Results 1 to 2 of 2
    T.W.O.
    Reputation: mimi1885's Avatar
    Seven Duo Ti with Hammerschmidt
    Finally it's done Big Thanks to
    Ethan and Chris From Maverick and Scot at Absolute bikes for providing the supports I needed to make this.
    The whole system add about 2 lbs to the bike which bring it to 28.9 lbs and that's with AMP adj seat post, Modified Mono-link and H'schmidt. Took it out for a quick spin and just love it. Can't wait to clear some technical climb that I couldn't clear before.
    The HS cable routing is a bit tricky and required longer than I expected so I'll fix the housing later. The Mod Link is just so sweet with ISCG 05 tab no facing or frame prep in anyway just pretty much bolt on and run the cable and that's it.
    I'm running 22/36 chainring on the HS and 11/34 cassette with the short cage XO and no shifting and clearance issue so far.
    Schipperkes are cool.
    Reputation: banks's Avatar
    Looks Killer!
    Shift whenever!
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
