Page 2 of 21 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Results 26 to 50 of 514
  1. #26
    Insanity later
    Reputation: Serenity Now's Avatar
    I don't know exactly how the XXL Durance compares to the XL ML7. I suspect a little larger. It's definitely bigger all around than the XL ML7.5, but that bike was smaller than my ML7.
    For your size I'd probably go with the XXL Durance. It's got a looong top tube, but then again I am really long legged (98cm inseam), so it may feel fine for you.
    Either way, it's a great bike.
  2. #27
    Thank you for your advice. It should fit me even if I'm a little short legged (90cm inseam only!)...
    You're wright, ML7 is a great bike ; 4 years of happy rides and still the state of art...
  3. #28
    T.W.O.
    Reputation: mimi1885's Avatar
    Incredible climbers
    Here are 2 of my pride and joy, both climb like true champs. Maverick rocks!!
  4. #29
    Shattering Glass
    Reputation: dash's Avatar
    Mar 2006
    Quote Originally Posted by mimi1885
    And your favorite is?
  5. #30
    T.W.O.
    Honestly both. Bikes at this caliber are great period. strong climber, great descender and good all around. maybe the Mojo because 5.5" travel, but if compared with the durance it will be a really tough call.
    The ML7 has been with me for years and Mojo only been 3 weeks, so to state the obvious I'm riding Mojo more now one reason is because it's my new toy. Both bike really rock!! my ML7 without the 647 pedal and the Speedball post weight in at 25.2 and the same set up with the mojo is 26( the new I9 wheelset will drop about 1.5-2lbs) but I like the post it worth the extra half a pound.
    Thanks for asking
  6. #31
    Hey! someone else also has a 7.5/Durance and a Mojo.[ And I also have a ML7 from a few years ago!] I love both bikes too, but for me they are really different in feel, the Maverick is like a hardtail with a bit more spring and whip out of a corner, the suspension is less plush even with loads of sag and a better climber than the Mojo whereas the Mojo feels more plush and very smooth...definitely a better descender.......I guess thats why I am keeping both bikes...I love the contrast between the 2! I run the Maverick with SC32 and the Mojo with DUC32...found the DUC's on the Maverick slackened the headangle too much.....enjoy!
  7. #32
    At the risk of hijacking this thread, I'm needing to replace my L ML7/5 with a larger frame and have pretty much narrowed it down to an XL Durance and an XL Mojo. They have very similar geometry (esp, HA, T-T, front center with DUC). I'm maxed out on my L ML7/5 with a Speedball R (ie, setback) and the saddle all of the way back -and it's comfortable for my upper body- but my knees smack the DUC and I can hardly stand and pedal. Real steep climbs (ie, Slickrock) are not doable, even with the travel turned down.
    Problem for me is, in part, they're separated by $400! And, though I'm pretty sure my medium DUC crown will work on either bike, I don't think my 30.9 speedball will work on the Mojo's 31.6 tube. Looked for shims and nobody seems to see the need to go up from 30.9.
    Any advice out there? Thanks.
  8. #33
    Demo the Mojo and get a 31.6 Speedball outer tube from Maverick...easy to swap over...one 10mm nut....hey presto!
  9. #34
    Now that's what I'm talkin about! Thanks. I've been emailing Ethan about my dilemma, in part b/c I'm having trouble tracking down 7/5 geometry so that I can compare numbers, and asked about shimming. He said no problem but didn't suggest the outer tube (maybe it's the $s...). As for the geometry, the Matic won't cut it since its geometry is based on the SC.
    Won't be able to demo a Mojo round Austin, but a buddy has a Lg so I'll get on it this weekend.
  10. #35
    just wrenched my durance together at 4 in the morning
    sram X0, triggers/der.; xtr 175s; avid juicy ultimates 185mm front and rear (organic pads); candy 4Ti pedals; Brooks Swallow Tail Ti saddle, just breaking in.
