Results 1 to 5 of 5
    Removing crown race from DUC32 safely?
    Before I attempt removing the Chris King crown race, is there any suggestions other than using a flat screw driver? The standard crown race puller is not an option here. I've thought about using a Dremel and separating disc to split the race first to avoid damage to the lower crown seat of the fork. Opinions?
    I'll be mounting a Chris King De-evoltion 1.5 race for a Tracer once the old race is off.
    Schipperkes are cool.
    Reputation: banks's Avatar
    Quote Originally Posted by spec-r
    You answered your own question
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    I found an easier way, I lightly tapped a utility blade to separate the crown from the fork. Then with the newly created space, I used a blade from a wood planer to wedge off the race. Just make sure you go edge it slowly off from both sides. Worked like a charm. Much quicker and I was able to save the race.
    As for seating the new 1.5 race, I used a 32mm 1/2 inch drive socket.
    ^^this helped me last night.
    You're welcome!
    :P
