC Racing
    Last Post: 06-25-2011, 03:34 PM
  5. Case Mtn.
    By XC62701 in forum Connecticut, Rhode Island
    Last Post: 06-15-2011, 07:16 PM
