    Mar 2006
    Substitute for DUC32
    So I have finally dived into my piggy bank and treated myself in advance for the next few birthdays to a ML8. I'm going to build it myself but wanted to get a DUC32 fork but they're no where to be found for a while. Any recommends on the next best fork for a ML8 until I get my hands on a DUC32?
    Any suggestions would be appreciated. Also, if anyone else has built a ML8 on their own, did you encounter any issues or have any advise?
    rider
    In FTF We Trust
    Reputation: el-cid's Avatar
    Quote Originally Posted by rideronthestorm
    rider
    You probably don't want to follow my suggestion for a fork (I put a Totem on mine, pics following in a day or so), but I can give some input to the second part of your question. I just got mine put together and honestly it was one of the easiest to build frames I've assembled. The front derailleur/D-mount setup with the suggested R773 front derailleur (by far the best choice for the frame) is definitely out of the ordinary but isn't really any harder to set up than any other front derailleur. I used a small piece of Nokon housing liner under the MonoLink cable guide and it shifts smooth as butter. Overall, the frame's a seriously nice piece of hardware. Get one and enjoy it.
    "I'll disintegrate over time if I expect my body to try to keep up with my mind" -BM
    Race, Rocks or Road...Just Ride
    Schipperkes are cool.
    Reputation: banks's Avatar
    You can cut the outer sheath of a 4" section of Shimano 4mm SIS housing and get the inner liner to use on the MonoLink cable guide; works slick as tihs!
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    rider see your pm's
