Results 1 to 6 of 6
    new Enduro seals on Marverick
    Has anyone tried the new Enduro seals for a Maverick fork? Now a 2 piece design with a wiper and an inner seal
    Schipperkes are cool.
    Reputation: banks's Avatar
    Not advisable. Use the Maverick factory blue seals as the seals are designed for upside down use.
    There is a lot of drag with Enduro seals and over 11+ years of over hauling forks, I do not recommend nor install Enduro seals; keep 'em factory.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Reputation: ragetty's Avatar
    on the photo it says '2009' ...
    i must agree with banks - properly installed (i.e. dry against the fork frame) and lubed (on the sliding surfaces), i have zero problems and no stiction with the standard blue seals.
    but i do swap them out once a year ...
    ragetty
    Reputation: Alpamayo's Avatar
    no more, as banks, too much of drag with the enduro seals.
    Maverick ML7.2 / SC32
    Maverick ML7.5
    Maverick Durance / Duc32
    Maverick ML8 / BOS Devile
    French Maverick Breeder
    excellent, thanks for the info. I have Maverick blue seals on two Duc32s and have always worked well. Need to buy some spares so will stick with 'em.
    No good enduro blue seal
    have you ever tried the blue seals? not appeal to you to hear people say?