    Coming from a rigid 26" singlespeed (ok, I put a 2x9 drivetrain and a FoxF80 on it for the mountians), this bicycle feels like cheating. a 20 mile tech/XC ride yesterday felt like 5. My legs we tired but the rest of my body could have gone another 20 miles easy.
    These full suspension bikes *are* like cheating. Only you get to go much faster and ride much farther.
    I'm hooked.
    She's a small with the lightest parts and weighs in around 25.5 lbs. My custom Ti singlespeed (straightgauge litespeed pisga weighs 24 lbs.) Weight is certainly not an issue.
    The only thing I miss is my Chris King rear hub, which wasn't available in time to ship for this weekend. But the fact that it shifts into granny under heavy load without a hitch is so bonus, that again, it feels like cheating.
  11. #36
    Reputation: ragetty's Avatar
    this is not mine, but it blows anything i've seen so far completely away - this is just such a cush build ...
    ragetty
  12. #37
    Reputation: Nanotron's Avatar
    ... and if we just ...
    A nice one from Spain.
    My new ML8.
    I only could test it 12 kilometers... but I think I'll be very happy with this bike.
    Hope to confirm my first impressions next weekend.
  13. #38
    Numerous wiring problems.
    This is Ego, he's a medium ML7, is a naturalised UK citizen and he doesn't look much like that any more, in fact I should take an up to date pic - now has '07 XTR cranks, shifters, mech, Formula B4 SL brakes, Stan's rims etc...
    Had him for about four years now. I reduced the travel on the fork by 15mm which made the whole bike feel much more balanced and together. Was way too chopperish with the original ML7 geometry.
    Lovely, lovely bike, climbs like a mountain goat :-)
  14. #39
    Schipperkes are cool.
    Reputation: banks's Avatar
    Digger.
    Rips up the singletrack in the high elevation of the Colorado Rocky Mountains.
    Scoty
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
  15. #40
    Almost too purty to ride. Almost...
  16. #41
    Reputation: Alpamayo's Avatar
    Quote Originally Posted by sjdiesel
    the seat post, mono 6Ti with rear disk larger than front ??? .... and the color
  17. #42
    that doesn't work for me either - but then, beauty is in the eye of the beholder.
    actually, the frame colour is ok, but it needs more "complementary" support (as opposed to just everything apple green) from the peripherals.
    @mimi1885:
    any chance of a pic of the ibis from the side?
    ragetty
  18. #43
    My old 7/2 (2004) silver anodized, destickered and Hard anodized before to be stickered like original.
  19. #44
    recovering roadie
    Reputation: dobbs's Avatar
    [QUOTE=Alpamayo]My old 7/2 (2004) silver anodized, destickered and Hard anodized before to be stickered like original.
    How do you desticker and resticker? I have a 2004 that needs a little TLC and I called Maverick yesterday and they said it wasn't really possible.... ? ?
  20. #45
    [QUOTE=dobbs]
    Quote Originally Posted by Alpamayo
    High pressure hot water or/and with strong adhesiv. You can also use sand treatment like to remove paint, before hard anodizing. The result is the same you can see on hard anodizing frame ML8 or durance ...
  21. #46
    Meet Mohawk. He is a 2007 Matic with Speedball R. This is only my second true full suspension bike but I must say this is one freaky cool machine... It makes me want to do stuff I have no business doing
  22. #47
    ML7/2 2004 after (re) hard anodizing and original stickers
    Now, all the familly in hard anodized version :
  23. #48
    Just finished building this....
    Not ridden it yet, put my back out so need a few days off the bike.....
  24. #49
    T.W.O.
    My Mavericks
    Great climber, great descender.
    I love my Mavs
  25. #50
    trail demon
    Jun 2005
    Here is......
    Xenia (top - ML8)
    Azerbaijan (Middle - ML7.5)
    Zarek (Bottom - ML7.3) now has a new owner & used in the mountains of france.
