Results 1 to 8 of 8
    Slightly unrelated fork guard question?
    Hi all,
    I need your help on a small issue i have encountered on a fork restoration i have finished.
    I recently acquired and renovated a (slightly rare) Marzocchi RAC inverted fork.
    See below.
    The obvious issue is the lack of lower leg protectors.
    Do you guys think that your lower leg protectors may fit if modified etc?
    You guys are my last port of call,
    Cheers Mike
    Schipperkes are cool.
    Reputation: banks's Avatar
    The Maverick parts are held by 2 small screws into the dropout knuckle. They are cheap @ $25/pair. I may have a few that are cracked that you could get.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    That would be awesome but i am in the UK. Would that be a problem for you?
    Cheers Mike
    Any other thoughts?
    add shipping and a bit on the top and i'll get the to you!
    nothing relevant to say
    Reputation: Cracked Headtube's Avatar
    Quote Originally Posted by banks
    Is the OP'er prepared to drill 2 small holes on each leg's 'knuckle'? If "No", see about some Lizard Skin neoprene covers
    Quote Originally Posted by Cracked Headtube
    Trial and error with automotive double sided trim tape, Velcro, etc.
    Liz Skins are the fastest way to damage the seals & stanchions.
    What is the issue with Lizard Skins? Are they also problematic for protecting the Joplin seatposts?
    Quote Originally Posted by xree
    These wraps hold fine particulate dirt against the stanchions and seals. Over time that stuff will do damage.
    Yes.
