Page 1 of 18 1234511 ... LastLast
Results 1 to 25 of 428
    Reputation: skleins's Avatar
    Post your Maverick!!
    Well..........someones gotta kick it off so it may as well be me
    I present my ML7 size small (Called Jibe) with the later air shock upgrade that works so much better, its got a 100mm Fox Float up front.......so far
    Here are Peabody and Lantana!
    RIDE ON,
    Scotto
    JWB
    JWB is offline
    Beckham @ just over 26lbs:
    John
    PS The seat post works very well for me.
    Two DUC 32's
    Here is a photo of the DUC's I am currently bashing around on
    While not Maverick Frames I thought this might be OK for this thread
    Mar 2005
    My girls ml7
    build this up for my girlfriend.
    she loves it.
    still have not weighed it.
    the cranks are italian extralight 172.5's
    king hubs, triple ti eggbeaters with short spindles.
    I was fast once, but then what fast was changed...
    Question for Crankarm
    Just wondered how you find the Intense compared with the RIP? I have had a 5.5 set up with DUC's and was thinking about the RIP so all comments will be of great interest!
    1FG
    1FG is offline
    Apr 2005
    Here is Bashful...
    Just got it two days ago, a demo bike from... haven't had time to ride it yet!
    Cheers,
    DC
    Reputation: Alpamayo's Avatar
    Hoops - Big and Small
    Reputation: Crash_Burn's Avatar
    Axolotl
    Got a pic of the latest version of my ML7, as you can see from my saddle I've got the new monolink/shock. Kind of miss my old set-up (extra heavy spring w/air assist) running 15-20 psi.
    Whatever
    Reputation: MINImtnbiker's Avatar
    Donkey - ML7/5 from May '06
    Photos are from Porcupine Rim in Moab, 3 weeks ago. Setup for that type of ride...big tires, Mallet pedals. Otherwise I run Candy's and 2.1 Specialized tires and it is a couple pounds lighter...just over 25#s.
    Finally, we've got a velodrome in Boulder. With a sweet indoor mountain bike park! www.boulderindoorcycling.com
    Whatever
    Quote Originally Posted by 1FG
    Cheers,
    DC
    Interesting setup for your Polar sensor. Is that mounted on the bash guard? I have mine mounted on the lower part of the right leg, under the bash guard. I mounted it with zip ties like normal, then screwed the bash guard screws over it and it works just fine. However the big issues is the wireless is not strong enough for the watch to read from the bars... so I have it mounted on the lower fork crown. It seemed wierd at first, but it is nice since I don't always look at it (in the shape I'm in, I don't always want to see my HR!)
    1FG
    1FG is offline
    Apr 2005
    Quote Originally Posted by MINImtnbiker
    I had the same problem on my Cannondale with the lefty fork. If mounted all the way at the bottom of the fork the signal isn't strong enough to reach the watch mounted on the bar. On the Lefty I had to make a special mount (see http://home.comcast.net/~ledrocnoc/M...4Jekyll_05.jpg - here for the bike http://sfbay.craigslist.org/pen/bik/242752061.html)
    When I looked at the DUC32 fork, I assumed I was going to have the same problem, so I just hanged the sensor on the fork guard. I used a hot wire to poke hole through the plastic, used industrial double sided tape and stainless wire to hold the sensor. I recessed the wire inside the guard so that it would not rub against the fork seal. Worked for the 2 rides I did so far.
    DC
    Hey thats some great action shots........
    Whatever
    Polar fork mount "switch"
    DC
    Someone told me that the fork mount piece has a "switch" inside it which can be set for a stronger signal. I'm bleeding my disc brakes today, so while I have the bike on the stand I'll take a look and report back.
    3.14159265358979323846…
    Reputation: velocipus's Avatar
    Apr 2005
    Fushia
    Sigh...
    Oh Glory!
    Reputation: TheProphet's Avatar
    May 2005
    I love seeing all these Mavericks! They are truely one of a kind. My LBS is the only shop in Maryland to carry them and they look great. Looking forward to seeing the new models.
    Cannondale and now Giant.
    Bike Vigilante
    Reputation: momentum's Avatar
    Pepe at Mt St Helens
    04 ML7 with an 06 DUC32 on Mt St Helens last summer.
    Whatever
    Polar sensor range adjustment
    This is off topic for this thread, but I had mentioned above that I'd reply back...I just heard back from Polar about the speed sensor range adjustment. They sent a document back that says there are 3 settings...however adjusting to the longer ranges could cause interference when riding close to others. Just email their customer service for it... or PM me. My issue is that the signal did not reach the watch unit on the my handlebar with the DUC32 fork....so I have to put the watch on the lower fork crown.
    please send me the infos about the different settings because I have the same problem.
    On my ML8 I use a special sensor holder from cannondale for the lefty. It works fine, but is very complicate to install because there is not much space at the DUC to fix it.. I try to give a photo from this solution.
    Massif des Cerces, France, Summer 2006
    My 7.5
    In size small called 'Snapper' Unusual colour
    Pic Taken after shredding 'sidewinder' at Afan - Wales(UK). At this place the performance of the bike was simply awesome!!
    Feb 2006
    Here's my current ML-7.3 (Zola) - preceded by
    ML-7.2 (Goblin)
    Both from ourTop UK Maverick man - Tim Johnson of SidewaysCycles
    My ML7
    Added a little NR mount so it looks like my motorcycle =)
    *edit, noticed that it was a pain to tighten the goose neck bolts and the whole thing was flexing so I made new 2 piece bracket, hardly any flex and easy to service*
    Insanity later
    Reputation: Serenity Now's Avatar
    The new XXL Durance.
    The seat angle is 1.5 degrees steeper than my XL 7.5, which is a big improvement while riding, and also looks better. Head tube is also slightly longer, as is the top tube. All in all a way better fit for me.
    About XXL size
    Hello
    Are they much bigger than the former 2003 ML7 XL ?
    I'm 6 feet 4inches tall, would you recomend an XXL?
    Attached photos of Normie
Hot Deals
Contests
Latest Mountain Bike Articles
