Results 1 to 5 of 5
    Sep 2004
    ML8 rear shock losing air.......
    Hello ml8 rear shock is losing air over a short ride, is first port of call cleaning the o ring and chamber (sorry not very mechanical minded) and replace oil??If so what oil should i use??
    All advice and help welcome.
    Reputation: ragetty's Avatar
    go over to the maverick website and check out their service pdfs - there is a pdf specifially on troubleshooting.
    in the other pdfs on component service, you'll find the information you need in terms of oil, etc.
    ragetty
    cyco biker
    Reputation: RTrainer's Avatar
    Dirt happens
    Probably particles of dirt around the seals letting the air out. Pretty simple job. Let air out & pull it apart. Dump the old oil & make note of it's health. Wipe everything around the seals clean. Add more oil (~20cc). Put it together. Air up & go.
    Of note... be careful backing out the base set screws only enough to release the upper shock. Too far out & the O rings are a bear to get back in w/out mangling them. Read the 1st 11 pages of the below PDF for pic's & more details.
    http://www.maverickbike.com/cms_images/file_16.pdf
    My hobby is keeping wood alive
    Schipperkes are cool.
    Reputation: banks's Avatar
    How old is your frame? What is the colour of the dust wiper seal; black or blue?
    Stock amount of oil for the shock body is 15ccs of Fox Float Fluid/Rock Shox Redrum. 20ccs will make the rear end more progressive-rammpy.
    When you are done cleaning out the body & seal, just before you install the damper, smear a good fingerfull of Slick Honey in the wiper seal lips; that will allow the seal to work cooler and be a bit more plush.
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Reputation: Denis's Avatar
    Quote Originally Posted by Hicksville
    If you are still struggling with air loss problems after changing the seals, check out my older thread at HELP: rear shock loosing pressure...
    Denis
